Golf 6 Gti hard starting
Phil
Registered for: 9 years 6 months
Post by Phil »
Hi guys.I have a problem with my Gti.Vehicle battles to start up usually while still warm.Cranks fine but battles to fire-up takes 2 to 3 attempts sometimes having to floor accelerator.No errors come up.Vw checked it out for me and said the only error that came up was a cam sensor position error,but what I find strange is that the error only appeared once a few days ago but the problem is now daily.Any ideas?Regards
Titleists
Philosopher STIG
Car Model: 2016 Golf R
Membership No: 1520
Re: Golf 6 Gti hard starting
Post by Titleists »
The chain tensioner might be on the way out. Take it back asap before the engine fails to start completely.
Sent from my VCDS
VCDS changes done by me for a minimal fee
My ex rides:
2013 LHD Scirocco R
2011 Golf 6 GTI
TimeShifter
Car Model: 2012 Mk6 GTi
Post by TimeShifter »
Titleists wrote:The chain tensioner might be on the way out. Take it back asap before the engine fails to start completely.
Sent from my VCDS
Do this like in yesterday!!!
2012 VW Golf Mk6 GTi
Post by ruan9n »
Camshaft positioning sensor.... is there oil seepage coming from it? Take it out and clean it then reinstall and see what happens! It's a common problem across the world on 2.0tsi's, oil seeps past its little green gasket and into the sensor itself.
hernandez
Car Model: X5M, M5, TOUAREG, CORSA UTE
Membership No: 1491
Post by hernandez »
cam chain jumped 1 tooth, thus the fault and the hard start. 1 more tooth and engine is game over. Have seen this plenty times. Tensioner failure allows enough slack to jump. Check urgently
Current: BMW X5M, BMW M5TT, BMW 335 TT, TOUAREG, CORSA UTE
Ex: 4x C63 (2XSupercharged) , 1x Bmw M5 V8 biturbo, 2x G5 GTI k04's, 1x R32 G5, 1x G6 R, 1x Amarok DC, 1x Touareg, 1x Bmw X5 v8, 1x audi A3 2.0T, 2x audi S3, 1x audi TTS.
Yes, I have an addiction.
Solo786
Car Make: Porsche,BMW,VW
Membership No: 1251
Post by Solo786 »
rather have it towed in rather than risk driving it
Post by ruan9n »
hernandez wrote:cam chain jumped 1 tooth, thus the fault and the hard start. 1 more tooth and engine is game over. Have seen this plenty times. Tensioner failure allows enough slack to jump. Check urgently
Tata hasie :hi:
K.J
Car Model: MK6 GTI
Post by K.J »
Is there a definite way to confirm this?
I have similar problem, but VW says they can't find anything wrong..
So it's a back and forth saga with nothing getting done, and OP and me would be in similar situation...
We can't wait for it to break before anything gets done
Titleists
Philosopher STIG
Membership No: 1520
Post by Titleists »
K.J wrote:Is there a definite way to confirm this?
Yes, open up the motor.
My ex rides:
2013 LHD Scirocco R
2011 Golf 6 GTI
K.J
Car Model: MK6 GTI
Post by K.J »
Is there a way to convince VW to do this?
Titleists
Philosopher STIG
Membership No: 1520
Post by Titleists »
K.J wrote:Is there a way to convince VW to do this?
Yes, you have to pay them. Unfortunately, they are not interested in doing anything before something breaks even when they know it's going to break.
My ex rides:
2013 LHD Scirocco R
2011 Golf 6 GTI
Phil
Post by Phil »
Hi,what doesn't make sense to me is the fact that if I try and start the vehicle as soon as I have stopped and turned it off ,it starts with no hassle.It only occurs when the vehicle has stood for a few minutes.Would this still relate back to the chain having jumped a tooth?Would I not notice any deficiency while driving if that was the case?
Abnormal
Registered for: 20 years
Membership No: 848
Post by Abnormal »
The cam tensioner works with oil pressure.
Letting it stand for store time means the oil pressure needs to build up before it can tension the chain again.
\Oo) \ _w_ / (oO/
hernandez
Membership No: 1491
Post by hernandez »
Abnormal wrote:The cam tensioner works with oil pressure.
revised part has spring now
K.J
Car Model: MK6 GTI
Post by K.J »
What about possibly the hpfp?
Is supposed to prime when drivers door is opened, but i notice mines only starts when key is in ignition and in on position.
Phil, try putting key in on position for a few seconds and then start, and if it's better
Phil
Post by Phil »
Problem sorted!
Belix
Car Model: Passat B8
Post by Belix »
so what was it the tensioner after all?
Wisey
Registered for: 6 years 3 months
Post by Wisey »
No guys
its a common issue on this engines...... the most failing parts could be fuel module or tank fuel pump ....
From my experience i ve got MK VI- GTi and MK VI-R
Belix
Post by Belix »
there are so many supposedly common issues, it's getting hard to keep track of them all...
Seeing wisey is new and probably trying to sell something we can probably expect at least 50 old posts resurected relating to anythin golf 6 and 7.
RoyG6R
Registered for: 6 years 1 month
Car Model: mk6 Golf R
Post by RoyG6R »
Hi Guys! I have recently got my Golf 6 R and its running well and smooth, just wanted to know why is it swings sometimes and the you gotta gas it and it starts...but doesn't occur all the time. I have asked VW as to whats up with this.
2013 Golf 6R
2014 CLA AMG
1989 MK1 GTI 2.0l 8v
RB35 Nissan Skyline
Tebohovw
Registered for: 4 years 9 months
Post by Tebohovw »
Hi Guys
I have exactly the same problem as Phil (Golf 6 Gti hard starting), I changed the chain system at 200 000km and I am now on 260 000km. what could be the problem and what was Phil's solutions guys? I am so frustrated
