For Sale: Mitsubishi Evo 8 - 2.3 Stroker
Specialists in the distribution of high quality aftermarket parts and tuning solutions for all car enthusiasts.
Our product range includes Turbochargers, Turbo Blankets, Exhaust Heat Wrap and Knock Detection Devices.
Phoenix*
Postby Phoenix* » Wed Feb 26, 2014 3:07 pm
Hi Gents,
Sad to put my Evo 8 up for sale, but it's time for me to move on.
I just never get a chance to drive the car...4 years...and only 5500kms...Lol
Asking for R420K...making a R200K loss...OUCH!!!
Below is a list of mods I put together...but, trust me, there is alot more that I've forgotten:
Evo VIII Modifications
Block Internals / Parts
Evo 9 Cast Iron Block
Norris Designs Forged Billet 100mm Stroke Crank - Part No.090058
ARP Crank Bolt & Washer Kit
Manley 150mm TT I-Beam Conrods - Part No.14403-4 (c/w ARP 625 cap screws)
Manley Platinum Series Pistons 85.5mm Dia. / -22cc Dish / 9.1 CR - Part No.608005C-4 (c/w Rings)
Manley 9310 Upgraded Piston Wrist Pins
Balance Shaft Eliminator Kit
ACL Race Main Bearings c/w Thrust Washers
ACL Race Rod Bearings
ARP L-19 4G63 Headstuds
ARP 4G63 Case Bolts
Complete 4G63 engine gasket & seal kit
Gates Kevlar Cambelt
Gates Performance Strong Serpentine/Accessory Belt - EVO 8/9
Gates Timing Belt Idler Pulley
Fluidmpr Harmonic Balancer Crank Pulley
OEM Oil Pump / Front Case for Evo 8
Water Pump, Gasket & O-Ring Kit
Tomei Oil Slicing Baffle
Cylinder Head + Valve-train + Ignition System
Custom Porting and Gasflowing
Zaklee Sightglass Clear Cam Gear Cover fpr Evo 8
Fidanza 4G63T Adjustable Cam Gears for Evo 8
ARP Cam Sprocket Bolt Kit
Kelford Cams 280/276 Camshafts Mitsubishi Lancer Evo8 4G63T
GSC Beehive 100lb Valvesprings and Ti Retainers 4G63T
GSC Power-Division 4G63 Zero-Tick Lifters (4042)
Ferrea Bronze Valve Guides 4G63 4G63T Lancer Evo 8
Ferrea Valve Seals Mitsubishi 4G63 4G63T Lancer Evo 8
Manley Intake Stainless Steel Valves 34mm (std head diameter) - Part No.11134-8
Manley Exhaust Stainless Steel Valves 30.5mm (std head diameter) - Part No.11133-8
Manley Sport Compact Valve Locks - Part No.13016-8 (2x Sets Required - $34.80 Each)
Spoolin-Up Evolution New Coil COP Kit - Evo 7-8 (Carbon Fiber - Under Cover)
Kiggly Racing - HLA Pressure Regulator (Evo8/9 + Universal)
Forced Performance
Garret GTX3076R Turbo
ATP Twin-Scroll 1.06 A/R Turbine Housing
JMFab Mitsubishi Evo 8 Turbo T4 Exhaust Manifold c/w Tial MVS 38mm EWG Flanges + EGT Bung
JMFab Mitsubishi Evo 8 - 3" Twin-scroll AC Compatible O2 Housing
JMFab Mitsubishi Evo 8 - Two to One Twin-scroll EWG Dump Pipes
JMFab Mitsubishi Evo 8 Intercooler Kit - 3.8" Core
Thermal Ceramic Coating for ATP Twin-Scroll 1.06 A/R Turbine Housing
Thermal Ceramic Coating for JMFab Mitsubishi Evo 8 - 3" Twin-scroll AC Compatible O2 Housing & Two to One Twin-scroll EWG Dump Pipes
