Page 39 of 44
Posted: Mon Jan 11, 2016 4:26 pm
by Djin
Rsi huntered wrote:this was how it was coming on the rim when i did it..... i took the photo and removed it immediately.....
but the end product came out good :lol:
Hi Bud
It seems like the product was not shaken properly. Did you shake before use?
The CarChem iron remover does separate when standing for more than 3 hours, so its highly recommended to shake well before use.
Car is looking good btw :hurray:
Posted: Mon Jan 11, 2016 8:42 pm
by Rsi huntered
Hi Bud
ahhhh! . ..... that could be the problem cause I didn't shake it at all :grin:
I also used bought the turtle wax exterior plastic solution and used it...... Very good product
and the optimum spray wax :hurray: this is going to be my new go to protection going forward..... The results of this product is just amazing ( thanks to Lawrence for the heads up on the product :thumbup: )
and thanks for the compliment Pravin :hug: I'm loving that wet look on the cars :drool: 18 hours well spent :grin:
Posted: Tue Jan 12, 2016 9:39 am
by lawrence
NHB_R wrote:Question
Can i buff polish/wax off using the shield da polish machine?
Or only by hand?
If it can be done by machine too, what pads should be used?
Sent from my  iPhone
Just want to try clear up something....
There is a fundamental difference between polishing and waxing.
Polishing is the act of rubbing something abrasive over your paint, in order to 'sand' the paint smooth again, thus increasing its shine.
Waxing is the act of applying a NON-abrasive product onto your paint to protect it.
So, when polishing, you can do it by hand, by dual action machine or by rotary.... with each step getting progressively more aggressive.... in other words, to polish (sand your paint) by machine requires less elbow grease than by hand. On most modern clear coated vehicles to polish paint by hand is not very efficient, due to how 'hard' the clear coat is. When polishing, you apply some product, work it over the paint, and wipe off any excess polish - you don't 'buff it to a high shine' - the shine comes from having leveled the paint.
When waxing, you can apply the product by hand or machine, and in most scenarios, it is easier to spread a thin uniform layer oover the paint by machine. You would then wait for it to haze up, and then buff off any excess residue.... personally, I would still use a decent quality MF towel by hand to remove any wax residue, regardless of how it was applied (hand or machine) as you are better able to control removing all the wax residue from the paint.
Posted: Tue Jan 12, 2016 9:43 am
by lawrence
Hi Bud
I agree with Pravin - the car is looking good :thumbup:
Glad you like the Optimum Spray Wax - its so easy to use and works as advertised.
You should try and get into the habit of always shaking all of your detailing products prior to use - this would definitely have effected how the iron remover worked. Also, out of interest, what sort of quantity did you use - if you sprayed it on too thin, it would also have dried out too quickly.
Factors that will effect how quickly a product dried out are:
-ambient temp
-ambient humidity
-wind speed around the car
-panel surface temp
-how much product you use
Posted: Tue Jan 12, 2016 10:14 am
by Rsi huntered
-ambient temp was about 8:15 in the morning so i would say about 28%
-ambient humidity Eish :fear: not to sure but in the shade it felt cool and not humid
-wind speed around the carvery mild
-panel surface tempthis was cool as i just moved it from the garage, wahsed and dried, then used the Revolt
-how much product you useopened the nozzle for fine spray, and sprayed about 2/3 times before moving slightly
will get into the habit, i always shake my products but didn't know i had to do the same to Iron out (you learn something new everyday)
Just a question on the Optimium spray wax (after how many wash's would you say this needs to be used?)
Posted: Sun Jan 17, 2016 10:51 am
by jippo
So after reading Lawrence's Aventador post I was curious about wheel cleaning.
The wheels and tires are cleaned and dressed before the car is washed. Won't the soap and water affect the finish on the tyres?
Posted: Sun Jan 17, 2016 11:32 am
by lawrence
jippo wrote:So after reading Lawrence's Aventador post I was curious about wheel cleaning.
Hi bud
I washed the wheels before the car and dressed the tires later once the car was back in the garage.
Sorry if it wasn't clear in the write up
Posted: Mon Jan 18, 2016 7:32 am
by jippo
Hi bud
Makes sense :lol:
Posted: Wed Feb 03, 2016 3:35 pm
by GaVeN
Detailing guys, need some advice here (Might have been discussed somewhere in the 39 pages, but I'll be damned if I'm going to read through all of that, off topic posts and debates to find it, so if it has been posted/discussed, point me there please)
I do my fair bit of detailing, paint correction etc. so I'm not completely useless (doing painting etc.)
