MICROBUS.......
MICROBUS.......
hi guys.
firstly i would like to apologise. posting in wrong section probably.
need some help.
1998 microbus.....does this come in 1800 ? as standard from the factory being a limited edition ?
regards
need some help.
regards
- Velofox
- Car Model: '94 FoxT 2.0 16v'
- Membership No: 1314
Re: MICROBUS.......
5 or 4 pistons?PRESTON wrote:hi guys.
need some help.
regards
5 will not be though as that should be from 2.1 and up i guess
Current Rides
1994 2.0 16v FoxT - Lexy
1998 2.0 8v Mk3 GTI - Liesy
My Inspiration
16vT Engine Pics
My Inspiration
16vT Engine Pics
- 16vnut
- Car Model: Citi 1.6i
- Membership No: 1941
Re: MICROBUS.......
yep, it came in a 4 cylinder 1.8.....4 speed if i'm not mistaken.
OumaBeskuit wrote:Nonuts is still better than Numbnuts!
"It's only when you see a mosquito landing on your testicles that you realise that there is always a way to solve problems without using violence."Psycho8v wrote:This has not ended well. Now you have dark blue nuts...
- Velofox
Re: MICROBUS.......
and that is the strongest gearbox also for them16vnut wrote:yep, it came in a 4 cylinder 1.8.....4 speed if i'm not mistaken.
Current Rides
My Inspiration
16vT Engine Pics
My Inspiration
16vT Engine Pics
Re: MICROBUS.......
True - My Notch has a Kombi 4 speed gearbox and it's bulletproof!!!!!!!!Velofox wrote:and that is the strongest gearbox also for them16vnut wrote:yep, it came in a 4 cylinder 1.8.....4 speed if i'm not mistaken.
Saul Van Rensburg
Golf MK1 GTX
VW Type 3 - Subaru 6 cylinder swop in progress
Golf MK1 GTX
Re: MICROBUS.......
thanks for the feedback guys
just wanted to confirm cause i know a lot of people change those
motors........
and this was said to be orginal.
regards
motors........
regards
- 1 Eyed Monkey
- Membership No: 1280
Re: MICROBUS.......
1.8's were commonly known as Kombi's, and were mostly Panelvans. But they were nothing to 2.3's. In fact, the 2.3's were the best Carabusses made(being a former taxi driver, I should know).
SHAUN wrote:Only been watching midget porn lately, uses half the data.1 Eyed Monkey wrote: If you know Shaun, you'll know he has the biggest porn collection in Gauteng....
- Car Model: Vento VR6
Re: MICROBUS.......
There were lots of 1.8 Kombis sold. Yes, as someone else stated they were badged Kombi and not Microbus when they were passenger vehicles. The 1.8 panelvans were badged Transporter in the early 80s and Van in the late 80s and the 90s. They always had 4 speed gearboxes. The Kombi was a stripped out Microbus...AFAIK they never had P/S or A/C and in the 90s had wheel caps and not mags as standard and a single headlight grille.
Many of the 1.8 buses were owned by SAPS and overall they were quite uncommon siince at the time there was a more sensible 2.3i "volksiebus" that was only a little more expensive.
If you're buying a T3 as a family vehicle I highly recommend the 2.5i. That was the best cruiser made in T3 buses. The 2.6i fuel consumption was ALOT higher. The 2.3i was an excellent passenger vehicle but the fuel consumption was higher than the 2.5i due to the 4 speed box. My dad had owned the 1.8, 2.5i and 2.6i and we found the 2.5i to be the best overall option.
Hope my post helps P.S If you need any help just PM me, I know a fair bit about T3 buses and the continued improvements that were made to them over the years.
[EDIT] During the late 90s the 1.8 T3 was badged Microbus.
Current: 1996 VW Vento VR6
Previous: 2006 VW Polo 2.0 Highline & 2008 VW Citi Rox1.6i and many others
Man who scratch ass should not bite fingernails.
