Here's our VW Polo 1.4tsi GTi DSG buying advice to help you make an informed decision when considering buying this car.
Watch Video
Shop used VW Polo 1.4tsi GTi DSG's for sale in South Africa https://www.wheelindex.co.za/cars-forsa ... EN/VW_Polo
#1 Pistons Breaking
#2 Charge pressure change over valve
#3 Mechanical Clutch failure on water pump failure
#4 Turbo failure
#5 Timing Chain & Tensioner
#6 Camshaft adjuster gear
#7 Fuel injectors
#8 DSG Clutch (7-speed auto dry clutch)
#9 DSG Mechatronic
VW Polo 1.4tsi GTi DSG Specs:
132kW @ 6,200rpm
250nM @ 4,500rpm
Turbo Charged & Supercharged
1.4L Engine
Automated Dual-clutch (7 speed dry clutch)
9 Common Problems with the VW Polo 6R GTI 1.4tsi DSG
- kingr
- Car Make: 2007 VW
- Car Model: Golf 5 GTI
- Membership No: 3337
- 07" Golf 5 GTi, 6MT, RamAir Intake, TMSS DP, Bridgestone Potenza RE11s/RE003
- 13" BMW 1-Series 118i AT
Ex: 13" ST180, 03" Mk4 2 door 1.8T Stage 2, 07" Velo 1.6, 83" Mk1 GT 2.0 8v MP9, 87" Mk1 1.6 CitiSport, 88" Mk2 2.0 16v, 83" Mk1 GT 1.6 + 40 webers
- NHB_R
Re: 9 Common Problems with the VW Polo 6R GTI 1.4tsi DSG
And overheating - radiator leaks
- kingr
- Car Make: 2007 VW
Is that a common issue? It didn't come up with my research, happy to add it.
- Car Model: Audi S3 Sedan
- Membership No: 1215
The radiator leak yes, It was a common problem caused by the fan cowling rubbing through the radiator.
There was a fix issues, but was only done to cars that went in for the issue
Grant Hendry
Membership no.:1215
2016 Audi S3 Sedan
1978 VW Golf 1100 GL
2012 VW Golf GTI Edition 35
2007 VW Golf GTI
2006 Polo 1.9 TDI Sportline
2012 VW Polo GTI
Membership no.:1215
2016 Audi S3 Sedan
2007 VW Golf GTI
2012 VW Polo GTI
