Motul gear 300 75w90 GL-4/GL-5 R165.00 per L
100% Synthetic lubricant. For high performance and racing cars. 0% Shear loss. Improved efficiency
Motul Multi DCTF for DSG or S-tronic R139.00 per L
Lubricant especially developed for duel -clutch transmissions (DTC) supplied by ZF, GETRAG or Borg warner and used by the main car manufacturers
We also got some brake cleaner R98.00 per can
Motul M4 water less hand cleaner (perfect for breakdowns and flat tyre changing) R70.00 per tube
Motul gearbox oil with pricing
- Goldwagen Delarey
- Membership No: 1800
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
Re: Motul gearbox oil with pricing
Is motul gear oil better than the liqui molly?
see they the same price for 1L
- Car Model: A3 1.8T
- Membership No: 1989
I would rate them the same, Specs are the same and we are running Liqui Moly in the golf, and wont change for the Motul.PoloGTIman wrote:Is motul gear oil better than the liqui molly?
- Stompie
- Boostleak Guru
- Car Make: BMW
Ok Cool! will probably change my oil this weekend.
- Goldwagen Delarey
I agree with Ashley on this and can get some performance specs if you wantAshley =1.8T= wrote:I would rate them the same, Specs are the same and we are running Liqui Moly in the golf, and wont change for the Motul.PoloGTIman wrote:Is motul gear oil better than the liqui molly?
- Stompie
- Boostleak Guru
- Car Make: BMW
Thanks wikus, but dont worry about the performance specs, im happy with the oil, im sure when ever i get change to actually put it in the gearbox ill be even more happier!
