[NEW PRODUCT] NF Diesel Lubricity+
- Wave
- Fuel Additive Specialist
- Car Model: Polo TSI HL
NF Diesel Lubricity+ increases the lubrication properties of diesel. Diesel fuel pumps and injectors rely on the diesel to lubricate them. Lower sulphur diesel tends to have less lubricity and therefore does not provide the same lubrication. NF Diesel Lubricity+ will significantly increase the lubricity of the diesel to help extend fuel pump and injector life.
Lubricates diesel pumps and injectors
Prevents wear and potential seizing of moving parts in diesel injection systems
Helps engines run smoother and quieter
Upper Cylinder Lubricant
Compatible with all grades of diesel
1 bottle treats 600 litres of diesel (1ml NF per 2 litres of diesel)
Non-Flammable
http://www.nfadditives.co.za/Products_D ... y-Plus.php
If you want the most out, put the best in!
2017 VW Caddy Crew Bus 1.6 - NF's delivery van
2009 Toyota Fortuner 3.0 D-4D 4x4 (M) - Mine
2014 VW Polo 1.2 TSI HL - The better half's
- Wave
Re: [NEW PRODUCT] NF Diesel Lubricity+
Its been tested at an independent lab and it improves the lubricity of Diesel by 33%
It is compatible with all diesel motors
