Water temp sender housing leak
Swaerie
Post by Swaerie »
Morning,
It seems that the FI head i acquired from 8V is slightly different than the others i have seen before.
It has a recessed area where the housing that holds the font water temp sensor bolt on. The flange is thus pulled up but the o ring cant form a seal.
Is there another type water housing to ask for at GW?
Have anyone seen a head like that.
Any help would be welcome.
Thanks in advance, Swaerie
Re: Water temp sender housing leak
There should be no different housing and no recess - was maybe some rust. Have that machined flat or try finding a fatter o-ring and or add some sealant.
Swaerie
Post by Swaerie »
Panic,
Thank you. Can i perhaps send you the picture via whatts App?
Swaerie
Why not just post it here for everybodies comment /benefit. ?
Swaerie
Post by Swaerie »
Struggling my bum off to get that to work. Will try though
There are a million posts of how to do that. Host at something like postimgs and post the link here.
