Installing amp in Ibiza Cupra
Posted: Sun Oct 17, 2010 11:09 am
A Buddy of mine Drives a 07 Ibiza Cupra TDi.
So yesterday me and him wanted to fit a amp, sub and new speakers.
So I installed the power and rca cables. but the problem is I couldn't get a remote wire on the HU.
The wiring diagram I found on the internet says its pin 11 which is a solid yellow wire. It only gives 3volts. Which wire should I use for remote?
Also the Dumba$$ connect the electri mirror pug to the power window console by accident. Dont know if that caused the problem but now the passenger side window does not work!
The way i connected the RCA's was with a high level converter which I cut the front speaker wires from the HU for the inputs to the converter and then just connect the wires from the output of the amp to the wires behind the HU going to the doors.
Did I do something wrong with the high to low converter? He called me this morning to say that some of the interior lights are freaking out and that the indicators don't flash when you lock the car.
I need help please. We ended up just putting back all the panels and so now only the rear speakers work as the front and sub was going to run off the amp.
