Velocity golf mk1 heating unit
My velocity golf mk1 2005 model heating unit is giving me problems. Weather the nob is on hot or cold it blows hot air in the cabin. What could be the issue/problem?
Re: Velocity golf mk1 heating unit
Look inside your engine bay, next to your brake booster there is two (2) pipes that are connected to the engine that go into your car. The one pipe has a funny looking black plastic thing (it's called a *heater valve*) in it that has a cable attached. The cable has come loose or the valve is stuck open.
Get someone to fiddle with your knob while you observe the cable and the valve. Observe if the valve is closing fully or not, or if the cable is moving at all. Move the lever on the valve to it's fully closed position and see if this resolves the issue. If this does not, purchase a new valve and install it.
Thanks for the advice. I've bought a new valve and it's still blowing hot air.
Adjust the cable to get the cable fully closed.JarrodBradley wrote:Thanks for the advice. I've bought a new valve and it's still blowing hot air.
There are also 2 types of valve, early type for the square style dash and late for Velo style dash.
If you have the early style installed it reveals the control knob, as in hot is cold and cold is now hot.
Try turning the knob to full hot and see what happens.
