Volkwagen Motor & Gear Oil Specifications & Codes
Posted: Fri Jul 06, 2012 4:28 pm
Volkswagen introduced its own specifications in mid '90s. Since then this classification system is the starting point for selecting the technically suitable products for all vehicles manufactured by the VW group (Volkswagen, Audi, Seat, Skoda).
Volkswagen Motor Oil Specifications
VW 500.00
Volkswagen specification for multigrade engine oils for gasoline engines with SAE 5W-X/10W-X viscosity. This is an "old" oil specification and is applicable to engines built before model year 2000 (up to August 1999). Oils with an approval made post March 1997 were given an alternative, later VW specification.
VW 501.01
Conventional motor oils suitable for some VW engines built before MY 2000. This is an “old” oil specification and is applicable to engines built before model year 2000 (up to August 1999). Oils with an approval made post March 1997 were given an alternative, later VW specification.
VW 502.00
Oil for gasoline engines. Successor of VW 501.01 and VW 500.00 specification. Recommended for those which are subject to arduous conditions. It must not be used for any engines with variable service intervals or any which are referred to under other specifications.
VW 503.00
Long-life gasoline engine oil for VW cars with WIV (system for longer service intervals). Also meets ACEA A1, SAE 0W-30 or 5W-30 specification.
VW 503.01
This specification is specifically for Audi RS4, Audi TT, S3 and Audi A8 6.0 V12 models with outputs of more than 180bhp, running with variable service intervals (30,000km or 2 years). Now superceded by the VW 504.00 specification.
VW 504.00
The VW 504 00 specification supercedes the VW 503 00 and VW 503.01 specifications. VW 504 00 oils are suitable for engines meeting the demands of Euro IV emissions standards.
VW 505.00
Passenger car diesel engine oil specification, minimum performance level CCMC PD-2. Lists viscosities SAE 5W-50, 10W-50/60, 15W-40/50, 20W-40/50 requiring 13% max. evaporation loss and SAE 5W-30/40, 10W-30/40 requiring 15% max. evaporation loss.
VW 505.01
Special engine oil for VW turbodiesel engines with pump-injector-unit and for the V8 Commonrail turbodiesel engines. Meets ACEA B4 SAE 5W-40 specification.
VW 506.00
These oils are suitable for diesel engines with extended service intervals of up to 50,000km / 2 years. Not for use on engines with a single injector pump. Oil change is indicated by the electronic service indicator. Viscosity is SAE 0W30.
VW 506.01
These oils are especially for "Pumpe-Düse" (unit injector or "PD" engines) running on extended service intervals (30,000 - 50,000km / 24 months). Oil change is indicated by the electronic service indicator.
VW 507.00
Low SAPS oils suitable for Euro 4 engines and almost all VAG diesel engines from 2000 onwards with extended service intervals, unitary injector pumps and also Pumpe-Düse ("PD") engines. Excludes V10, R5 engines and VW Commercial vehicles without fitted DPF (diesel particulate filters) – these must use a 506 01 specification oil.
VW 508.00
This standard is not yet released. It will probably require a low SAPS oil with energy conserving properties.
Volkswagen Gear Oil Specifications
VW G 009 317
Gear oil for mechanical and automatic 6 gear transmissions.
VW G 052 145 A2
Special synthetic gear oil with SAE 75W90 viscosity for front and rear differentials, including limited slip differentials.
VW G 052 162 A2
Special ATF with viscosity modifier. Suitable for 4 and 5 gear ZF automatic transmissions. Not suitable for 6 gear transmissions.
VW G 052 171
SAE 70W75 viscosity gear oil.
VW G 052 171 A2
Special gear oil designed for the manual transmissions of cars with transverse engines.
VW G 052 175
Special working fluid for Haldex clutches. Developed by Haldex and Statoil.
VW G 052 178
Gear oil with SAE 75W viscosity.
VW G 052 180 A2
Special gear oil for Audi Multitronic transmissions.
VW G 052 190 A2
Special VW gear oil for Multitronic CVT transmissions.
VW G 052 726
Monograde gear oil with SAE 75W viscosity.
VW G 052 798
VW G 052 911
Audi specification for transmissions used with longitudinal engine configurations. Products meeting this specification are of SAE 75W90 viscosity and also meet API GL-5 criteria.
VW G 052 990
Special ATF for automatic transmissions combined with differentials.
VW G 055 005
Special ATF for VW automatic transmissions and transaxles.
VW G 055 145
Transmission oil with 3% Sturaco additive.
VW G 055 162
VW G 055 175 A2
http://www.oilspecifications.org/volkswagen.php
VW 500.00
VW 501.01
VW 502.00
VW 503.00
VW 503.01
VW 504.00
VW 505.00
VW 505.01
VW 506.00
VW 506.01
VW 507.00
VW 508.00
VW G 009 317
VW G 052 145 A2
VW G 052 162 A2
VW G 052 171
VW G 052 171 A2
VW G 052 175
VW G 052 178
VW G 052 180 A2
VW G 052 190 A2
VW G 052 726
VW G 052 798
VW G 052 911
VW G 052 990
VW G 055 005
VW G 055 145
VW G 055 162
VW G 055 175 A2
