17952/P1544 Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
Mangweni Unathi
Post by Mangweni Unathi » Fri Nov 30, 2018 12:04 am
I own a VW 2006 Jetta 5 model. I have already replaced the petrol pump and throttle body on the car. When i took it to the mechanic after replacing the above parts.
The car gave us to error codes i.e. 17580 for the pedal position sensor (signal too low) and 17952 angle 1 sensor for/ throttle actuator sensor.
I then bought a new accelerator pedal position sensor system and replaced the old, however my car is still not driving and the are no error messages on the dashboard.
When we remove the plug that goes into the throttle sensor, the car starts and revs up to 15 on the rev count. When plugging in the plug into the throttle sensor, the car doesn't even want to start. And bare in mind that this is a a new throttle body.
Please help as I do not know what to do now...
WeirdSteam
Car Model: A3 Sportback 1.8 TFSI
Re: 17952/P1544 Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
Post by WeirdSteam » Fri Nov 30, 2018 7:09 am
You need to do adaption with VCDS for the new throttle body.
Sent from my WAS-LX1 using Tapatalk
Current: 2010 A3 1.8T Sportback
ex: 1996 Golf Mk3 GTs (Minion Yellow)
