Date: Sunday, 28 October 2012
Time: 8:00am - 3:00pm (approx.)
Cost: Member rates/Revo Clients R100, non-members R250.
Pre-Reg cut off date: 25 October 2012
Food: We have arranged halaal caterers. Please feel free to bring your own gas braai's. NO OPEN FIRES ALLOWED.
We will be capping entries at 120 cars and will be on a first come basis.
There will be a lot of interest so I suggest you guys get cracking if you want a spot.
We will be doing Heads up racing, Results will be given in class format. Classes TBA.
Please note there will be a driver's Briefing at 8am! We'd like everyone to be present for this please.
Gates open at 7am, Racing starts at 8:15
NB: Helmets, Closed shoes and long sleeves are mandatory for all drivers and passengers.
Pre registration is mandatory, If you have not registered and paid by the cut off time you will not be included in the event.
Reg forms and proof of payments must be sent to g-spot@vwclub.co.za, A confirmation mail will be sent once received.
If you have any issues or questions please mail the events guys at events@vwclub.co.za
Classes on the day: (club members will be scored as per the club classes)
A - VAG =/> 2.0 NA
B - VAG 1.7 - 1.9 NA
C - VAG 1.6 and below
TD - VAG TDI
FA - VAG <1.9T
FB - VAG 2.0 FI Ko3 or similar
FC - VAG 2.0 FI Ko4 and bigger
FD - VAG AWD
FE - VAG AWD > 2.1FI and BIG turbo
OA - Non VAG NA
OB - Non VAG FI
R - Race (Nitrous, slicks, stripped interior ect will fall in this class)
Check back here for more details on whats happening on the day...
GPS co-ords for ODI:
S25' 32.270 E27'57.450
DIRECTIONS TO GET TO ODI RACEWAY VENUE FROM JOBURG
Take the N1 (Ben Schoeman Highway) to Pretoria. This will become Potgieter Street with C-Max Prison on your left. Proceed down Potgieter Street until you get Church Street. Turn left into Church Street and continue until you get to DF Malan Drive. Turn right into DF Malan Drive and go straight until you get the PPC cement factory on your left. Proceed past until you get METRO on your left. Just after Metro you will get a turnoff that says Mabopane. Turn left onto this road - called Mapopane free-way. Pass one turnoff until the road makes a 270 degree turn. Proceed over the mountain. Pass first turnoff and cross over N4 pass Rosslyn turn off. Take the M20 Hebron turnoff. (7.7km from N4 brigde) turn left and go straight. Be on the lookout for the Marula Sun boards. Proceed straight on until you get the Marula Sun board approximately 10.3km to 4-way stop MABOPANE GARANKUA. Continue straight over 4-way stop for approximately 6.2km finding thatch roofs on left and a Liquor store on your right. Across the road is a road that turns left (sign board to ODI RACEWAY). Turn left and follow this road. This will lead you to the track entrance.
ALTERNATIVE ROUTE
to get to ODI Raceway
Travel on N1 towards Petersburg. Take N4 split just after Zambezi turnoff. Follow through tollgate. Take 4th turnoff R80 SHOSHANGUVE left, road makes a complete 270 degree turn. Travel in a northerly direction for 7.7km. Proceed past ROSSLYIN turnoff until you see Marula Sun boards. Take HEBRON off ramp and turn left. Go straight for approximately 10.3km until you find the board marked Marula Sun. There will now be a 4-way crossing MABOPANE GARANKUA. Set Speedo to zero and go across the 4-way stop for 6.2km. You will pass thatch roofs on your left and a Liquor store on your right. At the sign board (ODI RACEWAY), turn left and follow this road. This will lead you to the track entrance.
MAP DIRECTIONS
Start at Pretorius Street. Pretoria, South Africa
Head west on Pretorius St toward Leyds St 850m
Turn right at the 3rd cross street onto Jeppe St 500m
Turn left at the 3rd cross street onto Proes St/N4 3.2km
Turn right onto D.F.Malan Dr 66m
Slight left to stay on D.F.Malan Dr 3.9km
Turn left onto R80 (signs for Soshanguve) 18.9km
Take exit 57 toward Soshanguve/M20/Hebron 550m
Turn left onto Hebron Rd 3.4km
Continue straight onto M20 7.1km
Slight right to stay on M20 6.3km
Turn left 1.8km
Confirmed list of entries, As always, If your name is not here, I didn't get your forms.For those going to ODI for the first time, i thought i would take some time to advise you about ODI and what to take along with you...
