Hi
Can someone please assist me ? My Vehicle keeps on going into limp modes. Did a scan and the code shows P0299.I HAVE REPLACED THE SENSOR AND TURBO
VW TOURAN 2005 2.0TDI LIMP MODE
- Car Model: 2.0TDI
Re: VW TOURAN 2005 2.0TDI LIMP MODE
Check exhaust for restrictions
Check EGR valve stuck open
Check exhaust manifold and EGR pipes for exhaust leaks
Send injectors for testing.
Check actual values of MAF and MAP sensors, fuel pressure sensors
Actual fuel pressure before filter to verify lift pump function
The P0299 code will be stored when the turbo is not making sufficient boost.
This occurs when you have conditions to reduce gas flow through the engine and or turbo. For example, massive exhaust leaks, bad injectors that are under fueling. The latter can't be diagnosed by the computer, only on an injector test bench.
