Spark Silver R33 Nissan Skyline GTR - Detailed by Lawrence
- Lord of the Sponge
- Membership No: 1676
A good client of mine recently purchased this vehicle and I was obviously excited to get the opportunity to get her looking better.... I had time on my side (a weekend, the evenings in the week that followed and then that weekend too) but unfortunately there is only so much you can do before a repaint is the only option, and so I was rather disappointed that I couldn't have used that time to better effect.
Some of the car [the driver's side the bootlid and both bumpers] had already been repainted , and as you will see, it was a really bad job.
The polishing job was even worse. Not only were there plenty of sanding marks left for me to remove where the repaint was done, but the same aggressive combo (see pic below of the original repaint/polishing work being done - I just wanna cry) was also used on the rest of the OEM paint...which was much, much softer, and a lot thinner to start with... so the inevitable had happened and there were multiple spots patches where the OEM paint had been polished right through (not hard to imagine with the limited control the tool used below would give) and so this further limited what I was going to be able to do to get the car looking presentable.
So anyway....as always I started with the engine bay, one with no big plastic panels to easily clean and dress - instead just lots of hard to get to places that really don't show as dramatic a before and after as usual.
At this point the left half had been cleaned, mostly just using a steamer that I was trying out (a small Karcher one of a friend's which seemed to work well enough but IMO was too 'small' to handle something like and engine bay efficiently) and some MF towels. The painted surfaces were then sealed using Gyeon Cure.
Here is the bay mostly completed. The painted surfaces on the underside of the bonnet would later be wiped clean with some Carchem APC and MF towels, followed by a damp MF towel and Gyeon Cure. The carpeted cover gently wiped clean with MF towels and Mothers Upholstery Cleaner.
As you can see from the windscreen it was raining, and it pretty much didn't stop the whole time I had the car so there are no pics of the wash/decon stages. The fender liners were cleaned as usual using various brushes, a pressure washer and some Carchem APC. The tyres received the same treatment and were later dressed with Carchem Tyre and Trim Gel. The wheels themselves were about to be replaced so were only given a basic clean using Valet Pro Billberry - no iron or tar removal was performed.
The car itself was then cleaned and decontaminated:
Foam - Turtle Wax Hyperfoam
TFR - Valet Pro Citrus Prewash
2BM - Carchem Luxury Shampoo
Clay - Shield Heavy Duty Clay | ONR
Then it was time to tackle the exhaust tip.
The inside and outside were cleaned using Carchem APC and dried. I then damp sanded using 3000 Trizact discs and followed that with an initial cut using Menzerna Polishing Cream on a (dedicated) Menzerna wool pad on the Flex 3401. This was followed with Mothers Mag and Aluminium Polish on a orange white foam pad on the Shield DA.
The boot was then emptied and unfortunately revealed a bit of a mess.
This was cleaned out as best as possible, but will need to be addressed by the owner.
All the rubbers were cleaned cleaned using Shield Vinyl and Rubber Cleaner and dressed using Carchem Rubber and Vinyl Protectant. The carpeted areas were brushed and vacuumed.
The spare wheel was looking rather sad too
So it got a clean (tested out the steamer again) and I then applied some Carlack Fast Detailer.
This left me with the paint to correct....
Starting with some of the OEM paint
Paint thickness: Min 79µ, Avg 94µ, Max 112µ, Sdev 10.2µ
Taped are ready for polishing
Correction: Flex 3401, Menzerna SF4000, White Lake Country Hybrid pads
Paint thickness: Min 74µ, Avg 88µ, Max 106µ, Sdev 9.4µ
Paint thickness: Min 72µ, Avg 93µ, Max 112µ, Sdev 12.8µ
Similar paint readings were present over the rest of the OEM panels and the same approach was taken to correcting these areas.
I then gave the headlights a quick polish using Menzerna PF2300 on White Lake Country Hybrid pads, wiped them down with Gyeon Prep and applied Optimum Optiseal to them.
And then started tackling the repainted/butchered panels.
