Clutch pedal hard and difficult to get gear
Replacement parts suitable for: VW ~ Audi ~ Seat ~ Opel ~ BMW ~ Mini ~ Mercedes Benz
Joshua92
Post by Joshua92 »
Hi guys,
I have a issue with my clutch pedal,
So after i replaced my release bearing my clutch pedal is hard and difficult to get gear, when i removed the release bearing i saw that my rod was burnt aswell assuming it could be of to much friction, i replaced rod and same happened dont wanna drive so cause scared i could damage my pedal box, so i dropped the box and it seems fine thrust plate looks good also, so im thinking of replacing clutch and pressure plate, could that maybe be the problem? And i replaced clutch cable but still so
Need help asap
Regards,
Joshua
