My 2.0 8V conversion - Another update (28/08/2006)
frog_in_the_fridge
Registered for: 17 years 1 month
Re: My 2.0 8V conversion - Another update (28/08/2006)
Post by frog_in_the_fridge »
mojo786 wrote:shot a lot frog_in_the_fridge... :driving:
To play it safe.....consult quite a few Fi guys and specialists in ur area and elsewhere in teh country. Give em a call
Turbo-charged with a leafblower, Intercooled with a braai grill.
Sponsored by:
SMALLVILE COMICS (Alberton)
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
MacMan
Car Make: SEAT
Car Model: Tarraco XC 1.5 TSi
Membership No: 478
Post by MacMan »
The 1.4i injectors with the stock 3 bar FPR will run a 2.0 motor just fine. Just make sure that your ECU has been mapped / chipped for the 2.0 motor.
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
frog_in_the_fridge
MacMan wrote:The 1.4i injectors with the stock 3 bar FPR will run a 2.0 motor just fine. Just make sure that your ECU has been mapped / chipped for the 2.0 motor.
Which Gbox are u running with ur engine?
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
MacMan
Car Make: SEAT
Membership No: 478
Post by MacMan »
I am running a stock FFZ gearbox from a 1.4i VeloCiti.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
frog_in_the_fridge
Was hoping ud say that. Which starter are u using? When I convert to ADY block from my 1.4 8v block, ill have to change the flywheel and clutch......but will my starter iv got fit on the 210mm flywheel with my FFZ box?
I assume the 1.4 8v flywheel is smaller in dia?
Hows ur daily performance aswell with that Gbox on ur 2.0 engine?
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
MacMan
Car Make: SEAT
Membership No: 478
Post by MacMan »
frog_in_the_fridge wrote:Was hoping ud say that. Which starter are u using? When I convert to ADY block from my 1.4 8v block, ill have to change the flywheel and clutch......but will my starter iv got fit on the 210mm flywheel with my FFZ box?
I am using a standard VeloCiti starter. So yes your starter will work fine.
Yes the 1.4 flywheel is probably 200mm.... maybe even 190mm like on the 1.3.
The gears are perfect for normal everyday driving but a bit short for top end stuff. I have seen 211km/h on the GPS, but that was near the 7200rpm limiter in 5th.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
frog_in_the_fridge
I can live with 211km at this stage....with my 1.4 I cant even get near 190km on a downhill.
Instead of lightening the flywheel....why dont ppl use the smaller dia flywheels with corresponding clutch and just have them lightened. Im sure ull lose more weight with a lightened smaller flywheel then a 210mm one.
Or dont the bolt holes line up?
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
MacMan
Car Make: SEAT
Membership No: 478
Post by MacMan »
That would mean the friction surface of your clutch would be smaller, which would mean more chance of slippage.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
frog_in_the_fridge
MacMan wrote: I assume the 1.4 8v flywheel is smaller in dia?
The gears are perfect for normal everyday driving but a bit short for top end stuff. I have seen 211km/h on the GPS, but that was near the 7200rpm limiter in 5th.[/quote]
Or dont the bolt holes line up?[/quote]
That would mean the friction surface of your clutch would be smaller, which would mean more chance of slippage.[/quote]
Ok. Was hoping that the 1.4 clutch wud have enuff pressure on the same size flywheel attached to a larger displacement engine.
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