My question comes to a long lasting coating I can apply, that can help with some longevity.
The waxes after some paint correction/"top-up" care just does not seem to keep that beading effect after say 5-6 washes.
I wash with decent wash & wax, do the quick detailer whilst drying but it feels that the waxes don't last very long.
I have seen a lot of ceramic coatings that repel water amazingly, and read up on a few other products.
What can you guys recommend to try out? Gyeon Q2m seems to be an extremely good product for what I want.
Now, there is different products, for different steps(As I understand them).
Gyeon Q2m cure: For a quick way to protect for a good finish without full correction.
Gyeon Q2m prime: For protection after correction to provide the finish I'm after
Gyeon Q2m MOHS: Hard coating, that gives optimum protection, and has the best water repelant features.
Would I have to do the Prime, and then MOHS, or can MOHS be done after correction?
Would there be a need for a wax after correction, the Q2m, or can I apply straight after correction?
Any other similar products? Experience with something like this? Any do's/don'ts?
Posted: Fri Feb 05, 2016 11:37 am
by lawrence
Um..... go grab some coffee....
:lol: :troll:
GaVeN wrote:My question comes to a long lasting coating I can apply, that can help with some longevity.
Yes there are. And I will try give you my opinion on them.
But first, a couple of principals that I think are important for anyone reading this to get their head around.
1. Using beading as an indicator of protection
Whilst most people (us detailers included) use beading as an indicator of the presence of some form of LSP (Last Step Protection AKA a wax, sealant or coating), it is not really a true indicator on its own. By altering the contact angle made by a water droplet on the paint, you can get the water to roll up into beads, or to instead sheet off the car. So you could have a LSP designed to sheet, that then appears to be 'not doing its job' in comparison to a wax with excellent beading. But if your chosen LSP exhibits certain properties upon application [like good beading] and and these then change, it is the most 'simple' trigger to use when deciding when to reapply. And everyone who claims to use some form of dishwashing liquid to 'strip' the wax of a car, is being fooled by the residual surfactants in the dishwashing liquid creating a sheeting effect on the paint, much as it was designed to do on your dishes to prevent soapy water sticking (a quick wipe with something like IPA over the area you had supposedly stripped would restore the beading).
Also, remember completely clean paint (I mean like no nothing on it) will bead water too.
2. Above and below surface defects will negatively affect beading
Imagine looking at a magnified cross section of your paint. If it was perfectly flat _______ water will more easily roll up into a bead on the surface.... but if you paint is rough ---v--^---^-^^^^ this is harder. So, any contamination on the paint needs to come off, and once any swirls etc are removed, the effective beading ability of the LSP would be better.
3. Above and below surface defects will negatively affect the longevity of your LSP
Simply put, the LSP is designed to bond to your PAINT not embedded brake dust/paint overspray/tree sap/tar etc.
4. Water behavior is determined by the top 'layer' of LSP
If you were to apply some LSP to your paint and then at some point topped that with another LSP (e.g. sealant topped with a wax) then the water behavior (beading, sheeting, self-cleaning, hydrophobicity whatever you want to call it) you see will be that of the top layer.
5. Different LSP's will each have their own characteristics:
And this is where the waters can get very muddied. In my opinion, there is no right answer, only an answer that is right for you.
So, the characteristics...
Firstly, like I said, the waters are very muddied both by manufacturers marketing tactics creating confusing product descriptions, and the incorrect terminology unwittingly thrown about by the common car owner so first and foremost, you need to know what the actual product is. For example, Meguiars Cleaner Wax is not something you apply for protection only - it has abrasives in it that you don't want to use often, and yes, there is some (albeit not very durable) protection in there too. Soft 99 have a product called Fusso Coat, which implies a 'coating' (like the Gyeon stuff you are asking about) but its actually PTFE based sealant and on their website they refer to it as a hard paste wax. They claim 12 months, but on daily driver in our country you'd probably see 4 to 5. Most spray waxes don't actually contain appreciable amounts of wax - Optimum spray wax does.
Looks - beauty is in the eye of the beholder, and in the bigger picture of things, the influence the LSP has on the overall gloss of a car is minute, compared to properly prepping the paint (decon/polish), so personally this is one area I don't think warrants much contemplation.
