Agu 200kw build
444Funec
Car Model: Mk1 20v
Agu 200kw build
Post by 444Funec » Tue Jan 01, 2019 8:13 pm
Hi guys. I’m a newb here, I’ve tried searching a 200kw build on a AGU motor with no luck. There were some posts from 2005 and I’m sure people have been doing this and learnt some tricks along the way. I’ve purchased a 20v Agu motor and wanting to know what size turbo would give me a decent increase in power. Motor is going into a mk1 golf with dictator 60-2 management. I’m also needing to find out what size injectors to run 50/50 mix pump / ethanol. And advise would greatly be appreciated.
:hug:
PapaJo
Re: Agu 200kw build
Post by PapaJo » Tue Jan 01, 2019 8:19 pm
Search fot 20V BT builds on the forum. Quite a few around and look at Boost, DCMK4 and Lodewyk to name a few. Some serious builds, those.
You’ll need atleast 1000cc injectors on ethanol build.
444Funec
Car Model: Mk1 20v
Re: Agu 200kw build
Post by 444Funec » Tue Jan 01, 2019 9:07 pm
Awesome thank you , will search now
:hug:
444Funec
Car Model: Mk1 20v
Re: Agu 200kw build
Post by 444Funec » Fri Feb 15, 2019 5:56 pm
Heya, please could you help me to find the guys who you mentioned, would like to get the injector size right as I’m at that point of the build now.
:hug:
PapaJo
Re: Agu 200kw build
Post by PapaJo » Fri Feb 15, 2019 7:31 pm
Use the search funtion.
Car Make: Fiat, Toyota
Car Model: Uno, Auris
Re: Agu 200kw build
Post by Unobeat » Fri Feb 15, 2019 10:29 pm
Here you go:
https://www.vwclub.co.za/forum/viewtopi ... 1&t=198101
https://www.vwclub.co.za/forum/viewtopi ... 1&t=199355
444Funec
Car Model: Mk1 20v
Re: Agu 200kw build
Post by 444Funec » Fri Feb 15, 2019 10:46 pm
Thanks guys 👍🏻
:hug:
Stu
Car Make: Merc
Car Model: C63 Edition 507
Re: Agu 200kw build
Post by Stu » Mon Feb 18, 2019 7:11 am
After Many years of my project sitting on the back burner I think since 2004, any how Its back on track Panic is busy with it and will post pics of the build as it goes along - https://www.vwclub.co.za/forum/viewtopi ... 1&t=179892
Polo 20VBigT - The Redhead
C63 507 Edition - The Dragon
