In Stock: PTP Lava Exhaust Heat Wrap
Specialists in the distribution of high quality aftermarket parts and tuning solutions for all car enthusiasts.
Our product range includes Turbochargers, Turbo Blankets, Exhaust Heat Wrap and Knock Detection Devices.
Phoenix*
Postby Phoenix* » Thu Mar 06, 2014 10:41 am
Hi Guys,
We have in stock PTP Lava Exhaust Heat Wrap for all the guys wanting to insulation their exhaust manifolds, and downpipes, or even perhaps tgheir entire exhaust systems.
Superior wrap, which insulates the heat efficiently, especially to prevent a loss of heat feeding to your turbocharger.
PTP Lava Exhaust Heat Wrap - 15m Roll: R650 all inclusive
____________________
The PTP Lava Heat Wrap is constructed from fragmentized lava rock that is extruded into the fibers to create a heat wrap that will give you strength and performance you expect from an exhaust header wrap.
When properly installed, the proprietary weave in our heat wrap will allow an even dissipation of heat so that it will not over insulate your pipings or create any hot spots.
The PTP Lava Heat Wrap promotes increased flow and keeps down underhood temperatures for improved performance and reduced vibration breakdown.
PTP's Lava Heat Wrap is chemical and oil resistant that will not shrink or loose flexibility under extreme conditions. Lava Heat Wrap is very easy to install and tightens down onto pipings without needing to be wet.
Lava Heat Wrap Tolerance:
Direct Contact Use Limit: 1800 °F / 982 °C
Max Contact Use Limit: 2500 °F / 1371 °C
Marco da Costa
Managing Director
Phoenix Performance
Cell: +27 79 884 4856 | Fax: +27 86 240 3730
E-mail: [email protected]
Website: www.phoenixperformance.co.za
Phoenix*
Re: In Stock: PTP Lava Exhaust Heat Wrap
Postby Phoenix* » Wed Apr 09, 2014 2:12 pm
BUMP!
Marco da Costa
Managing Director
Phoenix Performance
Return to “Phoenix Performance”
Users browsing this forum: No registered users and 1 guest