Thermal Ceramic Coating for JMFab Mitsubishi Evo 8 Turbo T4 Exhaust Manifold
ARP SS Exhaust Manifold Stud and Nut Kit for Evo 8
MAP Exhaust Manifold Stud & Nut Kit for Evo 8
2x Tial 38mm MV-S External Wastegate
Tial Q-Type Blow-Off-Valve
Locally Fabricated Mitsubishi Evo 8 - 3" Downpipe + Full Exhaust (304 ST/ST)
PTP Lava Exhaust Heat Wrap of Screamer Pipe, O2 Housing, and Downpipe
Megan Racing M-Spec II Carbon-fibre Turbo Muffler with Titanium Tip
Custom Flexible Hydraulic Clutch Line
Custom Flexible Teflon Stainless Steel Braided Fuel Lines
Custom Flexible Teflon Stainless Steel Braided Turbo Oil and Coolant Lines
Dei Fire Sleeve - 5/8" x 3m - For Turbo and Fuel Lines
PTP T3/T4 Lava Turbo Blanket
Mangus EVO Cast Aluminum Intake Manifold
Full Blown Cast 70mm Throttle Body (Mitsubishi Evo 8/9)
ATP Turbo - Turbine Housing Clamp and Bolt Kit
ATP Turbo - T4 Divided Turbine Gasket (2 Off)
Hyperflow 100mm Air-Filter + Custom 4" Intake
PECS MAC 4-Port Solenoid - Part No. 45A AA1 DDBJ 1KA
Fuel System
Fuelab Mini Adjustable Fuel Pressure Regulator
71511 EFI Fuel Pressure Gauge Dual BAR/PSI 0-120 PSI Scale
AMS Fuel Rail (Evo)
Walbro 400lph c/w Installation Kit
Walbro 400LPH E85 In-Tank Fuel Pump
Walbro Universal Installation Kit for E85 400LPH Fuel Pump
Fuelab 828 Series Fuel Filter / -6AN In/Out - Black/Black - 75 Micron Stainless Steel Filter
1250cc FIC Injector Seals
Custom SKF 1250cc FIC Injector Seals
Clutch
Carbonetic Twin-Plate Clutch Kit (Evo 8 / 9) Regular Part No. ACM23230-14
ARP Flywheel Bolt Kit
Cooling - Oil System
Mishimoto Mitsubishi Lancer Evo IV-VI Manual Aluminum Radiator
Mishimoto 12” Electric Fan 12V
Mishimoto Universal Fan Mount Kit
MAP Upper Radiator Hose for Evo 8 & 9 with Evo 4/5/6 Radiator
Pyro Performance Oil-Catch-Can
Suspension / Engine Mounts
Ingalls Stiffy Arm
Whiteline 26mm Swaybar Front
Whiteline 24mm Swaybar Rear Adjustable
Whiteline Roll Centre Kit
Whiteline Spherical Front Links
Whiteline Spherical Rear Links
CUSCO 6-Point Roll-Cage
TEIN Coilovers
Torque Solution 5 speed Billet Aluminum 4 Piece Full Engine Mount Kit (Evo 8 / 9)
Transmission / Drivetrain
ShepTrans EVO 8 Transfer Case Ring and Pinion Rebuild
Main Transmission Rebuild with Cryogenic Treatment
Engine Management System
Vi-Pec V88 Mitsubishi EVO4-8 with integrated 4-Bar MAP sensor
Miscellaneous
NGK Iridium 2-Step Colder Spark Plug Set - Part No.BR8EIX
Diaqueen LSD Gear Oil - Transfer Case and Rear Diff
Mitsubishi ACD Transfer Case Oil - Diaqueen ATF SPIII
Motul RBF660 Brake Fluid
Redline Super Cool Water Wetter
Redline Power Steering Fluid
75W140NS GL-5 Gear Oil - Main Transmission
Here is a pic of the current engine bay and vehicle:
Thanks.
