mp9 throttle body pinouts?
- Car Model: Citigolf 1990
I was wondering if anyone could help me i would like to know the pinouts or have a wiring diagram of the mp9 trottle body please (looking to see if i can make a manual controlled idle screw for inside the car as i am running a gotech system)
- Colonel
- Membership No: 1041
thanks alot for the link it is greatly appreciated but i specifically need to know what each throttle body pin is used for so that i can build a control circuit for the idle control valve.
CitiGolf 1.8i mp9 with gotech-mfi, 276 cam, 4-1 cowley branch, 50-57mm two box (powerflow), BMC flat bed air filter
hey sorry just wanted to bump this thread up again please if anyone could help me i promise to make whatever i work out or develope known for everyone running managment systems without idle control THIS IS FOR THE GREATER GOOD!!!!!!!!!!!!!! PLEASE ANY INFO IS WELCOME
Re: mp9 throttle body pinouts?
It's been a month anyone please!!!!!!!!!!!!!!!
- Car Model: 1994 GOLF CTI
my dictator diagrams has it as:
1:idle stabilizer 12v+
2:idle stabilizer -ve
4: tps ground
5: tps signal
7: tps 5v+
i don't know what pin 3,6,8 are for.
but my car idles fine just takes two tries to start if it is really cold. but i am done with all that stuff i am fitting mp9 this fry day
4: tps ground
5: tps signal
7: tps 5v+
Golf CTI"94
2.0 AGG mp9
2.0 AGG mp9
Yeah i've got those in my gotech manuel as well its the others that i wanna get hold of but thanks for the input
i went and had a look at the plug. there are only 7 wires cant remember if it was pin 6 or 8 that was mising. but those other two wires are for the idle moter as well. remember it uses a stepper moter . the two wires that are left after the pin outs i gave you are the wires for the angle limiting on the butterfly. the dicktator uses it in a strange way thats why its slow to adjust the idle.
hope this helps
hope this helps
Golf CTI"94
2.0 AGG mp9
2.0 AGG mp9
- Car Model: MK4 Jetta 2.0
here is for the MP9 ECU but the t/b pinouts are on there:
1 Ground
2 Throttle body 1
3 NC
4 Injector 4
5 NC
6 Injector 2
7 Injector 1
8 Phase sensor +5V
9 RPM signal
10 Throttle body 3
11 GND
12 NC
13 Phase sensor signal
14 Throttle body 4
15 NC
16 Throttle body 8
17 GND
18 TMAP 4
19 Knock sensor 2
20 NC
21 Batt 12V
22 NC
23 GND
24 Ignition Control unit
25 Fuel pump relay
26 Throttle body 2
27 NC
28 Inj 3
29 Diag K-Line
30 NC
31 NC
32 NC
33 NC
34 NC
35 AC
36 Vehicle speed input
37 TMAP 3
38 O2 Data
39 Knock sensor 1
40 NC
41 Throttle body 5
42 Engine Coolant sensor
43 TMAP 2
44 NC
45 Screen for Phase and Knock sensor wires.
1 Ground
2 Throttle body 1
3 NC
4 Injector 4
5 NC
6 Injector 2
7 Injector 1
8 Phase sensor +5V
9 RPM signal
10 Throttle body 3
11 GND
12 NC
14 Throttle body 4
15 NC
16 Throttle body 8
17 GND
18 TMAP 4
19 Knock sensor 2
20 NC
21 Batt 12V
22 NC
23 GND
25 Fuel pump relay
26 Throttle body 2
27 NC
28 Inj 3
29 Diag K-Line
30 NC
31 NC
32 NC
33 NC
34 NC
35 AC
37 TMAP 3
38 O2 Data
39 Knock sensor 1
40 NC
41 Throttle body 5
43 TMAP 2
44 NC
Membership number: 1115
Jetta 4 2.0
MK1 GT 2.0 16v
Golf 2 2.0 16v ABF Gotech
Golf 2 2.0 8v MP9 Unichip
Jetta 4 2.0
MK1 GT 2.0 16v
There is a wiring diagram on the Gotech web site.
On MP9 t/b:
Pin 4 Earth
Pin 5 Signal
Pin 7 Positive
On MP9 t/b:
Pin 4 Earth
Pin 5 Signal
Pin 7 Positive
Jetta 4 2.0
MK1 GT 2.0 16v
Jetta 4 2.0
MK1 GT 2.0 16v
your reply has given me more insite thank you i knew it was a stepper motor but still not quite sure how to controll it properly epspecially if it has feedback to the computer box i'll just tinker with it for a while till i get it right and if i do i'll share all information on the forumk-jetronic rule wrote:i went and had a look at the plug. there are only 7 wires cant remember if it was pin 6 or 8 that was mising. but those other two wires are for the idle moter as well. remember it uses a stepper moter . the two wires that are left after the pin outs i gave you are the wires for the angle limiting on the butterfly. the dicktator uses it in a strange way thats why its slow to adjust the idle.
hope this helps
Can someone please give me vw cities golf throttle body 8pin NUMBER AND COLOR FOR EACH NUMBER PLEASE
- Colonel
Throttle Body
Pin no. - Ecu Pin No.
1 - 2
2 - 26
3 - 10
4 - 14
5 - 41
6 N/A
7 - 17
8 - 16
dont worry about colour, long as correct pin from TB goes to correct pin to ECU
1 - 2
2 - 26
3 - 10
4 - 14
5 - 41
6 N/A
7 - 17
8 - 16
