Hi All. Some help please. A friend knocked the bottom of her car. Front passenger side. Soon after that the temp warning came on. When we stopped someone pointed to a cable hanging below the car. See attached. The wires are yellow and brown. The yellow terminal has pulled out, but seens like it can easily be pushed back into the plastic bit... what is this? Bearing on temp problems. She has only been driving short distances in cooler weather. The warning has not come on again. Any advice greatly appreciated.
Polo 2012 vivo... what is this part?
- Car Model: Sportline
- Membership No: 3194
Re: Polo 2012 vivo... what is this part?
Outside Temperature Sensor.
- Car Make: SEAT
Ambient temp sensor
EDIT: Oops, beaten to the post!
I feel yours is more correct.Supervan II wrote:Ambient temp sensor
Thanks for the help... Google tells me this is only aircon related... not the engine temp. That correct?Bandit2803 wrote:Hi All. Some help please. A friend knocked the bottom of her car. Front passenger side. Soon after that the temp warning came on. When we stopped someone pointed to a cable hanging below the car. See attached. The wires are yellow and brown. The yellow terminal has pulled out, but seens like it can easily be pushed back into the plastic bit... what is this? Bearing on temp problems. She has only been driving short distances in cooler weather. The warning has not come on again. Any advice greatly appreciated.
- Car Make: SEAT
Only MFD related. Unless you have Climatronic installed.Bandit2803 wrote:Thanks for the help... Google tells me this is only aircon related... not the engine temp. That correct?Bandit2803 wrote:Hi All. Some help please. A friend knocked the bottom of her car. Front passenger side. Soon after that the temp warning came on. When we stopped someone pointed to a cable hanging below the car. See attached. The wires are yellow and brown. The yellow terminal has pulled out, but seens like it can easily be pushed back into the plastic bit... what is this? Bearing on temp problems. She has only been driving short distances in cooler weather. The warning has not come on again. Any advice greatly appreciated.
- Registered for: 1 year
It's called exterior temperature sensor or something.
The aircon does not switch on without it.
Mine also dislodge after a knock and then dragged and broke off, luckily found the piece, reattached, bought a second hand part from scrap yard, but it was the same price as one from Goldwagen (just R150).
Then it worked again. But I think if it gets wet it also stops the aircon working.
Also the radiator fan goes on all the time if that sensor is broken.
2013 Polo Vivo sedan
