Anyone DIY car Headliner???
- Membership No: 2033
So my mk3 GTi needs a new headliner, old one is sagging. I have goggled and downloaded a few DIY's of the 'net. Seems easy enough, just time consuming.
Anyone done this? In for real world tips
Found the liner at Kehls @R88/m (1mx1.4m).....glue? Seen overseas they use 3M 77 (found on TakeAlot @ R602!)
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- amstel18
- Car Model: Tiguan Allspace
Re: Anyone DIY car Headliner???
Haven't done it myself, but seen some guys use the spray on glue like you get at the craft shops.
Try Superfloral in Paarden Eiland for the glue...
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- JasonCPT
- Car Model: A4 1.8T
I need to do mine as well but wanna do alcantara. Up for a headlinder day one weekend?
- Car Model: Golf MK5 2.0 TFSi
I did mine on a polo. start In the middle. if you're using contact adhesive let both sides dry before sticking it together, or it will forever stay tacky. a second set of hands helps. try and get material that is foam backed, it just feels better, but you cant stick it then pull it off if you get a crease or if the material is not aligned properly.
I am also doing / going to use a "heavier" automotive material for the headliner (thinner layer of foam).JasonCPT wrote:I need to do mine as well but wanna do alcantara.
Seeing on youtube, prep is the most important, so likely gonna remove the liner and prep board and then later install.
HOWIE-WP,
Remember your post in your rides theadturbowheelchair wrote:I did mine on a polo. start In the middle. if you're using contact adhesive let both sides dry before sticking it together, or it will forever stay tacky. a second set of hands helps. try and get material that is foam backed, it just feels better, but you cant stick it then pull it off if you get a crease or if the material is not aligned properly.
HOWIE-WP,
couldn't have been me. I did not even know about this forum when I had my polo. unless you're asking if I remember, in which case, noHowie-WP wrote:Remember your post in your rides theadturbowheelchair wrote:I did mine on a polo. start In the middle. if you're using contact adhesive let both sides dry before sticking it together, or it will forever stay tacky. a second set of hands helps. try and get material that is foam backed, it just feels better, but you cant stick it then pull it off if you get a crease or if the material is not aligned properly.
Must have been someone else then .......turbowheelchair wrote: couldn't have been me. I did not even know about this forum when I had my polo. unless you're asking if I remember, in which case, no
HOWIE-WP,
- hubbly_bubbly
- Forum Advertiser
- Car Model: Touran GTD
- Membership No: 1793
also planning a DIY on my Ibiza FR's headlining.
Will be interesting to see how everyone gets on with theirs.
Definitely not a 5min job but will be worthwhile.
Candy White 2007 Touran 1.9TDI Trendline
This.....I wonder if my temperament is up to it? Luckily my brother (spdgti) is a somewhat calming / foreman influence....hubbly_bubbly wrote:Definitely not a 5min job.
HOWIE-WP,
- Aslam_mk4
- SO FLUFFY, WE ALL GONNA DIE!
- Membership No: 1824
Can get velociti style black roof lining with the foam
Bagged mk4 2dr
"Ride or die"
"Ride or die"
- EX-DOHCTOR
- Membership No: 712
How much?Aslam_MK4 wrote:Can get velociti style black roof lining with the foam
- hubbly_bubbly
- Forum Advertiser
Do share deets pleaseEX-DOHCTOR wrote:How much?Aslam_MK4 wrote:Can get velociti style black roof lining with the foam