Firstly, ODI is about 90-100km(IIRC) from JHB Central. The route to ODI is 20% freeway and 80% rural. There are a millions of huge speed bumps along the 80% rural roads. The roads are not bad, but keep your speed down and look at the road carefully. There are some potholes along the way. Becareful for taxi's that drive 20km/h and dont let you pass or that want to overtake you on the rubble while you slow down for bumps/potholes.
The Xcede guys suggested i carry the following, thanks to their advise, i survived the day - Just kidding, its not so bad but best be prepared.
Due to the fact that this place is an open field with a tarred strip, please carry the following:
1. Something for shade while you not in the car - Gazebo or Hat. If you take a Gazebo, make sure its pegged down properly, it tends to get windy and the Gazebo might dissapear or hurt someone. I took a hat as i went alone.
2. Sunblock - Lots of it. As there is no shade, you need some protection from the sun. I didnt take this and ended up a few shades darker than usual. I sat in the car with the aircon on to cool down at some point.
3. Water/Drinks - You will need to hydrate yourself pretty often as you have to wear helmet, long pants and top. I had a tshirt on and used a thin jacket when i was participating. Remember, you in a line of maybe 10-15 cars at a time in the heat so you perspire a lot.
4. ICE - To keep your drinks cool and to cool down the car. It helps wonders...
5. Cooler box to keep 3 and 4 in.
6. Food - They do have a little shop that sells chows, but they do not cater for halaal/kosher/veg.
My advise, get there early. Start your runs early and maybe leave around 3pm. I found that by 2pm, i was drained and just wanted to head home. The heat takes its toll on you there. Plus, adrenalin rush and awesomenes!!!
Use it dont use it...
The most important advise i can give anyone, go and give it your all... You will love it!!
Pre reg is closed, There are some spots open on the day, But entries are capped at 120, First come first serve.
1.Pumkani Nkosi
2.marcel Truter
3.Sanjay Dayah
4.Johan De Wit
5.Dexter Rautenbach
6.Albert Edward Hughes
7.Martini
8.James Barnes
9.Guillaume Cillie
10.Byron Bezuidenhout
11.Jonathan Thiel
12.Lawrence Kuisis
13.Tristan Gunn
14.Ridwaan Ally
15.Yulon moodley
16.Dineshen Chetty
17.JJ Potgieter
18.Pradeep Gopal
19.Wynand Britz
20.Chris Swart
21.Wikus Dippenaar
22.Stephan Smith
23.John Sanders
24.Safwaan Ahmed
25.Stanley Ah Towel
26.Maroof Gangat
27.Jan-Britz du Plessis
28.Brendan Penny
29.BigMIg
30.Justin George
31.Martin De Klerk
32.Hemand Rampursat
33.Muhammed Moolla
34.Kyle Miscia
35.James Souris
36.Warrick Morris
37.Lynton Clamp
38.Graham Savage
39.Mohammed Ismail Vally
40.Gerardo Cammarata
41.Mike Laing
42.Ruan Rehder
43.Fanie Olivier
44.Ryan Demoser
45.Wynand Van Den Berg
46.Jarryd Basdeo
47.Denzal Naidoo
48.Ruan Steyn
49.Francois De Wet
50.Neil Bothma
51.Donald Button
52.Ian Foat
53.Nicolas Soo
54.Mark Atterbury
55.Qhivi Tiva
56.Lance Turner
57.Petri Smith
58.Donavan Aarons
59.Danev Singh
60.Chad Wentzel (stage 3 TT-RS )
61.Nihahn Nana
62.Tavisha Moodley
63.Gavin Frost
64.Rouwellyn Moodley
65.Irfaan Chavoos
66.Nick Henry
67.Calvin ibbitson
68.Jean Van Heerden
69.Viroo Chetty
70.Zane Bower
71.Brent mcmahon-Panther
72.Bradley Pillay
73.Evangellos Liveris
74.Dirk Louis Froneman
75.Rafeeq Osman
76.Renier Bernardo