Longevity - generally speaking you can say that waxes will last the least amount of time, sealants longer, and coatings the longest. But you do get waxes that outlast sealants and sealants that outlast coatings. There are marketing claims which are not always true on our climate. As mentioned above, contamination will influence longevity, as will 'topping' one product with another.
Application method - This will weigh in differently for different people. So find a method that works for you , so that you keep up with it. A couple of examples of the different ways you can get protection on the paint.
-Liquid wax or sealant that you apply with a foam applicator
-Spray wax or sealant you apply with a MF towel
-Spray sealant you spray on and pressure rinse off
-Paste wax sealant that you apply with a foam applicator
-Paste sealant sealant that you apply with a foam applicator
-Coatings applied with suede applicators
Ease of application
-Paint surface prep can go from almost nothing (wash, apply wax) to a lot (wash, decon, correct paint, paint cleaner [some coatings require specific products to be used), and this can dramatically influence your budget, both in terms of time and cost.
-WOWO (wipe on, wipe off) generally with a 'setting up time' in before wiping off. This time can vary dramatically from seconds to close on an hour.
-WOWA (wipe on, walk away). Quick and easy
-SOWA (Spray on, walk away) - something like Gyeon Wetcoat which is awesome for wheels with complicated designs
Does the product have any specific requirements like a min/max temp for application (more so with coatings), does it need special processes thereafter (such as curing with infrared lights in the case of some coatings), how quickly (in the case of coatings) must high spots be leveled off?
All will have their own 'rules' around how much time needs to pass before it can get wet, which you have to factor into 'ease of use'.
Ease of re-application
If for whatever reason (let's say you are 18 months down the road and need to polish the car) you need to remove your LSP and re-apply it, then it is easier to do with a wax or sealant, than it is to do with a coating, which would need to be polished off completely and re-applied at considerable cost.
Cost of protection
Don't shop based purely on the lable price.... work out how much product you use per application, and how long each application lasts, so that you can work out a cost of protecting your car for the year. Remember too that you need to factor in the prep that is required prior to application, and the cost of re-application when looking at this.
Frequency of application
Some guys ( :hi: Zubair) are waxaholics and enjoy frequently caressing their paint with their latest acquisition....others simply don't have the time.... so again, find something that works for you.... just remember the longer you go between applications the more contamination you will get, and there more chance there is for swirls to develop in the paint necessitating correction, so you need to find a balance.
Etching resistance
Each product will have its own capacity to resist etching from bird crap, tree sap, and even water. There are no hard and fast 'rules' but again generally speaking waxes<sealants<coatings, but not always - for example, water spots are a real concern for coated cars, even leading to the advent of special 'water spot prevention products'... Decide how important it is to you (do you park next to a sprinkler, under a tree, is you tap water hard or soft etc)
Scratch resistance
Again a widely debated topic. I'd say that some coatings may improve the scratch resistance of some (very soft) paints, but would wager that when applied to an already 'hard' paint (like Mercedes cerami-clear) it will be a moot point. At the end of the day, waxes, sealants and coatings ALL require proper 'maintenance' methods and after roughly a 2 year period, all will be similarly 'scratched'. A coated car, washed incorrectly, could easily look terrible long before a waxed car that is looked after properly. This here should put scratch resistance into perspective http://www.autopia.org/forums/autopia-d ... tance.html
Filling ability
Some products are designed to fill any below surface defects (swirls, scratches, etching etc) more than others. If your paint is prepped properly (i.e. polished) this become somewhat of a moot point.
Enjoyment factor
Some LSP's smell so nice you want to eat them, and other stink. Some are easy to use and some difficult. Some can't be used in the sun (and maybe you don't own a garage) so all of these things will influence how enjoyable it is to use, and if you don't enjoy using the product, you are not going to use it often....meaning the car will probably go with no LSP on it, which is not good.
Street Cred
Yip, its a thing... some associate the cost of high end waxes with their effectiveness, and so the more it cost, the better it must be, right? Like Swissvax's Crystal Rock at around roughly R18K per 200ml - there is no way I can accept that a R600 tub (300ml nogal) of say Collinite 915 is 30 times less 'effective' and so often you pay more for the street cred a product has, not its actual benefit. Using the latest stuff on the market is also very important to some, but there remain tried and tested products that have stood the test of time, which can be just as effective.
