Help with sound interference/noise.
duggy8v
Car Model: MK3 GTi 2.0 8v
Post by duggy8v »
Hi
I recently installed a JVC KD-G521.
Now whenever an electrical component comes on in car, it can be heard in the speakers. For instance, when indicating, it sounds from speakers which are amplified. Or when a CD is spinning or a track is skipped, you can hear the sound of skipping and spinning from the woofer.
Any advice ?
'95 VW Golf MKIII GTi
'99 Opel Corsa B 1.4i - Sold
'84 VW Golf MKII CSL - 2.0 8V AFW - Sold
EX-DOHCTOR
Membership No: 712
Re: Help with sound interference/noise.
Post by EX-DOHCTOR »
Is your amp properly grounded?
Have you checked the earth strap on the battery?
Donavan
Post by Donavan »
you need to run your power cables for the amp on one side of the car and your rca cables for the amp on the other side of the car.
Audi A4 B8 2.0T - Daily
duggy8v
Post by duggy8v »
Hi, ground is fine. Wiring is separated. I don't see why this happened because all I did was remove previous Alpine deck and installed the jvc deck.
Even grounded the rca outputs from deck.
dcmk4
Registered for: 10 years
Car Model: MK7 GTi
Post by dcmk4 »
I had the same issue with a JVC headunit. Turns out the RCAs needed their own grounding to get rid of the noise audible over speakers powered by an amp.
Seemed to be a common problem with JVC units.
Even with your grounding of the RCAs then I would put it down to the headunit itself if it wasn't a problem before.
'14 Golf Mk7 GTI
THANAS STG/// ECU&DSG
Littco L380x
All the ponies
amstel18
Car Model: Tiguan Allspace
Post by amstel18 »
Remembered what I did on a buddy JVC deck back in the day..
Took some thin flex and wrapped the copper strands around the outside of the RCA terminals and basically grounded them to one of the screws on the casing of the deck. Seems to work for me. System ran like that with no issues....
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
