golf iv sdi
golf iv sdi
from which other vw can I replace my g4 sdi,nd is it possible to make it faster without mapping?
- Neuk
- Treasurer
- Membership No: 806
Re: golf iv sdi
Are you looking to replace the engine? The easiest way to make just about anything faster is with mapping and most modifications that you can do will require some mapping.
Re: golf iv sdi
Sdi was a naturally aspirated diesel that made 50 kw. No amount of mapping or other work is going to make that fast ever.
The easiest to kake that faster is to sell it and buy something faster.
Re: golf iv sdi
OK for now I will have to settle on the gearbox cause what I have shakes around 80km/h,can just go for any vw nd which clutch kit would I need to fit?thanks in advance
Re: golf iv sdi
Go to a goldwagen and ask for the correct clutch kit. Get it installed somewhere. Vw will charge you way more. Silly to go tomagents with a car that old. Of course you don't give an hint of where you are so impossible to refer you anywhere.
- Neuk
- Treasurer
Re: golf iv sdi
What shakes at around 80 km/h? You are very vague in describing your issues.rmake wrote:OK for now I will have to settle on the gearbox cause what I have shakes around 80km/h,can just go for any vw nd which clutch kit would I need to fit?thanks in advance
Re: golf iv sdi
the car shakes when the speed get to 80 u can feel it underneath the pedals,I just need to know if I get to a scrap should I just get from any other vw nd will it be a straightforward fit
- Neuk
- Treasurer
Re: golf iv sdi
What are you looking to replace from a scrapyard? And what is the cause of the shake?rmake wrote:the car shakes when the speed get to 80 u can feel it underneath the pedals,I just need to know if I get to a scrap should I just get from any other vw nd will it be a straightforward fit
Re: golf iv sdi
I suggest maybe going to visit a mechanic.
Re: golf iv sdi
I believe its the gearbox nd clutchkit
- Neuk
- Treasurer
Re: golf iv sdi
Why?rmake wrote:I believe its the gearbox nd clutchkit
- Neuk
- Treasurer
Re: golf iv sdi
You wish you knew why you believe it is the gearbox/clutch causing a vibration from only 80km/h? Instead of simply replacing parts on your car I suggest doing some proper diagnosis work to try pinpoint the cause of the vibration.rmake wrote:wish I knew
- Donavan
Re: golf iv sdi
Its more likely to do with either wheel alignment or wheel balancing or worn wheel bearings/hubs or worn suspension bushes.
Audi A4 B8 2.0T - Daily
Re: golf iv sdi
OK the machanic says I need a new clutch it cost about 6k,is there a way I can convert to a cheaper clutch like maybe from a vr6?
Re: golf iv sdi
contact Goldwagen delarey. They do a single mass clutchkit.
