Need some serious help
I have posted earlier this year about my electric window issues on my VW Polo 9n3 tdi 96kw.
So from the last time I’ve changed the switch on the door. Which worked perfectly fine till it rained and it stopped working, I then had a spook in my door which after around 15mins all windows work. I then changed the module on the door and worked perfectly fine throughout the year, till last months heavy rain in jhb that caused it to stop working. I now, only have my drivers window working and no passenger.
Does the module need to be changed?
Does the wiring loom neeed to be changed?
Does the switch need to be changed?
I was gonna try petrol and matches
Please help!!!
My nightmare called electric windows
- Kid_Rocc
- Car Model: Scirocco 2.0TSI
- Membership No: 3007
- stig
- Membership No: 2083
Re: My nightmare called electric windows
Sounds like my passanger side window. Only does auto down not auto up.Kid_Rocc wrote:Hi guys
Please help!!!
Maybe its getting water ins. Thats causing problems
The Ride:
H&M Dyno Night: 114KW 429NM
- Kid_Rocc
Passenger doesn’t go up nor down. Drivers auto up remains disabled for 5mins then auto works
I’ve also suspected that but but all wires are insulated.
Module I bought was from a polo vivo gt though
- Tman21
- Car Model: BosPolo
- Membership No: 3247
I have L+R OEM window motors from G5 if you need it let me know.
#TMAN21
#TMAN21
- Kid_Rocc
Thank will doTman21 wrote:I have L+R OEM window motors from G5 if you need it let me know.
- markfish888
- Registered for: 13 years
- Car Model: B7A4 -JETTA Mk2
- Membership No: 1787
corrosion on the connectors
check the connectors at the doors. They corrode there.
- Kid_Rocc
Hi guys update on the windows.
It’s March 2018 and my windows still don’t work
I’ve changed both door modules, both switches and still not luck
We’ve found that if you unplug the module for 5mins and plug it back on, you have it working from passenger side for 10-15min then off. However in that time period, the main switch from drivers side doesn’t work.
Drivers window work constant
PLEASE FOR THE LOVE OF GOD HELP!!!
Otherwise we shall see the first 96kw with winders
Thanks in advance
Thanks in advance
Bro did u fix the problem?
