Disclaimer: I'm am not a mechanic. I do not know everything. Please lets educate each other.
I have recently bored my HV 1800 block from 20 thou to 40 thou because the cylinders weren't even. There isn't an increase in power whatsoever but im okay with that, my problem is that the engine is not rev happy. it makes good power but seem to be sluggish i mean just reving the car from 1000 revs to 3000 takes a while and its always been like this. and ive checked videos on youtube of other 1800 carbs the revs go up fairly quickly compared to mine. is there anything i should look into?
VW 1800 HV Build
- amstel18
- Car Model: Tiguan Allspace
Re: VW 1800 HV Build
timing correct?
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Im not sure. I trust my mechanic. do you think it could be the timing? the power is there though.
Where you based?ssshannah wrote:Im not sure. I trust my mechanic. do you think it could be the timing? the power is there though.
I'm in joburg
- Car Model: '16 Golf 7R, 86 Caddy AUM 20VT
As others state, timing to be checked.
I would also look into other areas like carb and its jetting. You provide limited information on rest of you engine and just saying HV motor, assuming all other engine part are still from original HV motor.
Taking that into account the HV motor was only a 70Kw motor in original std form.
If your aim is to get more from this motor, you will need to look at a different carb or carbs, camshaft, branch and exhaust system.
Yeah JHB is a big place.ssshannah wrote:I'm in joburg
I can help you check the issue and tune the car.
I'm in Springs.