Paint thickness: Min 249µ, Avg 437µ, Max 1120µ (yes, that is 1mm of paint ), Sdev 225µ
Correction: Flex 3401, Menzerna FG400 + Orange Lake Country Hybrid pads followed by Menzerna SF4000 + White Lake Country Hybrid pads
The rest of the repainted panels were on average 220µ with a Sdev of 50µ, the exception being the roof which was a bit thinner at Min 100µ, Avg 122µ, Max 146µ, Sdev 14.6µ. The same method of correction was used, except for the driver's side front door which required an initial cut with FG400 and a Foamed Wool pad to get rid of the sanding marks.
Here are a few shots of what I was dealing with...
One example of where he polished through the clear he had just laid down on the bootlid
I don't even know what to say about this
Or this...
This is the condition a repainted bumper was handed back in...it blows my mind
This was during some testing on the front spoiler - eventually settled on Menzerna FG400 on Orange Lake Country Pads followed by Menzerna SF4000 on black Lake Country Pads
The wing before correction
And after
With the paint corrected I applied Meguiars M80 on the repainted panels on the Shield DA using a 6" Menzerna Black pad, and protected the OEM paint using Dodo Juice Iron Gloss Sealant and later topped it with a coat of Chemical Guys Pete's 53.
The rubbers and plastics needed a good cleaning too. Mothers Back to Black Cleaner was used along with the brush that comes in their cleaning kit to do an initial scrub, before they were cleaned with Shield Heavy Duty Vinyl and Rubber Cleaner and protected using Carchem Rubber and Vinyl Protectant.
They mostly looked like this
Obviously the glass was cleaned too, inside and out, using Autoglym Fast Glass and a lot of clean dedicated MF towels.
The badges & emblems were cleaned / polished / protected using Autofinesse Tripple, Q-tips and MF towels.
The interior plastics were cleaned using Carchem APC @ 1:20 and protected using Optimum Optiseal.
The interior carpets were vacuumed, brushed, cleaning using Mothers Upholstery and Carpet Cleaner, then vacuumed again and the seats steam cleaned.
It so happened that there wasn't any time to get the car out for any decent pictures once everything was finished, so the best I have is these 3 of it still in the garage
And these of it I literally took while the owner was driving it out.
Total time spent 39 hours
Thanks for looking and as always, any questions or comments are welcome.
Or this...
And after
- TDISmoker
- Car Make: VAG
- Car Model: 6R GTI | LC
Re: Spark Silver R32 Nissan Skyline GTR - Detailed by Lawren
Blixem, what a turn around.
2018 Toyota Tuna
2014 Polo 6R GTI | Xenons, DRL's | Pano Roof | LED Fogs | LED Interior
2016 Ford Ranger met lekke tekke!
2007 9n3 Sportline 129wkw 445nm
2003 VW Chico
2003 VW Chico
- Colonel
- Car Model: Golf VI R
- Membership No: 2023
Holy fook that's proper sir!!!
- Registered for: 8 years 3 months
Damn! Came out sparkling
2018 Pure White Mk7.5 GTI
2018 Reef Blue Polo Gti
2016 Reflex Silver Polo Gti-Manual
2014 Deep Pearl Black Mk7 GTI
2013 Candy White Polo GTI Revo2
- Kiran
- Thumbie
- Car Model: Golf 1 Citi
- Membership No: 2028
Wow outstanding work yet again LA, great car glad to see it revived
- Car Model: Citi Rox 1.4i
- MouseGTI
- Car Model: B8 2.0Diseasel
Thats an R33
White '07 Polo GTI 9n3 - Stock
Black '07 Polo GTI 9n3 - 113fkw 234nm stock -> 153kw 277nm chooned
Silver '07 Slowdi A4 B7 1.8t - w/ T3T4 powers
Green '16 Kawasaki Z300 - 28kw
Blue '15 Yamaha MT-07 - 55kw
Blue '13 B8.5 A4 2.0TDI - 130kw
- Ghostfacekilla
- Car Model: Golf GTi 7.5
awesome work bud
“It is not by muscle, speed, or physical dexterity that great things are achieved, but by reflection, force of character, and judgment”
CURRENT: GTI MK 7.5
EX: E90 LCI 320d Msport
EX: F20 118i Msport
EX: Polo 1.6 TDI 6R
EX: Polo 1.9 TDI 9n Sportline
PROJECT: MK2 GTI Jumbo
CURRENT: GTI MK 7.5
EX: F20 118i Msport
EX: Polo 1.6 TDI 6R
- crumbs
- Race Chip
- Car Model: Citi Rox 1.6i
- amstel18
- Car Model: Tiguan Allspace
Wass about to comment the same thing.MouseGTI wrote:Thats an R33
But Well done Lawrence! Splendid work as always!
