Golf 4 GTI-R wont rev past 5500 RPM
fadeel
Wheel Whore
Post by fadeel »
Hi All,
I have pulling my hair out for this problem, besides all the money I had to spend with no luck!!
I have a 2004 GTI-R and she has 180K kms on it now already. The car used to run like a demon, but now it will not rev past 5500 rpm.
Whats has happend and what is still happening :
The problem just started out of the blue, one day it was fine the next it wasnt.??
1. Replaced the Divertor Valve. - Showed up on the error codes.
2. Replaced the PCV - Did not show any error but replaced anyways.
NO LUCK - still the same
3. Replaced the MAF sensor - No luck.
4. (The money Spinner) - replaced the entire turbo, plus oil feeder lines :???: - No luck
5. Changed out the crank sensor, from a working GTI-R same model, no luck!!
Now I really need assistance! Please someone help.....
What next? I am at my wits end....
PS....we have checked the boost pipers for leaks ( i guess the best way we could removed and replaced)...
Help please.....
Any suggestions would be appreciated.
Regards
Fadeel - Tired and ready to strike a match!
BongzThaMr_K
Car Make: Polo
Car Model: Vivo
Re: Golf 4 GTI-R wont rev past 5500 RPM
Post by BongzThaMr_K »
Get a diagnostics check done might be a fault in software or perhaps you'll pick up a problem there , goodluck
I'm argumentative, uncompromising and Emotionally-distant. Being with me's a war of attrition...
That's what winning the war gets you! *Remisces to my days in Vietnam*... *Sheds a Tear*
Previous Car: Toyota Tazz 160
Current Car: Polo Vivo 1.4 With Ridiculous Bass from the Boot
Howie-WP
Membership No: 2033
Post by Howie-WP »
BongzThaMr_K wrote:Get a diagnostics check done might be a fault in software or perhaps you'll pick up a problem there , goodluck
+1
This ....... before spending money by guessing what the problem could be.
fadeel
Wheel Whore
Post by fadeel »
Thanks for the responses so far....
Just to make it clear...I did the diagnostics and also had the car checked multiple time...on many occations the car car gave no errors...and as it stands right now...as far as computer id concerned there is no errors.
PapaJo
Registered for: 14 years
Car Make: VW's
Post by PapaJo »
Get diagnostic check done and run some logs.
If you can install a temporary boost gauge to check your boost.
Check for leaking boost fittings. Any whistle sounds under boost.
Have you had plugs and fuel filter checked? Is your car pulling strong on lower revs and then just does not want to go further.
Have you checked the loud pedal? DBW pick accelorator input from here and it has a variable resistor switch / slide wire and this might be offset. Should pick this up on diagnostic log. Is idling low or where it should be?
fadeel
Wheel Whore
Post by fadeel »
Awesome...thanks....I will check the loud pedal switch..and fitting a temp boost gauge.
Just to answer some of your questions...
We have checked the fuel pump even bypassed the cut out to see if it was the fuel pump. Checked the fuel filters as well. Same problem.
We had replaced the Coil packs some time before the problem started.
We also serviced the car, and replaced the cam belt and tensioners...no difference.
Will try your suggestions and revert back.
Digit Riaan
Registered for: 18 years 9 months
Post by Digit Riaan »
Are you doing all this yourself?
fadeel wrote: 1. Replaced the Divertor Valve. - Showed up on the error codes.
What error code is that?
fadeel wrote: PS....we have checked the boost pipers for leaks ( i guess the best way we could removed and replaced)...
How did you check it?
fadeel
Wheel Whore
Post by fadeel »
Hi,
1. Replaced the Divertor Valve. - Showed up on the error codes. - This I did myself
What error code is that? - I cant remember, but it said in the report to replace the DV.
PS....we have checked the boost pipers for leaks ( i guess the best way we could removed and replaced)... - This was done via a mechanic, and he said that the boost pipes were removed and checked and then I replaced one with a new one as it had a tear in it.
Any other suggestions?
Killerwatt
Car Model: S3
Post by Killerwatt »
It was probably the pressure drop between turbo and engine error. It tells you to replace the dv.
You should log the following:
Requested Boost
Actual Boost
N75 duty cycle
Airflow
Specified Load
Actual Load
Throttle body position
Requested Air Fuel Ratio
Actual Air fuel Ratio
Ignition timing angle
Timing delay on all cylinders
And also check fuel trims.
Check if any of the actual parameters do not meet the specified.
Is the car stock? If not then what mods do you have on there?
Also where are you located?
If you are unsure how to interpret the logs then you can email them to me and i will have a look.
fadeel
Wheel Whore
Post by fadeel »
Hi Killerwatt,
Thanks for the reply, I am in Cape Town.
I will log the car and to get the logs again. The car is standard, the only mod (if you want to call it that) is a flat bmc filter.