- Post Whore
- Car Model: boat
- Membership No: 1133
- Car Model: MK5 GTI (BWA)
Re: MICROBUS.......
so which year model for the 2.5 would you recommend and why ?Possession wrote:There were lots of 1.8 Kombis sold. Yes, as someone else stated they were badged Kombi and not Microbus when they were passenger vehicles. The 1.8 panelvans were badged Transporter in the early 80s and Van in the late 80s and the 90s. They always had 4 speed gearboxes. The Kombi was a stripped out Microbus...AFAIK they never had P/S or A/C and in the 90s had wheel caps and not mags as standard and a single headlight grille.
Re: MICROBUS.......
I dónt get why the 2.5 would be heavier than the 2.6, they are identical engine blocks, 2.5 uses k-jet and 2.6 digifant style injection, so the 2.6 should be better.
My dad on the other hand said screw this and put a 2.8 30V audi V6 in his, IIRC the 5-speed box lasted all of 100m when it exploded during the test-run 2nd gear change. He changed it to a 4spd and never looked back
'10 Tiguan 2.0TDI
'00 A3 1.8T
'00 A3 1.8T
Re: MICROBUS.......
On paper the 2.6i is lighter but in practice it isn't. Ask anyone that had owned both around the same time and they will agree that the 2.5i is lighter. I do know that the 2.6i is heavier... Anyway, these are just my opinions.JVRDesign wrote:I dónt get why the 2.5 would be heavier than the 2.6, they are identical engine blocks, 2.5 uses k-jet and 2.6 digifant style injection, so the 2.6 should be better.
Re: MICROBUS.......
All the 2.5i models were pretty much the same. They didn't even appear across specs.GV wrote:so which year model for the 2.5 would you recommend and why ?Possession wrote:There were lots of 1.8 Kombis sold. Yes, as someone else stated they were badged Kombi and not Microbus when they were passenger vehicles. The 1.8 panelvans were badged Transporter in the early 80s and Van in the late 80s and the 90s. They always had 4 speed gearboxes. The Kombi was a stripped out Microbus...AFAIK they never had P/S or A/C and in the 90s had wheel caps and not mags as standard and a single headlight grille.
Stronger motors and much easier to repair due to kjet and cheaper parts + lighter on fuel + better acceleration
- Mark Taylor
Re: MICROBUS.......
Hi gents ladies and others. I have a VW Microbus 2.5 I 5cyl (aay motor) I'm looking for a workshop manual for her. I tried Lindsay Sakers they told me that they don't work on "S..T" and sent me away. my main problem is I'm getting about 3Km/Lt. And the fuel pump relay seems to be missing .I've checked behind the right tail light but can't seam to identify it ,what does it look like? and does it have a code or number to identify it with ? Any help or advice is welcome .thanks Mark...
Re: MICROBUS.......
If the fule pump relay was missing I doubt the bus would be running.
- Mark Taylor
Re: MICROBUS.......
I've hot wired the fuel pump to get her to run...how do I identify the relay does it have a number on it ..I've checked behind the tight tail lamp found five relays. Which one is it .thanks four your help...
Re: MICROBUS.......
I have long forgotten the relay number. But they are easilynidentified when you pull them out. The fuel pump relay has much bigger terminals on the middle two amd it has a small pin offset to the side that the others don't have
Re: MICROBUS.......
Hi. I have a T3 2.5i Caravelle with AAY engine. 1991 model. Kombi having misfire problem only when reaching temp and when fan kick on. Running 100% when cold no problems but the moment it gets hot misfire starts and engine dies aswell then struggling to start again. I replaced the coil with Bosch, Distributor, Plugs, Leads, fuel distributor, fuel pump, ignition module, fuel filter and air filter but nothing is working. I even had kombi with autolek but to no prevail. Not sure what to do now all mechanics stump and everyone giving differentopinions but nothing working. Did or are thereany T3 owners out there that have or had the same problem a I need to urgently fix it. Thanks