GaVeN wrote:The waxes after some paint correction/"top-up" care just does not seem to keep that beading effect after say 5-6 washes
Perhaps I am misunderstanding this, but if you do any form of paint correction (abrasive polishing) there will be NO wax or sealant left on the paint, hence no beading.
If you are only getting 5 or 6 washes (assuming weekly washing, and without abrading the paint, just washing) then I'd be interested to know what LSP you are currently using.
There are quite a few waxes and sealants locally that should have no problem getting you 20 washes to 40 washes. But prep (decon [and if required] polish, proper chemical clean of paint to remove oils [IPA or similar] in the case of sealants) is definitely important.
GaVeN wrote:I have seen a lot of ceramic coatings that repel water amazingly, and read up on a few other products.
Yes you get ceramic (silica or sometimes called 'glass') based coatings, some use polymer based resins, like Opticoat, and some are simply marketed as a coating, when in fact they are simply just sealants. In terms of their hydrophobic properties, again generally speaking, coatings are superior to waxes and sealants, but as already mentioned this is not always the case - for example, Fusso Coat (a wax or sealant, not a true coating) beads like a mofo, Sonax's Polymer Net Shield (a sealant) beads just as ridiculously as some coatings) and, bear in mind that as already mentioned, beading is not necessarily a good thing (water spots).
GaVeN wrote:What can you guys recommend to try out? Gyeon Q2m seems to be an extremely good product for what I want.
I haven't yet used a Gyeon product I didn't like
Cure is more the 'maintenance topper' for an existing coating, than it is a coating itself. So every now and then you wash and apply Cure to an already coated vehicle. On its own, it will fare no better than most other spray sealants.
Prime is a quarts/silica based coating which would be a good candidate for you which *may* last up to 12 months - cost is around R800, and temps must be below 30 during application,
Mohs is the big gun in their range, and touts a 9 on the MOHS scale, but I personally think that is a load of crap - 9 on the pencil test, sure.... but no on the MOHS scale, or it would make it harder than tungsten carbide meaning you could try scratch the coating with a tungsten carbide rod and nothing would happen to it.... just doesn't seem possible to me, but I may be wrong. Cost is closer to R1k and should see more than 1 year in durability.
Your prep for either Prime or Mohs, would be wash, decon, correct the paint (there is no point applying a coating to swirled out paint as you will effectively be 'trapping the swirls' under the coating, with no way of fixing them during the life of the coating), and then a wipe down with Gyeon Prep.
So at the end of the day, we go full circle and I'll repeat what I said.... there is no right product, only a product that is right for you. My guess is you could drastically improve your current durability by using a product such as one of the Collinite waxes, a Sealant like Menerna Powerlock, Sonax PNS or Dodo Juice Iron Gloss, at a fraction of what a coating would cost you, but, should you decide that a coating is right for you, then by all means, coat away.
Lastly, here are a few more threads touching on coatings, which may be worthwhile reading, if you have any desire to read any more after by long response :lol:
http://www.vwclub.co.za/forum/viewtopic ... 0&t=184602
An extract below
lawrence wrote:OK so let me preface this post by saying I am offering my opinions and am not looking to 'knock' anyone else's.... these are my view points on coatings, as anyone of my previous customers' will attest to - it is pretty much the same conversation I would have had with them regarding coatings during our 'pre-detail' chat.....
Kyle wrote:
lawrence wrote:
Kyle wrote:But - I honestly do believe that coatings are the future.
Going through international threads, they hardly ever talk about applying sealants...
I would say that if/when the price drops to something more easily swallowed by our detailing market, then yes coatings may be more common than say hybrids or sealants, but I don't think they will ever replace them completely.... Also, they are not some magic bullet that means you no longer need to maintain your paint properly.... so as always, customer education is key if you truly want to 'do right' by the customer....
The water becomes very muddied when you have people promoting a coating as a 'maintenance free' invisible shield that will protect your paint from acid rain etc etc
Gyeon quartz is R795, and that is enough for two cars, which ive personally tested and proven. Yes it is more expensive than using a normal sealant, but more than a year later and it's still on my paint :hi: (Daily driven, parked outside in the sun/rain during the day at work)
I know you don't like the idea of a coating, but if you can offer someone superior protection, then why not?
I apply a wax over it for a little bit of extra shine, it's quite common practice :hi:
Cost per month of protection.
Gyeon Quartz R795 a bottle, 2 cars per bottle, R397.50/application. Let's work on the 12 months durability you have gotten (which is pretty much what the manufacturer claims) so that is
R33.12/month to protect.