Regards,
Marco
Marco da Costa
Managing Director
Phoenix Performance
Cell: +27 79 884 4856 | Fax: +27 86 240 3730
E-mail: [email protected]
Website: www.phoenixperformance.co.za
PoLonY
Car Model: Volvo
Membership No: 1997
Re: For Sale: Mitsubishi Evo 8 - 2.3 Stroker
Postby PoLonY » Wed Feb 26, 2014 3:10 pm
Everywhere I look it's haunting me... :crazy:
:sad:
Amazing spec sheet
Naku786
Cake Laaitie Killer
Car Model: Citi 1.9i 8v
Postby Naku786 » Wed Feb 26, 2014 3:11 pm
:crazy: :crazy: :crazy: :crazy:
my dream car :drool: :drool:
FML :cry:
FrancoisMK2
Car Make: Kia, VW
Car Model: Sportage, Golf 2 1.3 cl
Postby FrancoisMK2 » Wed Feb 26, 2014 3:16 pm
What sort of power does this Frankenstein make ? :crazy:
As I lay rubber down the street.
I pray for traction I can keep, but if I spin
and begin to slide, please dear God protect my ride.
ShafiqNC
Car Model: Golf 6.:R
Postby ShafiqNC » Wed Feb 26, 2014 3:18 pm
:drool: :drool: :drool: :drool: :drool:
jeeeeeziz this is so sexy..glws
i know this thing must fly but is there any chance you could give me an idea of exactly how fast it is?1/4 mile?
vw is the best, f*#k the rest!!!
My Citi build!
REVV - ZN
Car Model: 2016 Golf 7R
Postby REVV - ZN » Wed Feb 26, 2014 3:19 pm
What a list :drool:
2008 Z4 Roadster
2016 Golf 7R DSG
1996 Golf 3 VR6
2012 Golf 6 TSI DSG
2013 Chevrolet UTE 1.4 Rolling on 17's
2012 Chevrolet UTE 1.4
MK5 GTI DSG
1996 Golf 3 GSX - VR6 Kit
1992 Ford Meteor 1.6
1.8R_andre
XSphere
Car Make: Bakkie
Membership No: 1378
Postby 1.8R_andre » Wed Feb 26, 2014 3:48 pm
EISH BRA all that work and now this :(
Is it fast :D
Demon Tweaked
Car Make: VW & VW
Car Model: MK7R & MK6 GTI
Membership No: 1845
Postby Demon Tweaked » Wed Feb 26, 2014 3:51 pm
FFS! I was looking so hard for this a week and some change ago! :bang:
LB MK7R 359WHP 511NM
MK6 GTI DSG UNITRONIC Stage2
AUDI RS3
BMW E92 M3 350WHP @ Rally Cross Motors
UNITRONIC SEAT Ibiza Cupra 1.8 20vT Stage3 434WHP 509NM @ KAR
VW Citi Chico 1.4
PoLonY
Car Model: Volvo
Membership No: 1997
Postby PoLonY » Wed Feb 26, 2014 3:51 pm
Demon Tweaked wrote:FFS! I was looking so hard for this a week and some change ago! :bang:
OLX that RS3 asap :lol:
Stompie
Boostleak Guru
Car Make: VW POLO
Car Model: 07' GTI 9n3
Membership No: 1843
Postby Stompie » Wed Feb 26, 2014 3:52 pm
LOL when i saw this just now, i thought of you!! :grin:
this thing probably pushes out close to a 1000hp!!!
07' Polo GTI 1.8T Rides Thread Here
Demon Tweaked
Car Make: VW & VW
Membership No: 1845
Postby Demon Tweaked » Wed Feb 26, 2014 3:53 pm
:bang: no comment to anyone, leave me to sit here disappointed
AUDI RS3
VW Citi Chico 1.4
Titleists
Philosopher STIG
Membership No: 1520
Postby Titleists » Wed Feb 26, 2014 3:57 pm
Looks like only the body, seats and the steering wheel is stock. :driving:
VCDS changes done by me for a minimal fee
My ex rides:
2013 LHD Scirocco R
2011 Golf 6 GTI
FrancoisMK2
Car Make: Kia, VW
Postby FrancoisMK2 » Wed Feb 26, 2014 3:58 pm
Demon Tweaked wrote::bang: no comment to anyone, leave me to sit here disappointed
Haha to make you feel better. AMG 6.3l :cool:
cuz only milk and juice comes in 2 litres :troll:
Donnie Darko
Membership No: 1834
Postby Donnie Darko » Wed Feb 26, 2014 3:59 pm
Just as I get my head right about keeping the Roc FFS :bang: :bang: :bang:
Current: 2016 VW Golf 7 ED40 Clubsport DSG
Ex: 2012 VW Golf 6 ED35 Manual - 342WHP and 500NM
Ex: 2015 BMW F21 M135i Sport Auto - 393.2WHP and 639NM
Ex: 2013 BMW F20 M135i Sport Auto - 332WHP and 626NM
Ex: 2012 Golf R DSG - 300WHP and 473NM
Ex: 2010 Scirocco DSG 155KW - 300.8WHP and 416NM
Ex: 2008 Ford Focus ST - 262.2WHP and 425NM
Ex: 2006 Golf 5 GTI DSG
Postby Kyle » Wed Feb 26, 2014 4:00 pm
I must have privacy now.