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Re: Spark Silver R33 Nissan Skyline GTR - Detailed by Lawren
Thanks very much for your kind words everyone - much appreciated
- Unobeat
- Car Model: Uno, Auris, CX-5
Outstanding work bro, car looks 100% better.
I am sure the owner could not stop smiling.
- Kyle
- General
- Car Make: Porsche
- Car Model: Adidas TYP 64
- Membership No: 1922
I know what you mean bud, sometimes you have such high hopes, and then you find out you have literally nothing to work with, great rescue either way... looks a whole lot better.
- Uvy
- Registered for: 20 years
- Car Make: VW and Seat
- Car Model: MK2 GTi 16V Golf
- Membership No: 1740
Great work LA. at Least you saving them cars one at a time
Heaven on Earth - VAG for life
takes skill to turn that around. well done dude
- Committee Member
- Car Model: A4 B8 Sooter
*Refrains from commenting on the paintwork*
Nice turn-around
Pity about the damage caused by the painter.
Nice turn-around
Unobeat wrote:Outstanding work bro, car looks 100% better.
Fanatix Boy wrote:Great work LA. at Least you saving them cars one at a time
uzzi777 wrote:takes skill to turn that around. well done dude
Thanks guysGaVeN wrote:*Refrains from commenting on the paintwork*
Nice turn-around
Nicely Done bud
That engine bays looks very scary to spray any water and do a normal engine bay wash ( just in case it doeshnt start again )
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
- Registered for: 9 years 6 months
superb work there bro
- Robz
- Car Model: Polo Classic 20V
- Membership No: 3256
- DrayWolf
- Car Model: "06 Polo Classic 2.0
- Membership No: 3108
Just wow... my car needs some tlc like this though...
Thanks bud - yeah not the kinda engine bay you want to cause any damage in - the steam cleaner came in really handy on this oneRsi huntered wrote:Nicely Done bud
Thank youSolaaris wrote:superb work there bro
ThanksRobz wrote:Looks great! Well done!
Thank youDrayWolf wrote:Just wow... my car needs some tlc like this though...
- Car Make: Honda/Seat
- Car Model: Accord 2.4L/ IC 1.9TDI
Huge turn around job well done sir, reading all your write ups really has got me trying on my own car. I along with alot of people im sure appreciate all the effort you put into your write ups!
Seat IC 1.9 TDI
stage 2, straight pipe, cupra lip,Depo racing 3 bar boost gauge, - His
Honda accord 2.4l old man car - Hers
Polo TDI
40mm evo drop, gti headlights, fmic, 63mm straight s/s pipe, bmc filter, toxic tuning sw, 132wkw 447 nm sold
98 Citi 60/40 drop custom sound install - RIP
Polo TDI
Thank you so much - its really great to know that people are getting some benefit from the write upsTD HIGH wrote:Huge turn around job well done sir, reading all your write ups really has got me trying on my own car. I along with alot of people im sure appreciate all the effort you put into your write ups!
You have no idea how all your write up help and obviously the consistent free info you dish now now and then.....cough....cough.....essays....cough....coughlawrence wrote:Thank you so much - its really great to know that people are getting some benefit from the write upsTD HIGH wrote:Huge turn around job well done sir, reading all your write ups really has got me trying on my own car. I along with alot of people im sure appreciate all the effort you put into your write ups!
I can honeslty say from my side, that i became how i am about my cars is due to reading all your stuff a long .... long time ago which then filtered to looking at you tube videos.... reading here and there.....
I dont think you really know how many people you are really helping or helped in the pass years
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
