Howsit Guys
I have just done the engine on my vehicle
Did the complete block and head cylinder
The timing is perfect set on relevant marks the rear main seal is also set right
But the car idle seems to fluctuate and cuts off at certain times
Ran a diagnostic on the vehicle gives the error of cam shaft sensor
my question is before buying a camshaft sensor is these problems in line with the symptoms of a cam shaft sensor ?
vw polo 9n bah
- Car Model: POLO 9N
Re: vw polo 9n bah
You need to give the exact error. IE does it say the camshaft sensor is dead - ie open circuit or short to grounfd or short to plus OR does it say camshaft correlation error.
- Car Make: Vw golf
- Car Model: Citi golf 2.0L 8V
Re: vw polo 9n bah
Hi I’m sitting with the same problem exactly the same problem ,error code it give “P0343 -camshaft position sensor A circuit high bank 1 or single sensor” that’s what it shows on my OBII reader and the car was fine wen it came in redid the whole
Motor with rear main crank seal
- Car Make: Vw golf
