NF Product Line Up
NF provides a range of high quality products that solve a wide range of fuel problems and are unique, very affordable and achieve amazing results!
NF.
Fuel Additive Specialist
Car Make: Subaru
Car Model: STi 6 Type-RA 555 V-Limited
NF Product Line Up
Post by NF. » Tue Oct 26, 2010 5:54 am
NF has a range of products for all vehicles. For detailed information on the products, to find your nearest dealer or to buy on our online shop, please visit our website.
NF Octane Boosters
  • Eliminates detonation / knocking / pinging / pinking
  • Increases acceleration & performance
  • Reduces hesitations & engine temperatures
  • Safe for oxygen sensors & catalytic convertors
  • Non-Flammable
  • Easy to use: The bottle is designed to fit right into the tank.
  • Safe: Doesn't instantly damage paint if spilled and has a child-proof cap.
There are currently 4 products in the octane booster range:
NF Race (Black): 6 Octane increase, treats 60 litres, for use on race and track days for a little added protection.
NF Sport (Blue): 5 Octane increase, treats 60 litres, recommended for everyday use in high performance cars.
NF Street (Red): 3 octane increase, treats 50 litres, a strong yet reasonably priced octane booster for those looking for a little more perfomance and safety.
NF Bike Boost-N-Clean: Designed for 2 wheel performance junkies. Treats 1 tank (5-20 litres) for a 5 octane increase and has high-strength, concentrated cleaners to maintain a clean fuel system and combustion chambers.
NF Ultra Race Fuel Concentrate
Since the discontinuation of lead in fuels since January 2007 and therefore the discontinuing of 102.6RON Race Fuel, people were asking for an alternative. We started importing the NF Ultra to meet this requirement. A tin of NF Ultra was added to 40 litres of 95 and sent to a laboratory for octane testing, resulting in an octane improvement of 102.7RON which is very close to the manufacturers claim of 103. The laboratory certificate is available on our website.
  • Instantly increases octane rating by up to 10 RON
  • Low metal content - therefore no spark plug fouling issues.
  • Safe to use in every tank
NF Diesel Boost
NF Diesel Boost is great for use in ALL diesel engines in cars and trucks. Simply add the unique formula to the fuel tank before filling to boost power and performance and maintain a cleaner, smoother running engine.
  • Restores and boosts power & performance, improves accelleration and throttle response
  • Helps remove hesitations
  • Increases cetane rating of diesel by up to 5 numbers
  • Cleans injectors and entire fuel system
  • Maintains a clean engine and fuel system if used continuously
  • Removes deposits from combustion chambers, extending engine life
  • Reduces carbon formation, extending oil life. Cleaner oil means less wear and tear on the engine
  • Reduces diesel smoke
  • Improves cold starts
  • Reduces harmful emissions
  • Improves fuel economy
  • Adds lubricity to low sulphur diesel, lubricating fuel pumps and injectors
  • Protects engines and turbochargers - even when used with high sulphur diesel
  • Inhibits corrosion
  • Treats 1 tank up to 100 litres of diesel
  • Non-Flammable
NF Petrol and Diesel Savers
Looking for something to save fuel that actually works? The NF Fuel Savers contain a combustion catalyst which results in the fuel achieving a more complete combustion during the combustion cycle thus limiting combustion during the exhaust cycle which leads to lower fuel consumption, lower emissions and better performance. In addition, deposits on pistons, valves, injectors are gradually broken down resulting in a cleaner, smoother, more efficient engine. This leads to lower maintenance, reduced engine wear and extended engine life. NF Fuel Savers will keep a new engine clean and can clean up a dirty engine while allowing the fuel used to burn cleaner. This offers a cost effective way to save fuel, conserve energy, protect the environment and yet not sacrifice performance. One bottle treats 300 litres and the bottle design allows you to measure exactly the amount of fuel saver you need for the amount of fuel you are filling.
NF 3-in-1 Fuel Cleaners
Maintain a clean fuel system for a better performing engine.
  • Contains specially formulated high strength cleaners
  • Cleans fouled injectors, intake valves & combustion chambers
  • Removes gum and varnish build up from entire fuel system
  • Restores accesleration & performance
  • Improves Fuel Economy
  • Safe for catalytic convertors and oxygen sensors
  • Non-Flammable
  • Treats 100 litres
  • Recommended for use at least every 10 tanks
