Seat Ibiza FR - detailed by Autocare Services
Greetings fellow detailers..
This detail is a special one for me as my work would be entered at an event. The car would be displayed with my branding...
I apologise in advance for the photos.
Now for the detail
***DAY 1***
My starting point
First up...
ENGINE BAY
Side view
Under bonnet
I saw the amount of dirt on top so i decided to remove it(cover) and found this...
dirt, grease, oil, leaves...all were present.
After a few minutes of planning i took note of all the important electrical parts and sensitive areas. I did a test spot on the heaviest stain (above cowling) with apc mixed 10:1 it didn't go the way i wanted so plan b...
*Using foil and packets i covered all the electrical parts. Taped it up to be certain.
*Used a blower to blow any loose dirt
*Sprayed water loosen more dirt
*Sprayed Apc & allowed to dwell then agitated with various brushes.
Too keep the engine as dry as i could i used the blower to remove as much water as i could immediately after spraying. plastics and pipes were dressed and wiped of to leave a factory Fresh look.
End results
From this...
To this..
Now the wheels & arches
Arches / Tyres
Hp rinse
Sprayed Apc allowed to dwell then agitated with Brushes.
Hp rinse
Wheels
Removed centre caps (caps were allowed to soak in another bucket with a cap full of glossworx shampoo to clean up abit)
Hp rinse
Sprayed GlossWorx Wheel & tyre Cleaner.
Allowed to soak
Agitated with brushes
Hp rinse clean
Sprayed Carchems Revolt onto wheel and allowed to dwell.
Agitated with valetpro detail brush
Hp rinse
The Body
I started with the door jams
Rinse
Sprayed Apc & allowed to dwell.
Agitated with valetpro detail brush.
Rinse clean
Hp rinse the body
First foaming using GlossWorx Shampoo
Allowed to break up some stubborn dirt
While the shampoo was allowed to dwell i brushed the grills, seams , around the windows & badges...
Decontamination process part 1
Iron...Sprayed Carchems Revolt over the entire car generously and didnt expect this much contamination
Hp rinse
Car was washed using 2bm.
Hp rinsed
Dryed using Crazy Detailer wafel weave drying towel with GlossWorx speed detailer as lubrication.
Decontamination process part 2
Clay - Shield
Lubrication - GlossWorx Speed Detailer
The baggie test
Extremely contaminated I would compare the surface to 600 grit sand paper.
I inspected the clay after the first few passes on the hood.
DAY 2 - Polishing
Machine - Shield da
Compound - Meguiars Ultimate Compound
Pad - Crazy detailer orange compounding
Before
After
Taped up edges, handles, plastics etc
Close up shots of the paint
It was very difficult for me to capture proper before and after shots of the paint.
End of day 2
All polishing completed and the car was protected by a layer of Smartwax sealant...
Decals installed
Pics removed by admin (check the website's advertising section)
DAY 3 (The details)
Badges
Before
Close up
After
Product - Meguiars cleaner wax
Tool - Ear bud
It made such a difference to the car in my opinion having all the badges cleaned...
Exhaust tips
Cleaning
Product - Carchems Apc (10:1)
Tool - tooth brush (its not only the dentists choice )
Sprayed Apc and allowed to dwell
Agitated with brush
Wiped with Microfibre cloth
Polishing
Product - Meguiars Metal polish
Tool - Polishing cone attached to cordless drill (energy levels were depleted and customer was on his way to fetch the vehicle @ 08:30)
Plastic trim
Cleaned using sheild rubber cleaner
Dressed using GlossWorx Silky shine dressing
Around trims were cleaned with Megs and a ear bud.
Before customer could fetch the vehicle i waxed using GlossWorx Carnauba wax & before customer could leave i misted GlossWorx speed detailer just to give it that extra shine.
After photos...
At the event
Thank you guys for taking the time to read my post. Any questions or comments are welcome. Take Care guys
Now for the detail
***DAY 1***
My starting point
First up...
ENGINE BAY
Side view
Under bonnet
End results
From this...
To this..
Arches / Tyres
Hp rinse
Hp rinse
Wheels
Hp rinse
Allowed to soak
Hp rinse clean
Hp rinse
The Body
Rinse
Rinse clean
Hp rinse the body
Hp rinse
Hp rinsed
Clay - Shield
The baggie test
DAY 2 - Polishing
Machine - Shield da
Before
After
End of day 2
Decals installed
DAY 3 (The details)
Badges
Before
Close up
After
Tool - Ear bud
Exhaust tips
Cleaning
Agitated with brush
Polishing
Plastic trim
After photos...