Now compare that to Collinte 845. Its cost R250 for 473ml and (this is open to debate, so we can tweak the numbers if need be) I reckon at most you would use 25ml per application. So that is 18.92 application per car, or R13.21/application. This won't last you a year though.... but it should easily last 4 months (I have seen longer, but let's err on the side of caution)... so you will need 3 applications per year equating to R39.64 or
R3.30/month to protect
And this assumes that the detailer 'sells' the coating to the consumer at cost - the likelihood of that happening are open to debate. Of course then there is the application time that the detailer will charge, which will push the cost per application up significantly. So, if I was the consumer, to get 10 times the amount of money out of my pocket (probably more like 20 times once the application cost from the detailer is included), there has to be real VALUE in the coating.... where could that value come from?
Protective abilities?
A coating - has the capability to provide a harder (more scratch resistant) surface than some OEM paint jobs.....for example, if I owned a Subaru.... I'd probably coat it as they are notoriously soft and scratch if you look at them funny.....If I owned a Mercedes with their Cerami-clear clear coat, the increased scratch resistance becomes more of a moot point. And even more of a moot point if you actually look after your car (in terms of washing/drying) anyway.... see 'Maintenance' below.
There is no way that a - let's call it a 'wax' (what most people think of as 'carnuba or 'show car wax' or a 'boutique wax, but in reality is actually in this day and age is actually probably a hybrid - i.e. blend of 'wax' and 'sealant') - is going to offer more scratch resistance than a coating. Same for a sealant. The coating wins, hands down...
When it comes to its ability to protect from other hazards such as bird bombs, etching, chemical crap and things like (overseas) road salt etc...things like the Collinite range will come damn close at an absolute fraction of the price.
Self-cleaning abilities?
Generally speaking coatings, due to their highly hydrophobic nature, will tend to win here. There are however some LSP's such as Sonax PNS, Soft 99 Fusso, that offer ridiculously great water behavior so perhaps the coating is the winner, but not at a ratio of 1:10
Maintenance?
Coatings still need to be maintained - i.e. to have 'boosters' applied to them, which adds to the cost... You will still need to wash the car gently with decent tools and products, but you will often hear how the consumer is told 'this coating is a permanent barrier for your paint and you can wash it with sandpaper'<-- or course I am exaggerating but you get the idea....it still needs to be cared for.
Looks?
Again this is so subjective and unless you are entering a show n shine competition, in my opinion, is the least important quality to me of ANY LSP.... because the LSP is.... the.... last step PROTECTION.
But, you will hear that some provide a very glassy look, some like Modesta are raved about in terms of that wet look (but then we are not talking R400/application) some darken paint, some look like unicorns tears....blah blah blah.... beauty is in the eye of the beholder.... all I do know is if you are having to top your coating to improve the look of it, at the expense of its self cleaning abilities, you are negating the '10 times cost outlay'. Rather just find a 'beauty wax' at a fraction of the price.
Ease of 'repairs' to the paint?
Wanna fix anything on the paint the coating within the year that it is holding up, it has to be polished off - this will be more costly than polishing off a coat of wax/sealant and re-applying.
At the end of it's 1 year life cycle, the coating will need to be polished off to be re-applied. This means either the owner needs to invest in the time/tools/equipment to DIY it, or, he has to pay a detailer to do it for him. At the end of the 1 year, you could just re-apply another coat of 845. The coating loses IMO as the problem is exacerbated by coatings that tout 2 or more years worth of protection, as by that time, you car WILL need to be polished (I would think at least by the end of year 2, even the most careful of washing will result in enough wash marring / swirls etc that a polish is required) and at that point you simply polish off whatever protection the coating may have offered in years 3 or 4....
So ja, to summarize.... I still maintain that there is a very small market for coatings, even more so in the detailing climate that is South Africa.
Lambchop wrote:If you a detailer charging clients and you not offering coatings as an added option then you behind the times
How so.... I think if you are simply punting coatings because they are the 'latest greatest' thing (and I am not saying you are - we are taking 'in general') then you would be doing your customer a disservice by giving them something they don't necessarily need - they may, in which case, coat away....
Would I coat a customers car if that is what they wanted - of course. But with all of my customers, I try and guide them on how to best spend their money to get and keep their car looking how they want it to.... most of them do not see the ten or twentyfold increase in cost as 'money well spent'.... But hell, most people don't see the value in a detail, never mind a coating..... so like I said earlier, until the market is ready for it.... I don't think coatings are 'it'.....
