Cadence braking or stutter braking is an advanced driving technique used to allow a car to both steer and brake on a slippery surface. In the past it would be used to effect an emergency stop where traction is limited, though for use in an emergency requires a presence of mind that the situation itself might preclude. Cadence braking is supposed to maximise the time for the driver to steer around the obstacle ahead, as it allows him to steer while slowing. It needs to be learned and practiced. For most drivers it has been entirely superseded by ABS.
Maximum braking force is obtained when there is approximately 10%-20% slippage between the braked wheel's rotational speed and the road surface [1]. Beyond this point, rolling grip diminishes rapidly and sliding friction provides a greater proportion of the force that slows the vehicle. Due to local heating and melting of the tyres, the sliding friction can be very low. When braking at, or beyond, the peak braking force the steering is ineffective since the grip of the tyre is entirely consumed in braking the vehicle.
Cadence braking involves pumping the brake pedal fairly rapidly but deliberately, to make the wheels lock and unlock. It can be approximated by the following steps:
Press the brake pedal until wheels lock up. On dry, hard pavement you will start to hear a squealing sound. On loose or slippery surfaces you will start to hear a swashing sound.
Reduce brake pedal pressure for the locked up wheels to regain traction and start rotating again. Note that on slippery pavement you will have to lift your foot almost entirely to regain wheel rotation.
Lower your foot again to increase brake pressure until the wheels lock up the second time, then lift it again to release pressure and unlock.
Lower your foot again to lock up the wheels the third time, then release to unlock once more.
Continue pumping the brakes in this fashion until the vehicle stops or the danger is over.
Anti-lock braking system performs these operations automatically many times per second in rapid succession. A human driver can perform one lock-release cycle per second with practice.
This is done primarily to maintain steering control, at least in part. In wet, hard surfaces, this is useful to reduce somewhat total braking distance. When ABS is present the best emergency stop will usually be obtained by simply pressing very hard on the brakes, forcing the ABS to perform, and steering to avoid the obstacles ahead.
Cadence braking (or any other type of braking) will not help much on extremely slippery surfaces such as ice (in theory it would, but in practice the ice can be so slippery that it makes little difference — a winter tire would make more difference). Also, on very loose surfaces, a quicker stop can be achieved by simply locking the wheels, causing a wedge of loose material to build up ahead of the wheels and create a substantial braking force. In such conditions, ABS actually increases the stopping distances. On poor surfaces, in the past, rally drivers timed the pulsing of brake application so as to take advantage of the load transfer as the vehicle pitches forwards and backwards in response to the initial braking effort. With modern overdamped, stiffly sprung, suspensions this is less likely to be effective.
While cadence braking is effective on most surfaces, it is less effective at slowing the vehicle, than keeping the tires continually at the optimum braking point which is called threshold braking. The latter is an expert driving technique that is even more difficult to learn than cadence braking, and again has been largely superseded by ABS.
Threshold braking, or a good ABS, generally results in the shortest stopping distance in a straight line. ABS, cadence and interference braking are intended to preserve steering control while braking.
from wiki
Cadence Braking
- Post Whore
- Registered for: 17 years
- Car Model: boat
- Membership No: 1133
Cadence Braking