At the event
- Registered for: 11 years
- Car Make: Honda/Seat
- Car Model: Accord 2.4L/ IC 1.9TDI
Re: Seat Ibiza FR - detailed by Autocare Services
Nice turn around bud hopefully it never gets back to the state it was in
Seat IC 1.9 TDI
stage 2, straight pipe, cupra lip,Depo racing 3 bar boost gauge, - His
Honda accord 2.4l old man car - Hers
Polo TDI
40mm evo drop, gti headlights, fmic, 63mm straight s/s pipe, bmc filter, toxic tuning sw, 132wkw 447 nm sold
98 Citi 60/40 drop custom sound install - RIP
Polo TDI
Thank you brother. honestly i hope so too but he is a busy guy so im hoping so i get his vehicle on a maintenance detail to keep it looking fresh.
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
What a transformation, outstanding work.
Owner must have fallen inlove again with the car.
I am sure you have educated the owner about taking better care of the car.
Thank you brother
Yes i did, ive explained the damages the local car wash does and the basics on how to care for his vehicle.
- REVV - ZN
- Car Model: 2016 Golf 7R
What a difference...Awesome job bud
Thank you brothers
- Registered for: 8 years 3 months
- Car Model: MK2 GTI. MK5 GTI
What a turnaround. Great work.
Thank you brother
- Lord of the Sponge
- Membership No: 1676
Nice work Carl. I am sure the owner appreciates the effort you put into get his car looking so much better
- Uvy
- Car Make: VW and Seat
- Car Model: MK2 GTi 16V Golf
- Membership No: 1740
Well done buddy.
Question though regarding below. Why do you need lubrication when drying.
"Dryed using Crazy Detailer wafel weave drying towel with GlossWorx speed detailer as lubrication."
Heaven on Earth - VAG for life
This is something I ALWAYS do....and so should anyone drying their car too... I'm sure I've discussed it before but nonetheless, the idea is really quite simple...Fanatix Boy wrote:Well done buddy.
After washing your car you rinse off the shampoo and this will leave some of the paint wet and some dry. If you were to then take a dry drying towel (be it waffle weave or straight microfiber) and use that to dry the car, you would, in some places anyway, have a dry towel in contact with dry paint. This, combined with any possible light dust in the air (which will present unless you wash your car in a hermetically sealed environment) increases the chance of the towel causing scratches during drying.
By spraying the car in some quick detailer / drying aid (pretty much the same thing), you add in some lubrication which allows the towel to glide over the paint while it sucks up water and qd off the paint surface - its sort of like why you need lube when claying, albeit that the chance of marring is much less with a drying towel compared to clay.
Of course, most QD's or drying aids are by their nature hydrophobic, and so they will tend to 'push' some of the remaining water off the car on their own too, making drying that little bit easier, and should also help with any potential spotting or streaking.
Over time, this small change in drying methods will greatly reduce the build up of swirls, resulting in more shine for longer and less paint removal required.
- Unobeat
Thanks for a detailed explanation brolawrence wrote:This is something I ALWAYS do....and so should anyone drying their car too... I'm sure I've discussed it before but nonetheless, the idea is really quite simple...Fanatix Boy wrote:Well done buddy.
if i could add..... may help may not help (but this is what i do).Unobeat wrote:Thanks for a detailed explanation brolawrence wrote:This is something I ALWAYS do....and so should anyone drying their car too... I'm sure I've discussed it before but nonetheless, the idea is really quite simple...Fanatix Boy wrote:Well done buddy.
when i nearly completed washing the car and about 5mins before i can start drying..... i spray my drying towel a lubricant so it get absorbed onto the cloth, taking the dry effect out and i spray on the panels i im going to wipe as well.
Nicely Done CARL
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
Thank you brothers. I really do appreciate it alot.
Thank you lawrence for the explanation, i couldn't of said it so good. Your knowledge of detailing is quite remarkable. Thank you.
- Uvy
Thank you LA.. much appreciated.. I shall add this to my drying routine
- Car Make: Volkwagen
- Car Model: CW Polo 6R GTi
Great work there bud, that engine bay transformation is awesome!
