Hi, we have a problem with one of our caddy"s door switches, it doesn't close causing the central locking not locking the car cause it thinks the door4 is still open, can someone maybe advise me which wires I must test in the door connector to locate the faulty micro switch, otherwise I am going to have to remove all the doorcards.
Thanks in advance
Vw caddy door micro switch test, central locking not locking
- Armand
- Car Model: Black Magic 6R Polo Gti
- Membership No: 1828
2011 Black 6R Polo Gti (Forge intake, Viper dp, Stage 2 DNA sw)
2007 Polo gti (Giac software, 76mm dp, ITG Induction, custom FMIC)
2009 Citi 1.4i sport
1997 Uno turbo ( w/m, Tdo4 turbo, intercooler,76mm exhaust
Bmw 540i e34 (Standard)
Nissan 3.0 v6 (Brospeed branches and exhaust)
2009 Polo gti (Giac software)
Suzuki gsxr1000 k5 (Everything)
Vw caddy club (Mp9 conver, Branches, exhaust, chip)
Re: Vw caddy door micro switch test, central locking not locking
It could most likely be the sensor wire in the door rubber that has been broken. It senses when there is some obstruction in between the door and door frame. Check at the bending corners and where the cable go into the rubber.
If you have it scanned for errors, it should tell you which sensor is not healthy.
- Registered for: 19 years 5 months
- Car Model: Touareg / Caddy / Polo / Citi
Our Caddy (1.9 Life TDi) has the same issue, but intermittent. It's on the right rear passenger sliding door. Every time you go over 20km/h you hear a click sound from the door, but it doesn't lock the door and you have to then lock it manually.PapaJo wrote:It could most likely be the sensor wire in the door rubber that has been broken. It senses when there is some obstruction in between the door and door frame. Check at the bending corners and where the cable go into the rubber.
PapaJo - I am curious, Would this sensor wire be in the door frame rubber and if so where does it enter the rubber seal? Perhaps where that three pronged pin enters the vehicle body on the B pillar at the front of the sliding door?
Anton van Graan
2009 Touareg 3.6 VR6
2007 Caddy Life 1.9 TDi
2004 Polo 1.6 Comfortline
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
1988 Ford Laser 1600i Sport
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
- Car Make: Nike
So it doesnt show you which door it is? Not even on the Screen or doesnt it have that aswell?Armand wrote:Hi, we have a problem with one of our caddy"s door switches, it doesn't close causing the central locking not locking the car cause it thinks the door4 is still open, can someone maybe advise me which wires I must test in the door connector to locate the faulty micro switch, otherwise I am going to have to remove all the doorcards.
Thanks in advance
I would suggest you get a guy with VCDS, thats the only way to trace the correct door.
Only way to test it to take the door card of. Each door has its own module that controls that. So wires coming out of door wont normaly give you a clear indication.
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
Check this site for reference and locate the cables. There is other pages also indicating that there is a switch in the pillar.
http://www.realoem.me/Volkswagen/ZA/CAD ... 971/972035
Thanks for the link, I will certainly check it out.
I had the whole central locking door lock mechanism changed about a year ago as it stripped on the inside, so I presume my problem might not be the cable to the mechanism, but rather a dirty connection at the door or the actual door switch.
Thanks for your assistance.
Anton van Graan
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
