Good morning all.
My A4 will do this once every now and then and is certainly not consistent at all. Sometimes I don’t start the car for 4 days and it’s fine.
Then I’ll use the car for 2 days in a row and I’ll get a very rough idle on a cold start. Engine is shaking and car is shaking. From the exhaust you can hear a miss fire or something for sure.
Goes away after 3 min or so and after that car is 100%.
I scammed the car with an OBD scanner. No engine light was on at all but got this code :
No idea on the bottom part when it mentions a bottom key not working. Is this code in anyway related to the issue I occasionally have?
Thanks everyone
Car Scanner ELM OBD2
DTC report
Selected brand: Audi
VIN: WAUZZZ8K7CA022256
============1==============
5646
Raw code: 00160E
ECU: Engine control unit
Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
Audi: B13C9FB: Multimedia system control head
Function key bottom right
2011 A4 B8 2.0TFSI cold start issue
- Car Model: A4 2.0T
- Car Model: Mk2 GTS
Re: 2011 A4 B8 2.0TFSI cold start issue
Your scanning results does not show anything. Try using a different scanner and post the results
S4 2004 --> Stock
A3 2010 1.8T Cabrio --> Stock
Previous
Golf Citi 2.0 8v MP9 2007
Jetta 4 V5 10V
Honda CB400 '74
S4 2004 --> Stock
Previous
Jetta 4 V5 10V
Honda CB400 '74
- Registered for: 1 year 6 months
Hi Wade
Did you figure out your problem?
Sorry for only seeing this now.chmarshall81 wrote: ↑Wed May 17, 2023 3:56 pm Hi Wade
Yes. PCV valve was done for.
New valve and so far so good.
