Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF IN STOCK !!!
- Goldwagen Delarey
- Membership No: 1800
There have been some questions in the wanted section for ABF flywheels and i think i have come up with a solution!
We have a clutch kit on the shelf here (made by Valeo) that replace the duel mass of the VW golf 4,A3 and polo 9N 1.8t with a solid mass flywheel (ABF) and use a vr6 2.8 clutch on that.
Size:
Od of ring gear 281mm
thickness of flywheel 43mm
Clutch plate size 228mm
We sell the compete kit for R4960.00 (flywheel, pressure plate, clutch plate + thrust bearing)
Size:
- Criminal Troll.
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 vr6 ? AVAILAB
As far as I know it's the AbF flywheel and VR6 clutch
- Goldwagen Delarey
What is the difference between ABF and AAA flywheel's?boost'd wrote:As far as I know it's the AbF flywheel and VR6 clutch
- Registered for: 18 years 9 months
The crank bolt pattern.Viper wrote:What is the difference between ABF and AAA flywheel's?boost'd wrote:As far as I know it's the AbF flywheel and VR6 clutch
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
ABF flywheel will have 6 bolt holes like the one in your pic, the VR flywheel will have 9 holes.Viper wrote:What is the difference between ABF and AAA flywheel's?boost'd wrote:As far as I know it's the AbF flywheel and VR6 clutch
- Goldwagen Delarey
So this will work on 4cyl crank shaft and cable shift/ hydraulic gearbox setup?
- Goldwagen Delarey
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF OUT OF S
NO sorry mr it will not fit. I do not know if there is a solid mass conversion foe the 6 sp. I know we can order aluminium flywheel and racing clutch kit from the uk, but it is not cheap (about 15k)Pynoxim wrote:When these are eventually in stock, would they fit a Mk4 with a 6 Speed Gearbox as I've heard that there are differences between the 5 Speed and 6 Speed Gearboxes.
- Goldwagen Delarey
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF IN STOCK
Hi every one !!
The Valeo kits with the solid mas flywheel for the 1.8t 5sp boxes is back in stock again!
- Dougi
- Broekn Neuws Reportr
- Car Model: Seat Ibiza Cupra, TDI
- Membership No: 1662
how will this kit work on the TDIs?
- Goldwagen Delarey
Nee mr it will not work. TDI sport line is 6sp SorryDougi wrote:how will this kit work on the TDIs?
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Clutch kit only, how much? Mk2 GTi 16v Cable Shift.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
That is a awesome price for the whole kit wikus! now i know who to come see when mine decides to fail!
- Goldwagen Delarey
The one that fits this flywheel is the vr6 type R1157.00VWicked wrote:Clutch kit only, how much? Mk2 GTi 16v Cable Shift.
The 2.0 16v once is in the process of being discontinued and they are R1112.00
- VWicked
Hmm what is difference in design between vr6 and mk2 16v? My car would have the same flywheel like an ABFViper wrote:The one that fits this flywheel is the vr6 type R1157.00VWicked wrote:Clutch kit only, how much? Mk2 GTi 16v Cable Shift.
- Goldwagen Delarey
I will check and come back to you!VWicked wrote:Hmm what is difference in design between vr6 and mk2 16v? My car would have the same flywheel like an ABFViper wrote:The one that fits this flywheel is the vr6 type R1157.00VWicked wrote:Clutch kit only, how much? Mk2 GTi 16v Cable Shift.
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF IN STOCK !!!
Hi any ABF / G60 spec flywheels for sale? Which other flywheels would fit? Any help would be greatly appreciated. Thanks Sheldon 0612916242 based in Gauteng
- Car Model: A3 1.8T
- Membership No: 1989
Hey bud please have a look at this thread. My whatsapp number is 0787325682 if you want to chat on there.Sheldon123 wrote:Hi any ABF / G60 spec flywheels for sale? Which other flywheels would fit? Any help would be greatly appreciated. Thanks Sheldon 0612916242 based in Gauteng
http://www.vwclub.co.za/forum/viewtopic ... 5&t=203017
- Registered for: 3 years 11 months
Hi. Do you still sell this kit? Thanks
Call the boys at DRD in Roodepoort and ask, this thread is old.ChadGeeTeeEye wrote:Hi. Do you still sell this kit? Thanks
