Golf mk1 colour code
Kyle28rsa
Car Make: volkwswagen
Car Model: MK1 1983 GLS
Post by Kyle28rsa »
Good day
I have a golf 1 1983 gls and i want to know whats the colour code or name. It says that there should be a stick somewhere in by the spare wheel but it probably peeled off. Is there anyway i can see what the colour code is?
I also found a plate on the inside of my fender with a bunch of letter and numbers. Any idea whats it for?ImageImage
EX-DOHCTOR
Registered for: 20 years 7 months
Membership No: 712
Re: Golf mk1 colour code
Post by EX-DOHCTOR »
There was a way to get the info off these... Need to see if I can find the web page again.
Kyle28rsa
Post by Kyle28rsa »
EX-DOHCTOR wrote:There was a way to get the info off these... Need to see if I can find the web page again.
Thank you for always helping out. I wouldn't even know what to look for as i dont know what the plate is called
EX-DOHCTOR
Membership No: 712
If I had to guess this might be Mexico Beige - LF1M, but could also be Helios Gold
This might help but you would need to google some of the paint codes
https://vwgolfmk1.org.uk/forum/index.ph ... aint-codes
For some reason they like to make the gold colors different shades with names like Wheat Beige and Storm Beige - but they are differing shades of Gold really.
EX-DOHCTOR
Membership No: 712
Could also be Sand - LA1V
Kyle28rsa
Post by Kyle28rsa »
EX-DOHCTOR wrote:Could also be Sand - LA1V
I saw the LA1V code which looks very similiar to mine. But its hard to tell from just a photo. Thanks for the link
Spelwan88
Registered for: 9 years 2 months
Car Model: '90 1.8 Caddy sport
Membership No: 3224
Post by Spelwan88 »
Daily:
04 Audi A4 2.0 (B6)
90 VW Caddy 1.8 Sport
Rourke
Post by Rourke »
Kyle28rsa wrote: Tue Apr 13, 2021 1:32 pm Good day
From what i see its like that 174n number should be the paint code , but i find nothing and it seems all paint codes start with a letter not a number
Is there no other vin plate somewhere ?
Then i found this
https://touchupdirect.com/touch-up-pain ... -year=1983
Looks like it could be
Mojave beige
or
Burnished gold metalic
Does your colour have a matelic finish or a pastel ( Normal Finish )?
Can VW SA not identify?
Cheers
EX-DOHCTOR
Membership No: 712
174N is the MK1 series identifier in the VIN. My MK1 2 doors VIN starts 172A for example.
There should be another plate either on the slam tray or in the boot with other details such as paintcode, interior and exterior trim codes aswell.
Kyle28rsa
Post by Kyle28rsa »
EX-DOHCTOR wrote:174N is the MK1 series identifier in the VIN. My MK1 2 doors VIN starts 172A for example.
I only have 2 plates. The one in this discusion and another on the slam try for weight distribution. I read somewhere that the one for the colour code is in the boot by the spare tyre, but it is s plastic sticker which can ofcause fall off. Which mine probably did
Kyle28rsa
Post by Kyle28rsa »
Then i found this
Mojave beige
or
Cheers
As what i can see that the mojave beige looks very very close to the cars colour. The other paint code Identifier is just a sticker in the spare wheel compartment, which probably fell off somewhere in the early 90's Image.
The paint is more pastel (base and clear coat)
Is there a way to contact vwsa directly to find out. As i cant get any details from my vin number online, as mine uses the old 10 digit system
Kyle28rsa
Post by Kyle28rsa »
Spelwan88 wrote:Image
Hi. There seems to be an issue with the image. Its being displayed as broken
EX-DOHCTOR
Membership No: 712
Yeah, it is usually in the boot on inside the door jam on the drivers side I think.
I can't confirm the exact locations as my MK1 was resprayed about 6/7 times in its lifetime so there are no badges or stickers except for the reproductions I've had made.
Maybe start a rides thread and add a link to the MK1 Build Register: http://www.vwclub.co.za/forum/viewtopic ... 1&t=192835
Rourke
Post by Rourke »
Kyle28rsa wrote: Fri Apr 16, 2021 10:18 am
Then i found this
Yeah try vw sa it cant hurt using the vin number
maybe they have the record
Other option is paint shop mixing . take a panel and try and match it ( Difficult in metalic and pearl, but normal base coat should be easy).
Worth a try and respray the whole car
Please let us know wat route u took
good luck
Mojave beige
or
Cheers
Kyle28rsa
Post by Kyle28rsa »
EX-DOHCTOR wrote:Yeah, it is usually in the boot on inside the door jam on the drivers side I think.
Ill play around with the forum to find out on how exactlt to do that lol. But ill it a try
EX-DOHCTOR
Membership No: 712
Are you looking for paint to do some touchups?
I'm sure a panel beater should be able to get the correct color and code for you.
Kyle28rsa
Post by Kyle28rsa »
EX-DOHCTOR wrote:Are you looking for paint to do some touchups?
Im just abit paranoid when it comes to a spray painter getting the correct colour. Afraid that the shade might be abit darker or lighter. Thats why i want to find out the code before hand
Car Make: VW, duh...
Car Model: Stuff
Post by Jetta2 »
Always remember if that paint is still original, it would have faded quite a bit in the last 38 years, even if it was kept out of the sun and in a garage, so even if you do get the correct colour code and a painter mixes it, it will be a few shades darker than what is on the car now.
What decent painters do is mix up the colour code, and if it is darker than the OEM paint, they lighten the paint mix and vise versa if it is lighter.
2012 Suzuki Hayabusa
2021 Aprilia RS660
Kyle28rsa
Post by Kyle28rsa »
Jetta2 wrote:Always remember if that paint is still original, it would have faded quite a bit in the last 38 years, even if it was kept out of the sun and in a garage, so even if you do get the correct colour code and a painter mixes it, it will be a few shades darker than what is on the car now.
That helps as i can state if i want it darker or lighter (closest to original)
VAG Fan
Post by VAG Fan »
Jetta2 wrote: Fri Apr 16, 2021 7:51 pm Always remember if that paint is still original, it would have faded quite a bit in the last 38 years, even if it was kept out of the sun and in a garage, so even if you do get the correct colour code and a painter mixes it, it will be a few shades darker than what is on the car now.
This, :iagree: absolutely.
And beware if a painter doesn't match things properly. After two or three partial repaints, your car can be a veritable patchwork quilt of metallic tones. My light-blue metallic Fox is one of those.
Kyle28rsa
Post by Kyle28rsa »
Im definitely going to be anal about how precise i want to work to be doneImage
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
VAG Fan wrote: Tue Apr 20, 2021 11:52 am
@GaVeN matched the paint on my '82 MkI Golf very well which I was happy about. Admittedly the paint isn't that great in a few area's and there are nearly 40 years worth of scratches on some panels so it wasn't pristine to start with.
Carel040
Registered for: 8 years 6 months
Post by Carel040 »
Check out this might helpImage
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
Carel040 wrote: Fri Apr 23, 2021 3:37 pm Check out this might helpImage
I really hope my MkI Golf's paint code matches Mahogany :lol:
Kyle28rsa
Post by Kyle28rsa »
Carel040 wrote:Check out this might helpImage
Thanks for the site. Will check it out