Lambchop wrote:I seriously don't have time to wax my car every 2-3 weeks.
I don't even wash my own daily drive that often.... :lol:
A wax that only got me 2 or 3 weeks of durability would have no place in my garage that's for sure!!!!!
Perhaps you should try some Collinite :grin:
:troll:
Lambchop wrote:I find this forum very one sided when it comes to products .... As the saying goes. Don't mock it till you have tried it ..
I have to disagree.... here is a thread about Collinite, DNA have some testing going on for their range (and all the review seems to be honest and unbiased), Solo is selling Gyeon stuff, Autofinesse are a sponsor selling their range, as are Crazy Detailer, who as you know are all about 'variety'. All of the detailers use all kinds of products....
:cool:
:hi:
http://www.vwclub.co.za/forum/viewtopic ... 0&t=190224
http://www.vwclub.co.za/forum/viewtopic ... 0&t=186616
Shout back if you have any more questions :thumbup:
Posted: Tue Feb 09, 2016 9:23 pm
by Rsi huntered
Howzit guys.....
What metal product would you suggest using on an Harley Bike......
There is alot of chrome and less paint.
any suggestions in something decent.
Posted: Wed Feb 10, 2016 8:38 am
by lawrence
Rsi huntered wrote:Howzit guys.....
You can look at any of the options at Crazy Detailer http://www.crazydetailer.co.za/index.ph ... kmdjj47011 Of the ones available, I have used the Mothers Power Metal which is really great as well as the Menzerna Polishing Cream (which is more aggressive than the Mothers option). I have not used the Autoglym stuff.
Or you can look at Pristine Detailing. http://www.pristinedetailing.co.za/meta ... xhtml.html I have not tried the M1 polish they have.
Another option which is readily available at places like Game/Builders Warehouse/Makro/Midas etc is Meguiars NXT All Metal Polish
And lastly Autosol works pretty well too.
:thumbup:
Posted: Wed Feb 10, 2016 10:53 am
by Rsi huntered
:thumbup:
thanks Lawrence..... will try out the option one above :thumbup: also need to stock up on Shampoo to will get this stuff ontime :cool:
Posted: Wed Feb 10, 2016 1:30 pm
by Kyle
Been using the menzerna metal polish for a while, stuffs magic.
Posted: Fri Feb 19, 2016 9:55 am
by Kyle
Posted: Mon Feb 29, 2016 10:21 am
by Rsi huntered
Hi Guys,
So ever since Lawrence advised on Optimum Spray wax i have bought and started using it after every wash on both my cars and it never ceases to amaze with the finish even after a drive through the rain :grin:
what i need to know :
Not sure about the longevity, and when i need to top up my sealant (PL) how would it bond with this wax due to it still being on my paint(is you understand what i mean?)
Will Power Lock still bond with my paint or will i have to stop using the Optimum Spray wax couple of week before i use the PL again (hoping i dont have to stop using the spray wax cause i become paranoid every since i started using it :lol: , if i dont :grin: )
thanks :hug:
Posted: Mon Feb 29, 2016 11:34 am
by lawrence
Hey bud - glad you enjoying the Optimum Spray Wax :thumbup:
The waters can get muddied very quickly when it comes to layering LSP's on top of each other....
Generally speaking the guidance is put a sealant on bare paint so it can properly BOND to the paint, then put a wax on top of that as the wax rather SITS ON the previous layer (be it bare paint, or a sealant).
In other words, in theory, you wouldn't put a sealant over a wax, as the sealant would not be able to BOND to the wax
So.... some possible options...
Wax straight onto paint
Top with more wax
Glaze onto paint
Top with a wax (as long as a) the solvents in the wax don't strip off the glaze and b) the glaze is designed to be topped)
Sealant on to bare paisnt (i.e. you would use something like Gyeon Prep/IPA/Menz Top Inspection to chemically strip the paint of everything, including polishing oils)
Sealant on to bare paint
Top with a wax (after allowing the sealant sufficient time to properly cross-link [typically 12 hours]
But, you must remember that various products from different brands may not necessarily 'play' nicely together, and so one layer wipes out the previous.... and conversely, there are some sealants, that CAN be used over a wax.... its all very confusing I know :crazy:
But..... for the most part, if you lay down a coat of sealant on bare paint (clayed, free of polishing oils etc), allow enough time for the polymers to cross link (12 hours) then top it with wax, then you can just keep topping up the wax without having to re-strip.
