Afternoon guys I own an mk1 1.4 feul injection ad iam have a problem with the consumption, black smoke revs until 4000
My tena citi is have a problem i changed my feul pump with a after market one and since that it has been using too much fuel and releasing smoke leaving my tips black with ashes
- Car Model: Polo Vivo
Re: Afternoon guys I own an mk1 1.4 feul injection ad iam have a problem with the consumption, black smoke revs until 4
I'm not an expert but it looks like your pump is sending too much fuel to the engine. Maybe you purchased a pump that is for a bigger engine or you purchased a performance fuel pump?
Kandorozuivangua wrote: ↑Mon Jun 22, 2020 3:52 pm My tena citi is have a problem i changed my feul pump with a after market one and since that it has been using too much fuel and releasing smoke leaving my tips black with ashes
Kandor
I believe there to be many things that can coz this black smoke
And thing is you gone run around and spend money by tryna figure out the issue.
I am no expert but if any1 els seconds me then i would say get some1 with VCDS to check the sensors and to check for errors .
If the person is a merchanic also to check timing
I changed sensors back and forth just to find out it was timing.
Hope you come right
Cheers
Lesedi
I dont see how a more higher pressure pump can coz issues
There is a FPR regulating the pressure and release fuel if there is too much pressure back to the tank.
The injectors also only open and close on comand of the cpu so still cant have a issue.
I can be wrong
Cheers
Rourke wrote: ↑Fri Nov 13, 2020 11:55 amKandorozuivangua wrote: ↑Mon Jun 22, 2020 3:52 pm My tena citi is have a problem i changed my feul pump with a after market one and since that it has been using too much fuel and releasing smoke leaving my tips black with ashes
Kandor
Hope you come right
Cheers
