Page 7 of 7
Posted: Sun Apr 05, 2015 2:31 pm
by Kyli3boi
I didn't buy the calipers from them just the disks and spacers, I don't mind if I have to buy new calipers it's just I need to get this sorted ASAP
Posted: Sun Apr 05, 2015 7:17 pm
by missioner
The kit is designed for a citi and to work with stock calipers.
Go see them on Tuesday and I am sure they can get you sorted out.
Posted: Sun Apr 05, 2015 7:34 pm
by Viper
Hi mr. I will message you now
Posted: Tue Apr 07, 2015 12:03 pm
by AlexTDi
Check that the mounting points on the hub carriers are straight and not bent in or out.
These things:
Posted: Tue Apr 07, 2015 1:16 pm
by Viper
Kyli3boi wrote:Hi,
All sorted out. He was here this morning with everything . His calipers are aftermarket pirate once and the brackets crossing the discs is thicker . So with the std 237mm it doesn't matter but with the 280mm discs the larger diameter is just to much. We took the pencil grinder to it and cleared just enough the give the discs some space. So now we know that there are some clearance issues with the aftermarket calipers .
Posted: Wed Aug 19, 2015 2:06 pm
by Vernon
What is the total height of the disc itself and the thickness
Posted: Wed Aug 19, 2015 2:16 pm
by AlexTDi
Vernon wrote:What is the total height of the disc itself and the thickness
280mm by either 18/20mm thick
Posted: Wed Aug 19, 2015 2:38 pm
by Vernon
AlexTDi wrote:Vernon wrote:What is the total height of the disc itself and the thickness
and the total height ?, why i'm asking is i have the powerbrake spitze disc and its height is 39,5 mm
Posted: Wed Aug 19, 2015 5:11 pm
by Viper
Vernon wrote:AlexTDi wrote:Vernon wrote:What is the total height of the disc itself and the thickness
Correct , the disc we use have a total height of 39.5mm
Posted: Wed Oct 26, 2016 10:18 am
by 8VALVE-zn
Hi there Viper,
Could you be so kind to put up the 2016 price for these kits with extra bits for road & track use.
Thanks in advance.
Posted: Mon Oct 31, 2016 3:22 pm
by Viper
8VALVE-zn wrote:Hi there Viper,
Thanks in advance.
Pryse have been updated on page 1
Posted: Tue Feb 28, 2017 8:56 pm
by Genesisfs9
Are there any kits available to change the back from drums to disks?
Re: RE: Re: 280mm bolt on Brake upgrade kits for MK1 is here!!!
Posted: Tue Feb 28, 2017 8:58 pm
by Viper
Genesisfs9 wrote:Are there any kits available to change the back from drums to disks?
On witch vehicle?
Posted: Tue Feb 28, 2017 9:02 pm
by Genesisfs9
Golf mk1 06
Posted: Tue Feb 28, 2017 9:08 pm
by Viper
We use the mk3 rear brake setups. Straight bolt on. But rather spend the money on the front brakes, the rear shoes are more than sufficient even on track.
Posted: Tue Feb 28, 2017 9:18 pm
by Genesisfs9
I was thinking on doing both the front and back or just the back to disks. I don't like the look of the drums makes the car look silly. I 'll start with the front I think. Also the hand brake doesnt hold the car very well.
How much is the mk3 setup and can I get it from you guys?
I 'll have to put the brakes on hold for a while. As my intake manifold sprung a leak and the thermoswitch is now broken as well. You guys stock the intake? My car has a carb.
Posted: Thu Oct 01, 2020 10:57 am
by Rathbone
Does anyone have a part number or at least have a year model number for me... nobody knows what im talking about...
Posted: Thu Oct 01, 2020 12:16 pm
by Viper
Rathbone wrote:Does anyone have a part number or at least have a year model number for me... nobody knows what im talking about...
You can contact me on 0824103147 for more details on this kit
Sent from my SM-G973F using Tapatalk
Posted: Sat Oct 03, 2020 2:48 am
by Rathbone
Ok thanks will contact you in the morning
Sent from my SM-A750F using Tapatalk
