Another coilover thread
- Car Model: Audi RS3
Hi Gents,
Need some advice / info please!
Will be fitting a set of coilovers to my Citi soon.
Coilovers of choice will be the JOM redlines.
What I would like to know:
Should I set a decent ride height at first to settle the shocks in before slamming them down?
Should I remove the helpers allround?
Should I cut the bumpstops?
tx
tx
His: '18 Nardo Grey Audi RS3
Hers: '19 VW T-Cross 1.0 TSI Highline DSG
Weekender: 'Searching for a neat enough VR6...
- travzo
- Car Model: CTI golf
Re: Another coilover thread
you can go way down by removing the helpers but it would be bouncy....
are you gonna put strut spacers?
do i need spacers?
- travzo
No but if you like me and want to be slammed you should.. also notch
the idea for now is to get the car sitting nice and low while still having a decent ride.
I will look into notch and extended top mounts for ultra low in future.
- PoLonY
- Car Model: A8
- Membership No: 1997
Remove helpers if slamming it on its nuts
Remove/trim bumpstop yes
They'll settle a lil but nothing major, if your plan is to slam it then it'll make little difference what you do on a mk1 lol
Extended top mounts will help though
Same for ball joint extenders and tie rod flip
- PoLonY
- Car Model: A8
Oh and double notch on a mk1
it's gonna ride badly anyway so don't worry about trying to keep any ride quality.
Off topic and qqPoLonY wrote:Remove helpers if slamming it on its nuts
Does trimming the bumpstop make the ride better?
- PoLonY
- Car Model: A8
Yes if you lowered enough you'll end up riding on the bumpstop which create a bumpy harsh rideraeesdawood wrote:Off topic and qqPoLonY wrote:Remove helpers if slamming it on its nuts
- yeo786
- Car Model: Velociti 1.6i
You should c-notch only if you plan on going ultra down ie if you have low profile tires or 14s and really wanna stance, otherwise not necessary. My car is set on around 70/60 and c-notch wasn't required, however it is a nice thing to do since it saves the chances of the cv shaft rubbing against the chassiszane.mk1 wrote:Hi Gents,
Coilovers of choice will be the JOM redlines. - These are nice however the spring rate compared to the blueline is harder
You should just install first so you can get an idea of how the car will look then you can adjust from there
Yes it will make adjusting easier too and free up space so you can go really low
Yes you should, or like me just take them out completely
tx
If you're in control, you're not going fast enough!
Current :
VW Velociti 1.6i
Ex -Honda Ballade EF 160i 16V Dohc - Sold
Ex -VW Citi 2.0 8V Carb - Sold
Ex -CitiRox 1.4i - Stolen
Current :
VW Velociti 1.6i
The drive shaft rubs. . Cv is very far from there.
- Neuk
- Treasurer
- Membership No: 806
And you don't need to go that low to get the driveshafts to rub, mine already do from time to time and my MkI is not low at all.panic-mechanic wrote:The drive shaft rubs. . Cv is very far from there.
I know. On the right hand side with the thicker shaft specially. Have done a few in my day for race cars.
