Page 6 of 7
Posted: Thu Apr 17, 2014 12:24 pm
by Torker
moonwillow wrote:It was smoking. Almot looked like my engine was on fire
When I bed my brakes they start smoking on the 5th or 6th stop out of 10, looks scary...
Posted: Thu Apr 17, 2014 12:30 pm
by Pieta
ShafiqNC wrote:hey guys
i fitted this kit to my project but im having a small issue
the disc is sitting way to close to the carrier...
ive spoken to viper about this and he also hasn't experienced this before
anybody else seen this before?
any ideas as to why this could be happening?
both sides are doing the EXACT same
Mine did the same, just touched the carrier with a flap disc on the grinder, problem, no problem.
Posted: Tue Apr 22, 2014 8:38 am
by GTiDon
How did you get that right? Are you sure its not a fluid leak?
Posted: Wed Apr 23, 2014 6:18 am
by moonwillow
How did you get that right? Are you sure its not a fluid leak?[/quote]
Well I installed a 288 deg cam and took the caddy for a spin. If it was fluid leak my brake fluid bowl level will drop and the level is still the same.
Posted: Sun May 11, 2014 2:16 pm
by mk1strand
Is this brakes still availible?
Posted: Sun May 11, 2014 4:31 pm
by Viper
Yes we got plenty stock
Sent from my GT-N7105 using Tapatalk
Posted: Sun May 11, 2014 4:33 pm
by mk1strand
Can you please pm me your contact details
Posted: Sun May 11, 2014 4:48 pm
by Viper
Goldwagen Delarey
624 Ontdekkers road
Delarey
Roodepoort
0114779979
Or just send me a PM of what you need. We can do courier or postal orders 2
Posted: Wed May 28, 2014 5:15 pm
by Tipstar
Hi viper dd pm u nt sure u gt it im interestd in the brake upgrade
Posted: Thu May 29, 2014 6:11 am
by Viper
PM send
Posted: Mon Jun 02, 2014 1:31 pm
by dubstar
Hi Viper do you guts have this kit for a Polo 6n (1997)?
I have std size ATE discs that's slotted and drilled and maybe use EBC green pads with it .
Posted: Mon Jun 02, 2014 2:03 pm
by Viper
dubstar wrote:Hi Viper do you guts have this kit for a Polo 6n (1997)?
Unfortunately nothing
Posted: Mon Jun 02, 2014 2:26 pm
by yeo786
Price of this kit?
Posted: Mon Jun 02, 2014 3:10 pm
by Viper
yeo786 wrote:Price of this kit?
Polo cup discs A2674 (GW Part number ) R860.00 per set
Brackets R850.00 per set (incl 8.8 HT bolts)
Brake pads:
for street use ATE R181.00 per set
For the track EBC yellow R1091.00 per set
For a mix of track and steer EBC Green R907.00 per set
Posted: Mon Jun 02, 2014 3:23 pm
by yeo786
You have pm
Posted: Mon Aug 04, 2014 7:36 pm
by lpret
hi there,
just a quick question, this would work on the Cti 's stock setup, not sure if they had the same caliper as all the rest?
also from the posts its seem 15" wheels a must? I'm still on the stock 14' s 6 spoke alloys
thanks
Posted: Mon Aug 04, 2014 7:45 pm
by Viper
Will fit the the Cti stock calipers. Any you will have to get 15" rims. Caliper won't clear 14s
Posted: Sun Aug 10, 2014 7:54 pm
by lpret
TX for the reply, this is something i am putting on the To Do list, together with the 15's
Posted: Sun Sep 07, 2014 8:14 pm
by lpret
Hi there, another quick question, do you guys sell/stock the braided brake lines as well as the Dot 4+ fluid you (if I'm not mistaken) mentioned elsewhere and what are the prices?
TX
Posted: Sun Sep 07, 2014 8:18 pm
by Viper
We don't sell braided brake pipes but we do sell Motul RBF660 racing brake fluid. R174.00 per 500ml
Posted: Mon Feb 16, 2015 10:03 am
by Kyli3boi
Hi Viper,
Can you please give us a updated as to the prices?
Posted: Mon Feb 16, 2015 11:56 am
by Viper
Kyli3boi wrote:Hi Viper,
Polo cup discs R900.00 per set
Brake pads: R200.00 ferodo
Posted: Sun Apr 05, 2015 12:17 pm
by Kyli3boi
Hi,
Posted: Sun Apr 05, 2015 12:48 pm
by Pieta
Kyli3boi wrote:Hi,
Hi bud,
Send Viper a pm. He will get a notification if you pm him. He is not always on the forum.
I had the same kit on my car with no issues.
Posted: Sun Apr 05, 2015 1:33 pm
by missioner
Kyli3boi wrote:Hi,
Should have taken it back before putting the grinder on it and explained your problem. The guys would have then been able to steer you right.
Viper has this same kit on two of his personal vehicles and supplied dozens of other guys on the forum who are all happily driving them.