I will get the logs asap.
Digit Riaan
The only way to check for a boost leak is to pressure test the system to 1bar with compressed air like so:
http://www.audizine.com/forum/showthrea ... eak-Tester
Then, start with WOT logging the following blocks using VAG-Com:
003+115+119
001+031+118
002+020+111
001+002+031
There's no point (except wasting money) in replacing things if you do not know 100% what's wrong, but I'm sure you realise that now.
fadeel
Wheel Whore
Post by fadeel »
hi porno_ster
Thanks a million, I appreciate all the help. We will assemble a device like that and test again. I just sorcing someone to do the logging as well.
I will revert asap. I also agree that throwing good money after bad is just not on.... :(
Digit Riaan
fadeel wrote:hi porno_ster
No problem, as Killerwatt said, we can help with deciphering the logs once you have them.
ETunersSA
Car Model: Golf 7 R TTE535
Post by ETunersSA »
Check that your TIP is not squeezing closed at those RPM's.
We have replaced a few stock TIP's on the 1.8T where the car would just not want to rev pass a certain RPM (Usually upper RPM band)
Replacing the TIP solved the issue.
Worth a try
Shaheen Moosa
- BMW X4 xDrive20d MSport Auto
- Tiguan 2.0TDI R Line 4 Motion Highline DSG
- Citi Golf CTi 1.8
- Golf Mk2 CSX 1.8
- BMW E46 325TI MSport 6 Speed
- BMW E30 325i MEX 1989 Diamond black metallic
- BMW E30 325i Shadowline Mtech2 Brilliant Red
VELO-GP
Car Model: MK4 GTi
Membership No: 1870
Post by VELO-GP »
test your fuel pressure, and check your throttle body - i (Tiaan) picked up this problem on my car
Digit Riaan
VELO-GP wrote:...and check your throttle body - i (Tiaan) picked up this problem on my car
Jip, throttle body alignment is a must.
http://www.youtube.com/watch?v=2zrmhDw_v7Y
Solo786
Car Make: Porsche,BMW,VW
Membership No: 1251
Post by Solo786 »
I would also check the TIP is not collapsing under load.
If thats fine then check the FPR and perhaps the TB.
fadeel
Wheel Whore
Post by fadeel »
Hi All,
Just an update, and once again thanks for all the feedback.
So after all the advise and too and fro, here is what was done and the car is still the same.
1. Did a diagnostic check and it came up with a few error.
2. Replaced the Divertor Valve. - Showed up on the error codes.
3. Replaced the turbo with the oem replacement part, as the boost pipes were soft during boost, and it was found that the turbo was cracked between the exhaust housing and the actuator.
4. Replaced the oil feed lines to the turbo.
5. Changed the MAF sensor
6. Checked the fuel filter and fuel pump, as well as the the fuel pressure.
7. Checked for Boost leaks - with a compressor and gauge.
8. Checked N75 Valve - the actuator is responding, so possibly not a boost problem.
9. Swapped out the crank sensor.
10. Had the car at a VW dealer, and here is the answer "We cannot find the problem"
SO - The car still wont rev past 5500rpm, and it is not like it hitting the limiter, it gets to 5500 rpm, and then everything just shuts off!
Any more suggestions would be appreciated.
All the macks in CPT know this car already!
Regards
Fadeel
SemiColon
I sparkle in the sunlight
Car Make: Volvo
Car Model: S40 T5
Membership No: 1641
Post by SemiColon »
Are you sure its not a tdi?
Sparkz0629
Car Model: 2012 Polo GTI
Membership No: 1768
Post by Sparkz0629 »
SemiColon wrote:Are you sure its not a tdi?
LOLLLLL!!!! :lol: :lol: :lol:
Sparkz0629
Membership No: 1768
Did you try what Shaheen advised?
VVVVV
ETunersSA wrote:Check that your TIP is not squeezing closed at those RPM's.
Worth a try
PapaJo
Car Make: VW's
Post by PapaJo »
Sparkz0629 wrote:Did you try what Shaheen advised?
VVVVV
Worth a try
:iagree:
Is it cutting out like a fuel or spark cut off or just hang on to the 5500 rpm's?
Longshot.......is exhaust not blocked?
Digit Riaan
fadeel wrote:Hi All,
Regards
Fadeel
Diagnostic check does not equal logs. Log it as I recommended and them come back with the info. If you keep on replacing stuff you are just wasting time and money and hoping for the best.
Killerwatt
Car Model: S3
:iagree:
Do the stock k03 tips really get sucked closed though?
I thought this was just the k04 cars...
Digit Riaan
Killerwatt wrote::iagree:
I can't see how this will happen on a stock GTI-R system...It most likely an electrical problem, i.e. ECU power cut, spark cut, etc.
