Dear All,
I have problem with my Audi A4 2013 model, It was stopped and showing ESC fault after Audi check up says:
Complaint : Vehicle cutting out and engine light on
Cause : during our diagnosis we found that all faults on the car were related to ENGINE CONTROL UNIT communication
All components connected to the engine control unit had a communication fault, which means there isn’t a communication possible with the ECU.
We then carried out test which verified that the ECU unit is faulty and it’s no longer communicating and it needs to be replaced.
This problem came up just after few days i took the car get serviced at Audi, now they want to charge me R23k for this cause they said the ECU has been tampered even my car still under maintanence plan and all the work was done by Audi. If they not cover it i would like to find some capable workshop to fix it and pay less. Please any one can advise on this issue.Thank you
Audi A4 ECU
- Car Model: '06 A4 DTM, '07 A4 2.0T
- Membership No: 1622
Re: Audi A4 ECU
where are you based?
