Hyundai Getz - By SeventyFourFour
- Committee Member
- Car Model: A4 B8 Sooter
I got this one in to do a full detail on it, as well as a few other things.
This one was my most challenging one yet, patience, combos, care, research, testing tricks etc.
It has spent most of its life outside, from hail to extreme sunlight.
I had worked on this car before (About 2 years ago) where I did a quick pre-wax glaze & wax on the exterior. I kept the amount of correction to a minimum, as it had been polished aggressively before by a bodyshop.
When I got it back again this weekend, the paint was dead & dull. It also got some hail damage from the last summer season, as well as some ugly deep scratching. This will be covered further down.
To tackle:
- Engine oil leak repair
- Cambelt & tensioner replacement
- Runner pulley & ancillary belt replacements
- Engine bay detail
- Remove mags & install steelies, spray OEM wheel caps, and fit wheel caps
- Full exterior detail
- Interior detail
1st night I stripped off the cambelt & replaced that, together with the tensioner. Replaced the runner pulley & all ancillary belts.
Replaced tappet cover gasket which was sweating oil quite badly.
Cleaned engine bay:
- HP rinsed & Foamed with CD Foam cannon
- Carchem citrus APC diluted 1:5, various brushes, agitated
- HP rinsed again & blown dry with compressed air
- Pushed the car to its overnight sleeping spot & left for the whole of the next day to dry completely
- Dressed with Carchem trim & tyre dressing
Before & After:
Following afternoon after work, I climbed into the little car's paintwork. It was extremely dirty, with a lot of bird cr@p & tree sap all over
Process & kit used:
- HP rinse
- Carchem Citrus APC 1/4 & Carchem luxury shampoo 1/4, Warm water 1/2
- CD Foam cannon & left to dwell
- All grills, emblems, joints & jambs agitated with various brushes
- HP rinsed again
- Washed with Carchem luxury shampoo & wash mitt
- HP rinsed again
- Clayed with a medium clay & lots of soapy water
- HP rinsed again & dried with MF towel
- Pulled into the garage & blew out all gaps with compressed air
- Taped-up all black trim & rubbers
- Wet-sanded the headlights with 800, 1000, 1200, 1500, Polished & sealed
- Firm pad, DA, Quick detailer, Shield polishing Glaze (Light-medium compound with a lot of lubrication for the soft paint) to remove the dead oxidised paint, medium pad to smooth over the deep scratching with QD &hield polishing glaze, finished off with finishing pad & pre-wax glaze, Sealed with Colllinite #845 after each panel correction
- HP rinsed, 2BM wash with Carchem luxury shampoo, HP rinsed & dried
- Coated with Collinite #845 again, left to sit for 45 min & buffed off
- Rubbers & trim heated with a heatgun to bring back original natural shine/colour, coated with Turtle wax bumper & trim gel. Buffed off excess with MF Towel
- Windows given a run over with a blade, and finished off with C-Thru
Used the bonnet as a test spot, as it seems to have been polished aggressively before, which I'm guessing was a bodyshop, as the front end & rear bumpers & bonnet had been repsrayed. As you'll see on the bonnet test spot, they had polished through the paint already on the high point of the bonnet. The trim on the bumpers & doors also has a few spots where they ran their polisher over it, and damaged the strips.
After doing a test spot & removing the dead layer of paint, I noticed some extremely deep scratching, which can only be assumed to be from washing the car with a hard bristled broom, or even a scotchbrite scourer. This was present throughout the entire car
The paint is extremely soft, and the care taken on this car was painful & careful. I could not remove the deep scratching completely, as it was too deep. I decided to try get them better, without taking off more paint than was already done.
I used a medium pad, with Shield polishing glaze, & a lot of quick detailer to keep the paint lubricated as much as possible through the correction phase. This of course made a lot of polish sling all over the car, but it got rid of a lot of the scratching & brought back the shine to the paint.
Before & After:
Interior:
- Vacuumed seats, floor & roof lining
- Steam cleaned all the door panels, dash, & other interior bits
- Seats sprayed with an APC solution 1:20, agitated with a brush, Steamed & wiped down with a dry MF towel
- Carpets sprayed with APC 1:5 solution, steamed, agitated, steamed again & dried with a dry MF towel
- Interior dressed with DNA chocolate dressing, left to sit for an hour & excess buffed off with a clean MF towel
- Carpets & seats sprayed with Megs odour eliminator
- Windows wiped off with Megs fast glass on the inside
- Car left to sit in the sun for 4 hours to dry out interior moisture with the windows left open ever so slightly
Before & After:
All-in-all, I was about 25-26 hours in on the little car.
The soft paint was tricky, but with just enough compound & detailer, I managed to almost “move” & even out a lot of the deep scratching & minimising the amount taken off.
To tackle:
- Engine bay detail
- Interior detail
Cleaned engine bay:
Before & After:
Process & kit used:
- HP rinse
- HP rinsed again
- HP rinsed again
Before & After:
Interior:
Before & After:
- Car Make: Mazda
- Car Model: 6 MPS
- Membership No: 1796
Re: Hyundai Getz - By SeventyFourFour
F me, detailed the mags right off that thing.
Looks very good man, well done.
-2011 Audi S3 Sportback
-2004 Ford Ranger 2500D
-2015 KTM 1290 Superduke
-2010 Triumph Street triple
-2008 KTM 690 Enduro
EX Rides:
- 1987 VW Citi Golf - RIP
- 1988 VW Fox
- 2009 NO Limit cg 125
- GoMoto Ballistic naked SI
- Suzuki DRZ400SM
- 2007 VW Polo 1.6 Comfortline
- 1991 MK2 Jetta CLI 20VT
- 2006 Audi A4 Avant S-Line
- 2013 Honda CBR1000RR - RIP
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2008 Suzuki GSX650F
-2007 BMW 335i
-2011 Golf 6 GTI
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
- Car Model: Citi Rox 1.4i
epic one Gaven... The during and after shots of the engine were dead on
Ahmed Syed
- Lord of the Sponge
- Membership No: 1676
Nice turn around bud
- Car Make: BMW
- Car Model: 320D
- Unobeat
- Car Model: Uno, Auris, CX-5
What a transformation, wow
Outstanding work
Outstanding work
- Committee Member
Echo03 wrote:F me, detailed the mags right off that thing.
Thanks guy
Thanks guyAhmed.Syed wrote:epic one Gaven... The during and after shots of the engine were dead on
Thanks guylawrence wrote:Nice turn around bud
Thanks guyCornel wrote:very good work!
Thanks guyUnobeat wrote:What a transformation, wow
Outstanding work
It was pretty messed up, I won't lie
My thoughts exactly
Great work Bud
Tiguan 2018 R-Line
Polo 6C Ex
2004 Golf 1 Baby 1.4i +VAT 76.3 WHP@K.A.R
Polo 2008(9n3)Ex:-(
Golf 1(2 door)branch,exhaust,domingo's,leather seats,electric windows, 2.0L 16v ( sold ) Ex.
Golf 2 2L 16v full house(RIP) Ex
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
- Car Model: Polo HL tsi
Thats impressive
Sent from my LG-H815 using Tapatalk
Current 2009 scirocco 2.0 tsi dsg
Ex 2011 honda civic vxi
Ex 2004 honda civic 170i vtec
Ex 2014 Hyundai grand i10
Ex 2007 corsa lite sport
Ex 2012 chev ute
Ex 2005 Astra coupe turbo
Ex 2012 chev ute
- Car Make: Volkwagen
- Car Model: CW Polo 6R GTi
