280mm bolt on Brake upgrade kits for MK1 is here!!!
Delarey Racing Developments specializes in standard automotive and custom performance automotive parts
duncan
Car Make: SEAT
Car Model: Golf MK1
Re: 280mm bolt on Brake upgrade kits for MK1 is here!!!
Post by duncan »
Viper wrote:Hi mr
The brake upgrade is only available from us . The discs on the other hand is available from any Goldwagen.
I have found no quality difference between Febi, ATE and Meyle . The big difference is price. I can post it down to you for R55.00 extra
So you guys are linked, all GW's across SA? Then I get it at Goldwagen Bellville.. Do you guys use the FEBI pads over the FERODO to match the disks?
16v
'05 velocity ABF
'95 cti
Viper
Goldwagen Delarey
Registered for: 13 years 2 months
Car Model: GOLF 1 1870cc 8v ethanol
Membership No: 1800
Post by Viper »
We prefer ebc pads , but if you don't have the budged for that use ferodo.
We are a franchise and not linked at all. We all get out parts from the same mother company apart from my special parts, like the brackets witch i designed myself
Cyle16v
Registered for: 11 years
Car Make: Mazda
Car Model: Boosted 3
Membership No: 1923
Post by Cyle16v »
It might be a stupid question but if i were to change to these discs, would i need to change my calipers, at the moment i have solid discs, and i noticed these discs are vented ???
I know 2litre and still solid discs...asking for trouble :fear:
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Yes it would work fine , unless you still have the small d200 pad calipers
duncan
Car Make: SEAT
Car Model: Golf MK1
Post by duncan »
Ya I figured you are franchise, fone GW in CPT, they only stock the disk size and the pads but not that specific bracket you were talking about. You said you make use of the 280mm polo disks instead of the 288mm disk, only reason therefore is because the 288mm limits you to certain rims am I correct?
16v
'05 velocity ABF
'95 cti
duncan
Car Make: SEAT
Car Model: Golf MK1
Post by duncan »
16v
'05 velocity ABF
'95 cti
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker »
duncan wrote:Ya I figured you are franchise, fone GW in CPT, they only stock the disk size and the pads but not that specific bracket you were talking about. You said you make use of the 280mm polo disks instead of the 288mm disk, only reason therefore is because the 288mm limits you to certain rims am I correct?
I had 288mm late VR6 disks on my Velo and GT, the problem is not with the extra 4mm it's bigger, it's with the increased off-set (basically the width of the spacer). I had 15" Velo rims on both cars. Wikus's kit maintains the correct off-set, allowing you to fit any aftermarket rim specified for the Citi Golf (15" or bigger)
Current rides:
Hyundai - 1.4 Getz (daily)
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
That's exactly correct. Thanks Torker
Sent from my GT-N7105 using Tapatalk
duncan
Car Make: SEAT
Car Model: Golf MK1
Post by duncan »
Mainly the only thing stopping me is I've got a set of 16" mk4 GTI rims and a Velo rim. So i'll have to redrill your set to accomodate the GTI rims as well? Where the VR6 will be a bit better for my situation of wheels.
Sorry Torker, probably riving you crazy with the dumb questions on my thread as well. :fear:
Should learn to search threads before posting my own.. :bang:
16v
'05 velocity ABF
'95 cti
julianjvr1023
Registered for: 10 years 4 months
Car Model: Scirocco mk1 1979
Post by julianjvr1023 »
Is there a vented disc option
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
julianjvr1023 wrote:Is there a vented disc option
The discs are vended. But if you want to know if they are drilled, then no they are not.
segokgo
Car Model: vw mk1 caddy
Post by segokgo »
Viper wrote:Yes it would work fine , unless you still have the small d200 pad calipers
I have a 1984 caddy, I realised the caliper are no the same as the one in your picture/ will this system still work with the old 1984 model?
respond soonest
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
respond soonest
Yes but you will have to change to the newer caliper :oops:
segokgo
Post by segokgo »
respond soonest
Yes but!!!!! :bang:
Thought this was a straight fit to all Mk1
Damn.....
After I have evrythn, now I need change yet another thing
So which year model of mk1 will its callipers work...??
Bt I asked this question Before on our communication Viper
chucker02
Car Model: Citi ADY
Post by chucker02 »
segokgo wrote:
respond soonest
Yes but!!!!! :bang:
Damn.....
Not his fault you have other calipers, just get them at a scrap yard and fit the kit
1971 VW beetle
segokgo
Post by segokgo »
chucker02 wrote:
segokgo wrote:
Viper wrote:
segokgo wrote: I have a 1984 caddy, I realised the caliper are no the same as the one in your picture/ will this system still work with the old 1984 model?
respond soonest
Yes but!!!!! :bang:
Damn.....
I dnt remember blamming any1 here, and I dnt remember you bein the middle man of what I was advice to put you inthe position to say what u are sayin now
And now I was simply asking so I can solve the problem am facing and stil u not helping
chucker02
Car Model: Citi ADY
Post by chucker02 »
segokgo wrote:
chucker02 wrote:
segokgo wrote:
Viper wrote: Yes but you will have to change to the newer caliper :oops:
Yes but!!!!! :bang:
Damn.....
Yes you asked the question if they would fit on your caddy. All I am saying is that Viper could not have known what calipers you have, looks to me as if you are blaming him. Just get the correct calipers then. Any citi or velociti calipers would fit, provided you get the carrier for the calipers as well.
1971 VW beetle
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
They do fit all mk1 golf's. If you have small calipers on , then you need to upgrade unfortunately. If you have asked me this question before and I miss understand It, I apologise.
segokgo
Post by segokgo »
Thank you Viper,
So I shud just look for any bigger than mine golf 1 callipers rite?
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
segokgo wrote:Thank you Viper,
Just find any mk1 caliper af a golf that's manufactured after 1982. That's why it doesn't make sense that your 1985 got small calipers on :bang:
segokgo
Post by segokgo »
this is the calliper I have on mi 1984 caddy
tried test fitting the bracket and this is how it sit on the hub
the pink arrows represent the gab left
the green part is where it bolts and it is not aligned
the blue part is where the bracket sit on the hub
Now help, what should I do
was thinking I should grind a lil on the hub (the blue part).........
advice guys
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Jip we fount that on a few of the older mk1's. The casting are very rough and we needed to clean the the part up using a grinder just make them fit more snugly. Your calipers have been modded BTW, some one removed the front bar between the upper and lower part of the caliper :fear:
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Online
Crawler
Car Model: 9N3 Polo TDi
Membership No: 1358
Post by Crawler »
I like the paint pic ^^
CW Polo TDi Sportline
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker »
Not really an issue, I picked it up when I fitted the kit to my '83 GT, 30 minutes with a grinder sorted it out nicely...
Current rides:
