ZWARTKOPS TRACK DAY Sunday 26 August 2012
- Goldwagen Delarey
- Car Model: GOLF 1 1870cc 8v ethanol
- Membership No: 1800
http://youtu.be/T5vNEh8pVIg
It was so allot of fun and the brakes worked perfectly again with no issues. So we just wait for few weeks and the brake upgrade kit will be available for resale. The car ended up doing a 1:24.16 what i fink is not to bad considering i only got 2 track days behind me incl this one and we were still on road tires wit 40mm drop suspension.
please let me know what you fink.
- Car Make: Mercedes
- Car Model: AMG
- Membership No: 1368
Re: ZWARTKOPS TRACK DAY Sunday 26 August 2012
Not bad. There's definately some time to be made, esp in turn 5. The brakes seem pretty sharp!
.....Past Volvo S70R (GT3582R modded), Volvo XC70, Volvo 850 T5, VW Jetta VR6 (Rebored), VW Jetta CLX, VW Golf II GTS
Present Mercedes ML500, Mercedes SLK32 AMG
.Project '74 W114 Benz
- Dougi
- Broekn Neuws Reportr
- Car Model: Seat Ibiza Cupra, TDI
- Membership No: 1662
That is awesome Oom.
Now you need coilies for the GW golfie
- Goldwagen Delarey
Cool thanks . I must say the brakes got bigger balls than me, so more practice it is. My tires took a good pounding this time, I will have to invest in some semi slicks and some coil over shocks.
- Car Model: AMG
Yup... definately looks a little bouncy through 3. Coilies are a must, also will assist you with camber which will help save your tires.
- Car Make: Opel,VW, Ford
- Car Model: Corsa, Citi, Figo
- Membership No: 1995
What motor are you running?
I used to have money.... But now I have a Racecar!!!
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Tell us more about the brake upgrade
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Goldwagen Delarey
Working on that problem. I'm looking at D2 racing suspensions.Dougi wrote:That is awesome Oom.
- Goldwagen Delarey
1800 crankDodging wrote:What motor are you running?
83mm piston
10.5/1 compression
298 camshaft
2E head (gas flowed)
Spitronics Management
Balanced bottom end
2.8 Audi v6 throttle.
- SHAUN
- Post Whore
- Registered for: 19 years 9 months
- Car Make: BMW
- Car Model: 2006 335i
- Membership No: 1148
Also have a look at XYZ coilovers, they come with camber plates for the MK1 and are 30 way damp adjustable.Viper wrote:Working on that problem. I'm looking at D2 racing suspensions.Dougi wrote:That is awesome Oom.
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
Viper wrote:1800 crankDodging wrote:What motor are you running?
83mm piston
10.5/1 compression
298 camshaft
Balanced bottom end
You'll still get plenty time off that 1.24
- Goldwagen Delarey
Basically we supply 280mm 4/100pcd discs (no drilling) with 2 aluminium brackets (will space caliper out) You will reuse your old caliper.VWicked wrote:Tell us more about the brake upgrade
Then you decide what pad you want to run STD, EBC green or EBC yellow .We can then also supply braided hoses and 5.1 brake fluid.
The 280mm disc we used was just plain (no slots, not drilled) But we are looking into getting them slotted. Ill post pictures as soon as i can.
BTW back brakes STD drums.
- Goldwagen Delarey
Who is the dealers for them in SA?SHAUN wrote:Also have a look at XYZ coilovers, they come with camber plates for the MK1 and are 30 way damp adjustable.Viper wrote:Working on that problem. I'm looking at D2 racing suspensions.Dougi wrote:That is awesome Oom.
- SHAUN
- Post Whore
- Car Make: BMW
Speak to RobViper wrote: Who is the dealers for them in SA?
- Goldwagen Delarey
Call stupid, but Rob who?SHAUN wrote:Speak to RobViper wrote: Who is the dealers for them in SA?
- SHAUN
- Post Whore
- Car Make: BMW
Rob Prece, owner of volksiepares.Viper wrote:Call stupid, but Rob who?SHAUN wrote:Speak to RobViper wrote: Who is the dealers for them in SA?