Here are a few articles worth reading over
http://www.autogeekonline.net/forum/hot ... nding.html
http://www.autogeekonline.net/forum/how ... pping.html
http://www.autogeekonline.net/forum/hot ... -last.html
http://www.autogeekonline.net/forum/hot ... alant.html
If I were you I would simply just keep using the Optimum Spray Wax until you are ready to clay the car again. Then, once you have clayed, use a decent paint cleaner (like the aforementioned Prep/Top Inspection etc) to ensure the paint is perfectly clean, re-apply some PL, then the following week, at the first wash, dry and then top with Optimum Spray Wax.
Posted: Tue Mar 01, 2016 9:11 am
by Rsi huntered
Thanks Lawrence for the info :hug: read the first one and some good info was given such a long time ago 2011 :eek:
Eish if i clay then i will need to polish again :cry:
Posted: Tue Mar 01, 2016 12:58 pm
by Rsi huntered
Hi Lawrence,
posting this here instead of derailing the Detailing Products & Equipment Sale/Swop/Trade Thread.
Please could you explain a little on the below highlighted portion, why would you need more pads for the doors as opposed to the roof and trunk?
The distance should be more on the roof an trunk VS the doors correct OR is this due to flat surface vs edgy/curved surfaces?
Correction step = 6 pads
1 for the hood
1 for the roof and trunk lid
2 for driver's side
2 for passenger side
Polishing step = 4 pads (You could probably get away with 3 if you use 1 for hood, roof and trunk lid)
1 for the hood
1 for driver's side
1 for passenger side
Posted: Tue Mar 01, 2016 1:24 pm
by lawrence
Well Mike's suggestion of 6 pads is broken down as:
1 for the bonnet
1 for the roof and boot lid
2 for driver's side - i.e. 1 for driver's front door and front fender, and one for driver's side rear door and rear fender
2 for passenger side - i.e. 1 for passenger's front door and front fender, and one for passenger's side rear door and rear fender
Make sense?
Remember its about the AREA you can cover with 1 pad....so he has tried to break the car up into 6 equal sized areas (very roughly of course), and it doesn't necessarily take into account the different sized (diameter) pads you will need (which will be determined by the shape of the panel - concave panels don't allow larger diameter pads to make contact with all the paint properly, an A-pillar is very difficult to polish with a large pad, a front bumper has to many sharp body lines to efficiently polish it without running over these raised edges etc etc).
The more work you try make the pad do, the more heat builds up, the more polish will 'clump together', exacerbating the heat issue, and it spirals out of control until the foam pad separates from its velcro backing, rendering it useless.... and of course, all the while the finish you get with the pad gets worse and worse as more 'residue' [spent polishing oils/lubricants and abraded paint] scours the paint....
Posted: Tue Mar 01, 2016 2:02 pm
by Rsi huntered
lawrence wrote:Well Mike's suggestion of 6 pads is broken down as:
1 for the bonnet
Make sense?
Thanks alot.......got it..... i read it as only for the door.....
Need to stock up on pads :grin: generally try and stock up on 1 or 2 per month (this time went to crazy detailer to stock on pads and ended buying the Dayotona wheel brush..... what a good investment opposed to the shield one i had)
Posted: Sun Mar 06, 2016 10:40 pm
by iLy
Anyone know where I could get Shield Heavy Duty vinyl and plastic cleaner from here in Cape Town?
Posted: Mon Mar 07, 2016 10:50 am
by Lambchop
:troll:
:cool:
:hi:[/quote]
Happy to see you still think of me Lawrence :)
Posted: Mon Mar 07, 2016 7:16 pm
by mikhail117
:troll:
:cool:
:hi:
Happy to see you still think of me Lawrence :)[/quote]
Hey bud, your rebuttals are all valid. LSP's are very subjective topic and detailers all have their preference. I'm confused to the posts you quoted though because it says you're quoting yourself and then replying to that?
Anyway, glad you back bud, haven't seen you this side for a while :type:
Posted: Mon Mar 07, 2016 7:18 pm
by mikhail117
iLy wrote:Anyone know where I could get Shield Heavy Duty vinyl and plastic cleaner from here in Cape Town?
Hi bud, not sure about any shops here in CPT that stock it but CD stock it:
http://www.crazydetailer.co.za/index.ph ... ts_id=1068
Regards