PoLonY
Car Model: Volvo
Membership No: 1997
Postby PoLonY » Wed Feb 26, 2014 4:05 pm
it's a 2.3 :troll:
crumbs
Race Chip
Car Make: Volksie
Car Model: Rocc2.0tsiDSG
Postby crumbs » Wed Feb 26, 2014 4:06 pm
Donnie Darko wrote:Just as I get my head right about keeping the Roc FFS :bang: :bang: :bang:
:crazy: :drool: :drool: :drool: :drool: :crazy:
Only if I didn't buy the ED.... but im happy, price is a little over budget!
Demon Tweaked
Car Make: VW & VW
Membership No: 1845
Postby Demon Tweaked » Wed Feb 26, 2014 4:08 pm
it's a 2.3 :troll:
Mine is 2.5 :troll: but will get a PK bitchslap from hell from this thing.
AUDI RS3
VW Citi Chico 1.4
Firestrm_ZA
Car Make: SEAT
Car Model: 2008 Leon Cupra
Membership No: 1906
Postby Firestrm_ZA » Wed Feb 26, 2014 4:13 pm
You know you want to.... :lol:
Tidy
Car Make: Suzuki
Car Model: Jimny
Postby Tidy » Wed Feb 26, 2014 4:18 pm
it's a 2.3 :troll:
Find away to C.P.A the RS :troll:
Suzuki Grand Vitara (Pearl White) 1.5'' Lift, 17" Magnums, Pirelli Scorpion ATR's
Kawasaki Ninja ZX6R 636 (Custom Saturn Black)
Suzuki Jimny (Pearl Black)
Peugeot 207 GTI (Diablo Red)
VW Polo 9n3 Sportline (Black Magic)
VW Polo 9n Classic 1.4 TDi (Silver Bird)
Mazda Astina 180SE 16v (Gunmetal)
Demon Tweaked
Car Make: VW & VW
Membership No: 1845
Postby Demon Tweaked » Wed Feb 26, 2014 4:20 pm
it's a 2.3 :troll:
I would be lying if i told you that exact thought didnt just run through my mind :lol:
AUDI RS3
VW Citi Chico 1.4
Donnie Darko
Membership No: 1834
Postby Donnie Darko » Wed Feb 26, 2014 4:22 pm
:banned:
:crazy:
crumbs
Race Chip
Car Make: Volksie
Postby crumbs » Wed Feb 26, 2014 4:25 pm
:banned:
:crazy:
Jy sal nie :evil:
FrancoisMK2
Car Make: Kia, VW
Postby FrancoisMK2 » Wed Feb 26, 2014 4:26 pm
crumbs wrote:
:banned:
:crazy:
Jy sal nie :evil:
Hy sal nie hys bang :lol:
VW POLOTIC
Postby VW POLOTIC » Wed Feb 26, 2014 4:27 pm
Bliksem, what a shopping list! :crazy:
______________________________________________________________________
Current Ride: 2013 CW Tiguan 1.4T B/M
Previous Ride: 2007 Flash Red Polo GTI
CPI, H&R, Powerflow Downpipe, Forge DV, ITG CAI
"The bitterness of poor quality is remembered long after the sweetness of low price is forgotten."
Return to “Phoenix Performance”
Users browsing this forum: No registered users and 3 guests
