rusty block
wesley ZA
rusty block
Post by wesley ZA »
evening guys,
so after i pulled the head and so on, i noticed rust and rust pieces in the water ways, how can i clean this **** out without taking everything out of the engine bay? there is no visible damage on the gasket so still no clue wtf went wrong, but anyway question stands...
HOW DO I CLEAN MY CAR'S ENGINE BLOCK OF ALL THE ****????
thanx in advance!
PapaJo
Registered for: 14 years
Car Make: VW's
Re: rusty block
Post by PapaJo »
Radiator flush would be your best bet! Lots of it.
Once it is cleaned out put antifreeze/water mixture in
markfish888
Registered for: 13 years
Car Model: B7A4 -JETTA Mk2
Membership No: 1787
Re: rusty block
Post by markfish888 »
pull top & bottom radiator hoses, flush with garden hose till run clear
pull hoses from water pump, flush with garden hose till run clear
make sure therostat is clean
pull hoses from head, flush with garden hose till run clear.
once clean, refill ONLY with G11/G12 coolant & distilled (or at least boiled) water .
Do NOT use the cheap yellow/green/pink coolant available from spares shops!
wesley ZA
Re: rusty block
Post by wesley ZA »
The head is off... only block left in car
