help with cli jetta 1800 8v kjet
- Registered for: 17 years 5 months
will it be ok to fit a 288 cam to my car its only got a freeflow system with abranch, i know 276 would be more reasonable but i atleast want the same performance as a stndard vtec, please wat is also the diffrence btween 276 and 288 in performance
its not wat you drive its how you drive it.
If you fit the cam you should have your car dyno'd as the air/fuel ratio will be out. Should see a worthwile gain in power. Don't know the power differences with regards to the cams but the 'wilder' ones put the power higher up the rev range and you lose some low end power and torque. I have a 268 cam in my Jetta with mildly worked head and it starts pulling nicely from 3500rpm all the way to 6000. The G cam(252) I had started pulling from 2500rpm until about 5200rpm. So it is basically a case of where you want power to be made. Low rev torque and a nice pull in traffic or a screamer that only starts pulling well at 4000rpm's?
