Turbo oil drains
Turbo oil drains
Howzit guys, has anybody made a hard line (steel piping) for a turbo drain without any sort of flex material? I want to know what are the chances of it cracking.
Re: Turbo oil drains
About 99.9999999999999999999999999999999999999999999999999999999999999999999999999percent sure of it cracking
Oh well thats a high chance.. lol.
I thought since the turbo and engine move together it wouldnt be a problem.. the rubber/braided part on the oem drains tends to kind of melt after time
Not just actual movement, it's vibration that kills it.Ashveer03 wrote:Oh well thats a high chance.. lol.
Ok, thanks for the advice guys.. heading over to a hydraulic shop to check what they have
Alternative is always to buy an OEM part like from a TDI or gti and make a piece to join it to the turbo.
I went to a friends shop and got a piece of steel braided hydraulic pipe..
Just to check the difference, i cut of a small piece of the aftermarket pipe and stripped of the steel braiding, and did the same with a damaged tdi oem steel braided pipe..
Both have ribbed teflon inners, the oem pipe looks more like those plastic covers u get to cover wiring harnesses. The aftermarket 1 seems to be of better quality though, not sure if thats because the oem part was deteriorated. Will post a pic later
The small black pipe is oem
That ain't no drain pipe. That is a supply pipe. Are you sure you are talking about the right thing?
Drain is out the bottom of the turbo and into the sump.
That is the drain. Oem feed is a hard line.
can you put something next to it for scale?
Like a ruler or measuring tape
- Criminal Troll.
you get a great pipe from FTF.
use that on all my drain setup with big turbos, in saying that i have manifolds jigged so i use oem
@Panic will post a pic tomrw
@boostd thanks, but im getting 1 sorted with hydraulic fittings and steel braided hose
@manali i dont know what u going on about
- Car Model: 18 Polo Vivo
- Membership No: 1691
I used a power steering pipe on mine but changed to lemon when got a new one
The Events Toy
Project Louise Drag Car
The Daily
Project CTi
The Daily
Project CTi
Lemon?
Ok so not knowing exactly why you asked the question here is what I mean. You can't have hard pipe all the way. it has to have some sort of soft pipe in between. if you issue is that you want to do a new turbo conversion then buy a pipe like this and modify it to suit the new application.
If you have a current tdi and the pipe is leaking heck just get a new one. They are not that expensive. If you feel it is way too much then take the entire pipe to a hydraulic shop and see if they can put a new piece in the middle.
Its for a conversion.
I asked if a complete hard line can be used because i saw that the oem hose has deteriorated, and wanted to possibly avoid that in the future.
But as ur first post stated that it will definitely crack, i got it made up in a steel braided teflon lined hose.
Just remember that some turbos want a big return. For instance garrett t3 cores want a minimum of 16mm otherwise they tend to smoke.
Yeah, thats the reason i dont wanna use any part of the oem 10mm ID drain, and got a complete new pipe made up
- Neuk
- Treasurer
- Membership No: 806
So The Witch made you her ****?smritilekhac1979 wrote:Hi I have for a year tried to defeat Assassin's Crees Bloodline P.S.P Game Boss 'The Witch'.I Am tired of playing now so I have Decided to put a save data and skip it.But the problem is i can't find a save data for Assassin's Creed (P.S.P) Game named 'The Witch' Please tell me where to download it.Thanks In Advance
Lol what the hell is wrong with this dude
- Neuk
- Treasurer
Do you have The Witch's number? I am sure she can sort the spammer out...Ashveer03 wrote:Lol what the hell is wrong with this dude
Yeah il give the witch a call..
