Hi all,
Seen multiple reads on vacuum etc.
Misfire at idle. Converted 1600 to longblock 2.0 Carb motor.
The intake manifold has a green substence/ residue.
Will inspect manifold later the week but wanted to know if the misfire is due to vacuum leak issue and or potential coolant leaking into manifold.
Closing half of carb with hand the misfire goes away. Cant find any other leaks on system. Not even on carb.
Cheers
Swaerie
Vacuum leak and green residue in Intake manifold
Re: Vacuum leak and green residue in Intake manifold
Pictures would be helpfull. But is the coolant you a using green?
Sounds like it is running lean, did you adjust the idle mixture a bit richer ? The bigger motor will,want a bit more fuel.
Panic,
Dont see coolant level dropping as actually. Could it be fuel.
Swaerie
Swaerie
yes it can. But again - useless without pictures. It 'can' be lots of stuff
