NF race fuel concentrate
- Voora Molester
What is the ideal mixing ratio of this product?
i put in half a bottle to 2/3 a tank of fuel and really cannot feel a difference....
car = Subaru 2L turboh
- Le Clue
- Membership No: 1458
Re: NF race fuel concentrate
I use a full bottle to a full tank. Up's the octane to 100..then adjust my map and give it about 50km's..
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- PoLonY
- Car Model: A8
- Membership No: 1997
did you read the can?yakuza racer wrote:What is the ideal mixing ratio of this product?
- Le Clue
Also noticed now, half a bottle you'll barely feel a difference. Always use a full bottle.
Previous Rides:
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- Voora Molester
yes i did.. there is no instructions on it... will take pics and send them to you.PoLonY wrote:did you read the can?yakuza racer wrote:What is the ideal mixing ratio of this product?
@leclue - done about 60km's thus far, my car is a bit older so maybe takes a while... will dump the rest of it in when i get home... or rather fill it up proper and add the rest of the contents.
- PoLonY
- Car Model: A8
ok then did you try NF's website for instructions?yakuza racer wrote:yes i did.. there is no instructions on it... will take pics and send them to you.PoLonY wrote:did you read the can?yakuza racer wrote:What is the ideal mixing ratio of this product?
only works when used with 60litres of fuel
I don't need pics thanks
adding more fuel and then the rest of the contents will just dilute it even more
- PoLonY
- Car Model: A8
5ml per 1l is maximum recommended dosage so yes, must be with 60lSparkz0629 wrote:so don't try use it with 59 liters, or with 61 liters...PoLonY wrote:
- Voora Molester
NF Ultra Race Fuel Concentrate is designed for vehicles that have been tuned for high-octane race fuel.
1 tin mixed with 60 litres 95 RON pump fuel increases petrol octane to 101 RON
1 tin mixed with 40 litres 95 RON pump fuel increases petrol octane to 103 RON *
1 tin mixed with 20 litres 95 RON pump fuel increases petrol octane to 105 RON
ok cool, thanks for the help...
my tank does not get 60L of fuel... so what to do? fill up and toss in half a bottle?
i think i'll wait for NF to comfirm
- PoLonY
- Car Model: A8
You said Race, not Ultra, 2 different productsyakuza racer wrote:For reference:PoLonY wrote:
- Voora Molester
that is the product i bought....
"NF Ultra Unleaded Race Fuel Concentrate"
i dont see the confusion, should have stated it in ze beginning...
- brads
- Car Make: BMW
Ultra can be mixed in greater concentrates due to its different composition compared to other NF products.yakuza racer wrote:
Its also safe at higher dosages whilst other octane boosters tend to foul plugs.
Put a can into your tank.I take it you have 55L tank? that's fine.
I have used a can of NF to half a tank before with no issues.
ex.
MK 7 GTI
MK 6 GTI
MK 7 GTI
MK 6 GTI
- Sparkz0629
- Car Model: 2012 Polo GTI
- Membership No: 1768
We all thought you were talking bout this one:
- PoLonY
- Car Model: A8
exactlySparkz0629 wrote:We all thought you were talking bout this one:
- Voora Molester
this is a 1L bottle.... so 1L - 55L??brads wrote:Ultra can be mixed in greater concentrates due to its different composition compared to other NF products.yakuza racer wrote:
@polony - i said concentrate man dammit lol
*my bad mah niggahs!
- Fuel Additive Specialist
- Car Make: Subaru
- Car Model: STi 6 Type-RA 555 V-Limited
I would use a full tin in a full tank of 95 (+-52 litres in your Subaru). I run this in my STi 6 and the car is very happy with zero detonation.
If I recall correctly, you said your car was mapped for 95. If you have an Apexi ECU or similar, it won't adjust for the better fuel as much as the standard ecu, so this could be why you don't feel a big difference. My car was mapped on the NF Ultra which gave me an extra 12 degrees timing advance and 0.35b boost over 95 resulting in just over 40wkw extra.
- Voora Molester
stock standard ECU and i will eat my words, just think it needed some more time to adjust...NF. wrote:I would use a full tin in a full tank of 95 (+-52 litres in your Subaru). I run this in my STi 6 and the car is very happy with zero detonation.
the car feels better, sounds better (i dunno, but it sounds deeper on normal driving) and pulls!!
you have a customer for life man, the product really does work great!!
also 0_o 40wkw!!! gawd damn! what ecu you running?
- Coroner
- Car Make: VW / Subaru
- Car Model: Citi 1600 / 2.0 T
- Membership No: 1502
I let them fill the tank with say 10l of fuel. Then dump the bottle of Ultra in and let them fill it to the top. Thats on a empty 55l tank. The car LOVES it.....
- Car Make: Subaru
Apexiyakuza racer wrote:also 0_o 40wkw!!! gawd damn! what ecu you running?
- Chris_FZ
- Forum Advertiser
- Car Model: 2015 Vw Caddy Pv 2.0TDI
- Membership No: 2065
-Vw Caddy Pv 2.0TDI 2015-
-Nardo Grey & Black Trim
-Rolling on 19" Santiago's and Toyo's
-Owner of Retrofitters
-073 754 5203-
-073 754 5203-
