Screamer Pipe
- smitbrandon
Screamer Pipe
How's guys,
Quick question wrt a screamer pipe, I have not seen anyone in rsa running a screamer pipe before?
I noticed it's a bigger thing in the US but then again in some or the vast majority of states claim it illegal due to the sound levels it generates at high boost levels.
I have heard if this setup being used mainly for drag purposes but research is extremely limited with regards to its benefits if any?
My question is: despite the sound emitted from this setup that in my opinion sounds ADDICTIVE, does this so called "screamer pipe" produce any performance increase at all?
I understand that the design is for a quicker release on excess exhaust fumes? But is there any real benefit for terms of performance?
- Pynoxim
Re: Screamer Pipe
I run a screamer pipe, as do many people I know that do BT builds. There is a performance increase IF your wastegate originally ran into your exhaust but your exhaust was too restrictive then switching to a screamer pipe would bring about some extra power.
Re: Screamer Pipe
No power gains. It's easier to build because you don't have to join back into the exhaust again which always cracks unless you have some flex pipe. It is only for external waste gates.
It is noisey becuase you literally open the exhaust straight into atmosphere bypassing the silencer.
- Ian_F
- Car Model: Voetswagen
- Membership No: 1846
Re: Screamer Pipe
I know of at least 5 cars in the VAG fold currently running BT's and screamer pipes.smitbrandon wrote:How's guys,
Some find the sound intoxicating, others not.
Like Panic said, it all depends on the setup.
- Car Make: Merc
- Car Model: C63 Edition 507
Re: Screamer Pipe
Thanks Panic you can make mine with a screamer....panic-mechanic wrote:No power gains. It's easier to build because you don't have to join back into the exhaust again which always cracks unless you have some flex pipe. It is only for external waste gates.
Polo 20VBigT - The Redhead
C63 507 Edition - The Dragon
Isuzu 4x4 - Little Joe
Re: Screamer Pipe
are there any build threads on this ?
the 5 bt's with screamers lets see how they work ?
- Ian_F
Re: Screamer Pipe
Kieran D's Project MK6R
https://r.tapatalk.com/shareLink?share_ ... are_type=t
Here’s one on the forum
- PoLonY
- Car Model: A8
- Membership No: 1997
Re: Screamer Pipe
Hate the damn things
Get into Boost and all you hear is a 38 or 44mm exhaust pipe shouting
Horrid
All BT builds I’ve done or been involved in are recirc back into exhaust
You spent thousands on a sweet sounding exhaust that you can’t hear under load? Neh fok that kak
Horrid
- Ian_F
Re: Screamer Pipe
Each to their own though. Some find the noise intoxicating, others can't stand it.PoLonY wrote:Hate the damn things
Horrid
I am with you on this one though...
(Damn, I just agreed with you... FFFFFFFSSSS)
- smitbrandon
Re: Screamer Pipe
Agreed, I'd love to see different setups.Rourke wrote:are there any build threads on this ?
- Waz_05
- Car Make: Mazda
- Car Model: Rx7
- Membership No: 1935
Re: Screamer Pipe
Screamer Pipe one time
Hi Ian and Stratt
Hi Ian and Stratt
- smitbrandon
Re: Screamer Pipe
Howsit bud, this link just redirects me to the main page again?Ian_F wrote:Kieran D's Project MK6R
- smitbrandon
Re: Screamer Pipe
A car running with an internal wastewater OEM setup, would it be a big project to do the conversion to the screamer pipe and external wastegate?panic-mechanic wrote:No power gains. It's easier to build because you don't have to join back into the exhaust again which always cracks unless you have some flex pipe. It is only for external waste gates.
- Ian_F
Re: Screamer Pipe
You can shut itWaz_05 wrote:Screamer Pipe one time
Hi Ian and Stratt
@smitbrandon, It works fine for me, but I just read the thread and there are no pics of the screamer pipe setup.
- Unobeat
- Car Model: Uno, Auris, CX-5
Re: Screamer Pipe
Horrid
- Pynoxim
Re: Screamer Pipe
I hate mine, I really do, I've been planning on routing it back into the exhaust once I get my stock 57mm exhaust and all 3 boxes and both resonators replaced with a 76mm setup. I mean sometimes I just need to overtake quickly and then suddenly... screamer.PoLonY wrote:Hate the damn things
Horrid
- PoLonY
- Car Model: A8
Re: Screamer Pipe
Yeah it’s even worse on low Boost setups where the damn thing is open 24/7Pynoxim wrote:I hate mine, I really do, I've been planning on routing it back into the exhaust once I get my stock 57mm exhaust and all 3 boxes and both resonators replaced with a 76mm setup. I mean sometimes I just need to overtake quickly and then suddenly... screamer.PoLonY wrote:Hate the damn things
Horrid
- smitbrandon
Re: Screamer Pipe
Lol why the hell would anyone want to daily a car with a screamer pipe... #madness I would install one in a weekend car but after the advise you all have provided above its pretty much pointlessPoLonY wrote:Yeah it’s even worse on low Boost setups where the damn thing is open 24/7Pynoxim wrote:I hate mine, I really do, I've been planning on routing it back into the exhaust once I get my stock 57mm exhaust and all 3 boxes and both resonators replaced with a 76mm setup. I mean sometimes I just need to overtake quickly and then suddenly... screamer.PoLonY wrote:Hate the damn things
Horrid
