Post new topic Reply to topic  [ 8 posts ]
VR6 lip
Author Message
Newbie
Car Model: Caddy mk1
Post VR6 lip
Hi guys,
So I got myself a VR6 lip for my caddy, and want to fit it tomorrow, is it a big hassle to make them fit? I know i have to take the bumper off for it so that you can do a proper job, but what would be the correct way to fit it?
Thanks in advance :D
_________________
Real cars are not bought, they are built!!
Fri Jul 30, 2010 10:36 am
Profile E-mail
Car Model: MkIV GTI , 96 VR6
Post Re: VR6 lip
the vr6 lip fits into the bumper via slots in the bumper and clips on the lip
the caddy wont have these, thus you will probably have to self tappet it.
as well its going to be too long, so will have to be cut
good luck :hi:
_________________
EX RIDES
1600 Datsun SSS (2 door) SOLD
200 STI SOLD
2008 Velo SOLD
MK1 Rabbit (2.0 16V ABF) JACKED
Fri Jul 30, 2010 11:11 am
Profile E-mail
Car Make: VW...Oviaas
Car Model: Golf 4 TDi & Caddy Van
Post Re: VR6 lip
Best would be if the bumper is off, align the VR lip, clamp down drill holes through lip & bumper, where you can bolt & but it, Pop-rivet etc.
Mark excess that needs to be cut off, mask off to ensure you cut straight (Jigsaw is preferable)
Put bumper back & admire your handywork
_________________
1982 MK1 GL
1984 CADDY
Fri Jul 30, 2010 11:59 am
Profile E-mail
Post Re: VR6 lip
do not pop rivet it on, it'll come loose,
take bumper off, align and cut where need be in the centre, use heat gun to make it look really niceand mould the cut bit, then drill holes and put 6mm bolt and nut ... the best way to do it..
Fri Jul 30, 2010 4:12 pm
Profile E-mail
Post Re: VR6 lip
Drill holes and use small screws rather - this way if you need to change the lip in the event of it breaking or getting damaged it will be easier to remove...
_________________
His:
06' Velo 1.4i Ice White - Mk1 mudflaps, recess plates, detrumpetted airbox, KnN Flatbed, Mk2 GTi Spoiler
Hers:
05' TDi Sportline White - New Spec, mudflaps
98' Golf 3 VR6 White aka Flook - 40mm drop all round, 205/50 SZ80's, VR6 mudflaps, MK3 Spoiler, Webasto inbuilt tilt and slide
http://www.webgallery.co.za/ims/pic/830Sjq64/4553.jpg
04' Golf Life 1.6i White - Sold For the VR
Sat Jul 31, 2010 8:39 am
Profile
Car Model: Cti
Post Re: VR6 lip
Personally, I would have gone for the Golf 2 16v lip.....
_________________
Tashveer Maharaj
1993 CTi
100KW & 196Nm @ Tuneserv
1998 Mk3 GTi Exec
Mon Aug 02, 2010 8:43 am
Profile E-mail
Post Re: VR6 lip
Same here....but each to his own :hi:
_________________
His:
Hers:
Mon Aug 02, 2010 12:27 pm
Profile
Post Re: VR6 lip
you don't need to take the bumper off..
All you do is jack the car up a little..
Then you align the corner of the spoiler to the corner of the bumper..
Its much easier if you have somneone to help you hold the spoiler in place as you use dry wall screws to attach the spoiler to the bumper in the corner..
Then attach the side of the spoiler and then work towards the center off the car
Do'nt attach the entire spoiler leave about 15-20cm..
Follow the same steps attaching the oter side
Once done there will be an overlap of the two sides..Center a line with the center line of the car..
Cutt off the excess and attach the loose bit on either side..
Tue Aug 03, 2010 11:06 am
Profile E-mail
Display posts from previous:  Sort by
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
Search for:
Jump to:
Powered by phpBB © phpBB Group.
Designed by Vjacheslav Trushkin for Free Forum/DivisionCore.
